Old 05-10-2013, 09:19 AM   #136
Scootern29 OP
Scootern29's Avatar
Oddometer: 510
Hey Ray, good job. I actually thought about boring the peg and making a brass bushing for it. What else I didn't touch on was the stud is also prone to bending. Personally, the whole stock design sucks. Your fix will be fine. If I was going to do another one of these bikes I would cut the lug off the frame and make new brackets and weld them on to the frame rails. It really could have been designed better. The only draw back could be getting the motor out of the frame with my solution.
Scootern29 is offline   Reply With Quote
Old 05-10-2013, 05:07 PM   #137
craydds
craydds's Avatar
Oddometer: 1,160
I actually attempted to do just that. Bored it, heated it, put the brass bushing in the freezer, attempted to press the bushing in, and CRACKED it. Plan B - made some shim material ...
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 05-10-2013, 09:10 PM   #138
Scootern29 OP
Scootern29's Avatar
Oddometer: 510
You didn't use a Coors Light can did you?
Old 05-11-2013, 06:55 AM   #139
craydds
craydds's Avatar
Oddometer: 1,160
Well, since Anchor Steam does not come in a can....
ABC #12947
'75 R90S
Old 05-11-2013, 01:35 PM   #140
Scootern29 OP
Scootern29's Avatar
Oddometer: 510
Old 05-11-2013, 04:18 PM   #141
Valleyrider
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,865
More pictures!!! Less Drinking....
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Old 05-12-2013, 02:49 PM   #142
Scootern29 OP
Scootern29's Avatar
Oddometer: 510
Uhhhh Sorry Sir, right away Sir.
I received my new billet gas cap this week. This thing is sharp looking and works great............on my MX125C. For some reason it won't fit all the way into my alloy tank but will fit my steel tanks. I contacted the maker and he is going to check his machining. It may just be my tank but who knows. They are supposed to all be the same. He is going to send me another one. When I get my new one I will let you know the sellers business. Really a nice guy.
Left to right, the new billet, stock MX, and the original YZ one that came on the bike that shrunk. It was common on the caps.
Did a little polishing of the canisters. I gotta find stickers for them or make something up.
Random pics.
Now it's time for the pause that refreshes. A cold frosty one.
Old 05-12-2013, 04:43 PM   #143
ADK
____
Oddometer: 8,225
stickers? what kind of stickers? "tach" and :speedo", I'm guessing.
ADK is offline   Reply With Quote
Old 05-12-2013, 05:32 PM   #144
Valleyrider
I Survived The '60s
Oddometer: 1,865
And a well deserved frosty one!! It looks way to good to get dirty...
Old 05-12-2013, 07:59 PM   #145
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,371
Looking good..
Regarding shrinking caps... The one on my TY was off the bike or awhile when I first got it and the damn thing ended up being like a 3/4 size cap. It wasthe weirdest thing I have ever seen. I don't know why it did it. I thought maybe from some cleaner we tried in the tank.
JeffS77 is offline   Reply With Quote
Old 05-13-2013, 07:50 PM   #146
craydds
craydds's Avatar
Oddometer: 1,160
Nice work, Scott. Can I be in your club?
ABC #12947
'75 R90S
Old 05-15-2013, 04:02 PM   #147
Scootern29 OP
Scootern29's Avatar
Oddometer: 510
You probably could join our club. We are a drinking club with a racing problem.
Old 05-15-2013, 04:09 PM   #148
Scootern29 OP
Scootern29's Avatar
Oddometer: 510
So continuing on with stuff, I found stuff some stuff I needed in the next town from me. They actually had what I was looking for.
A kill switch, plastic tubing for the carb, and some rubber automotive grommets for the number plate fasteners. The old ones are messed up and brittle. The automotive ones are thinner but work ton's better.
Uploaded with ImageShack.us
Old 05-15-2013, 04:17 PM   #149
Scootern29 OP
Scootern29's Avatar
Oddometer: 510
To work on the things I bought I had to dis-assemble some of the bike. Well the whole top of the bike. Tank, seat and sidepanels. I am this far into it time to clean up and fasten some of the wiring. A little zip ty action going on
The new grommets in place. These thing work so much better than stock IMO.
Mounted the kill switch. This bike is a one lead switch so I am converting it to a two wire.
Old 05-15-2013, 04:29 PM   #150
Scootern29 OP
Scootern29's Avatar
Oddometer: 510
The kill switch I bought had different connectors than the stock Yamaha ones on the bike. No problem as I had some cool plug ins that will work. Don't mind the crappy picture.
While I was doing these things, I took a break............had a frosty one and pulled this out of the parts box. It is beat up pretty good. Time for pounding out dents and thins.
Safety tip of the day. If you cut off the zip ty's like we all do........I like to take a soldering iron to the cut off area and melt them smooth. These things are sharp as a razor and can cut you real bad. I learned this trick from my race car day's.
Times are GMT -7.   It's 11:27 PM.
