Old 03-29-2013, 03:33 PM   #61
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,375
Originally Posted by Scootern29 View Post
Thanks for the compliment on the bike Jeff. I have tried to condense this build into the last couple of weeks. I am now into the YZ 400 about 6 months. The TY could be fun unless I sell it. We will see. Do you want it?
A 250 would look good with my 175..but I dont ride trials and also have a TLR200 trials bike..go figure
hey thats not you with the '69 DT 1B parts bike on craigslist is it ? if it is..lets make a deal
JeffS77 is offline   Reply With Quote
Old 03-29-2013, 03:36 PM   #62
Scootern29 OP
Scootern29's Avatar
Oddometer: 521
Not me but I am bidding on one on ebay. I want the shocks.
Scootern29 is online now   Reply With Quote
Old 03-29-2013, 07:46 PM   #63
Scootern29 OP
Scootern29's Avatar
Oddometer: 521
Besides dealing with my neighbors VW buggy I did get the motor in the frame and it has ton's "O" spark. Yippee
I started on getting the pipe in the frame as a mock up. I have to order gaskets for the joints tomorrow.
Old 03-29-2013, 08:36 PM   #64
ADK
____
Oddometer: 8,244
Cool2
How about an aluminum swing arm?
ADK is offline   Reply With Quote
Old 03-30-2013, 05:38 AM   #65
craydds
craydds's Avatar
Oddometer: 1,167
Last night I machined the allen head screws down. It only took 40 thousants to clear the flywheel.
Machined down? Indeed, you truly are a PRO. I would have taken my angle grinder to them and whacked 'em off.
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 03-30-2013, 09:11 AM   #66
Scootern29 OP
Scootern29's Avatar
Oddometer: 521
I actually have a full suspension package for a 79 YZ 250 that would probably fit, but it would take away from the originality of the bike. But you never know...........I almost thought about making it a twin shock.
Old 03-30-2013, 09:47 AM   #67
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,375
That bike would make a good classic class bike in the d37 gp's
Old 03-30-2013, 08:34 PM   #68
Scootern29 OP
Scootern29's Avatar
Oddometer: 521
It would be a fun ride but not competitive against the 78-79 Honda's or Yamaha's
Old 03-31-2013, 11:29 AM   #69
Scootern29 OP
Scootern29's Avatar
Oddometer: 521
I spent yesterday having an early Easter party with the family. I didn't get a whole lot done before, just put the carb in some Pinesol for cleaning. But after lunch I started working on the pipe. I had sprayed the pipe with some black to keep it form rusting while waiting for the right time to install it. So I wire wheeled the paint off. I hadn't noticed this dent in the front of it.
I had done a procedure on my KTM pipe to take a dent out of it and figured I would try it with this pipe. DON'T TRY THIS AT HOME.......IT COULD KILL YOU ARE SOMEONE ELSE. Luckily I had allready had this happen so I was prepared. It will blow the cap off the end about a scrillion miles and hour.
An air fitting on one end of the pipe and a Jim-Cap on the other end.
Pull out the torch heat it up and add air. It should pop out.
It popped out about 2/3rds of the dent before the cap blew off and landed about 70 yards away out in the desert.
Old 04-11-2013, 02:33 PM   #70
Scootern29 OP
Scootern29's Avatar
Oddometer: 521
Maybe more updates later today. Been busy racin and stuff.
Old 04-11-2013, 02:42 PM   #71
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,867
I hope I am not boring anyone. I do know it is rather mundane shit at times.........but back to the forks.
Filled them up with 30wt as that is what the manual calls for to the proper amount.
I read somewhere to pump the forks about 15 to 20 times to get the air out of them. This is when I discovered that one fork leg had more oil in it than the other. Seems odd to me. I drained the forks and took measurements in the beaker again. Hmmmmmmmmm. The correct amount. Measuring from the top of the tube down to the oil level was about a 1/2" difference. I guess the maching from the factory wasn't as good as they said. Me pumpin aluminum. It was easier to do both at the same time.
I notice the CZ engine sitting under the counter just in case.
You never know.
I just picked up an ugly 1975 MX250 with a white MX400 alu tank on it,luckily it was pretty cheap what with the end broken off the crank,came with a spare engine that looks to be a DT250.
There might be something useful on it.
Handy being able to build your own shock from scratch.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-11-2013, 05:50 PM   #72
Scootern29 OP
Scootern29's Avatar
Oddometer: 521
There are actually 2 CZ motors sitting under the bench. I may have a plan to put one in a 1986 KTM chassis just because I can.
Good score on the parts. Parts is parts.
Old 04-11-2013, 05:56 PM   #73
Scootern29 OP
Scootern29's Avatar
Oddometer: 521
Before I went to the races last week I put the carb in a Pinesol concoction for about 36 hours. It cleaned up real well.
I also received parts that I am going to start installing hopefully tonight or tomorrow.
Old 04-12-2013, 05:11 AM   #74
craydds
craydds's Avatar
Oddometer: 1,167
I find the Cran-Apple cleans those carbs very well AND it's pretty tasty over ice.
ABC #12947
'75 R90S
Old 04-12-2013, 04:08 PM   #75
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,375
The 400 is looking good. I like the dent removal technique I will have to remember that one.
I got a text the other day and it seems our mutual buddy picked up the TY..cool
Times are GMT -7.   It's 10:30 AM.
