Old 04-10-2013, 07:36 PM   #1
Stinky151 OP
Stinky151's Avatar
Oddometer: 402
KLR ignition wiring
Okay, trying to finish my HDB upgrade on my KLR. With all of this, I got the BD switch that attaches to the top clamp. It is only 2 wire. the KLR switch is 6 wire. I dont care about the park lights. They can go. What else do I need to do to make this setup work? I was thinking I should be able to bridge two of the wires, and then connect the other two to the new switch. Any input?
Lincoln
"If you're in control, you're not going fast enough." -- Parnelli Jones
Stinky151 is online now   Reply With Quote
Old 04-11-2013, 04:08 PM   #2
Stinky151 OP
Stinky151's Avatar
Oddometer: 402
So I got this all worked out with one oddity. The switch is backwards. Could it be as simple as switching the wires?
Lincoln
Times are GMT -7.   It's 08:52 PM.
