Old 03-19-2013, 02:38 PM   #1
mousitsas OP
mousitsas's Avatar
Oddometer: 2,755
One for electrics gurus
I would like to intercept the rpm signal on an SE. What are the options?
Google search returned something about pin #6 of the cluster plug. What signal is this? A frequency pulse or an rpm-dependent voltage?
Alternatively, would it be possible to intercept the stator signal and extract an rpm-dependent frequency from it?
Many thanks for your input.
mousitsas is online now   Reply With Quote
Old 03-19-2013, 08:04 PM   #2
Motomedic
Motomedic's Avatar
Oddometer: 2,481
It's a pulse-5vdc. Happens pretty quickly too- have a good meter set up in the proper range. Auto-ranging takes too long.
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is offline   Reply With Quote
Old 03-20-2013, 12:00 AM   #3
mousitsas OP
mousitsas's Avatar
Oddometer: 2,755
muchas gracias!
Old 03-20-2013, 12:24 AM   #4
Remmie
Remmie's Avatar
Oddometer: 95
Look at this like. Its Dutch. But, if you look at the pictures you see what I mean.
This is the cheap version of getting the rpm signal from the cluster plug.
It works
http://forum.lc8.nl/viewtopic.php?t=4222&start=45
Remmie
I recycle, I sniff my own farts
Remmie is offline   Reply With Quote
Old 03-20-2013, 01:08 AM   #5
mousitsas OP
mousitsas's Avatar
Oddometer: 2,755
Thanks Remmie. It is the yellow wire then, right? What I cannot tell is if it already exists in the harness, or if you installed it there instead.
Old 03-20-2013, 08:51 AM   #6
Remmie
Remmie's Avatar
Oddometer: 95
The yellow wire is a new installed and connects the tachometer on the dash.There is no pin in the plug for the Tachometer.
So you have to take the plug apart and place a new pin in it. But to find e new/used pin is the problem.What you see is e cheap version without the pin.
Remark on this picture: You have to pull the wire back in the plug so its just inside the plug. When you place the plug back it connects with the (male) pin from the unit.
Remmie
Old 03-20-2013, 10:04 AM   #7
mousitsas OP
mousitsas's Avatar
Oddometer: 2,755
That is excellent. Thanks for your time!
Old 03-25-2013, 09:53 PM   #8
Wizard
Adventure Rider
Oddometer: 83
Where can you buy a tach in the USA like pictured above??
Thanks,
Jim
14 R1200Gsa 05.5 950Adv 12 990Smt 07 Husky Te610 01 Ktm 520exc
Hers - 07 F650gs 08 Wr250r
Wizard is offline   Reply With Quote
Old 03-25-2013, 11:46 PM   #9
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 736
Wicks or Aircraft spruce I believe there is a small one for ultralights.. I saw one on VDO's web page too I think.. Was lookign for one for a small race car a while back..
Dave
pdxmotorhead is offline   Reply With Quote
Old 03-27-2013, 04:38 PM   #10
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Cool2 The World is Your Oyster
Most every tachometer on Japanese (& most Euro) bikes operates directly from the primary of the ignition coil.
A search of fleabay or your local motorcycle salvage operation should provide plenty of cheap, easy choices. Just pick the one that fits your mounting ideas/requirements- a little wiring (hey you want the light on in there don't you?) some spraypaint & you're good to go!
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Times are GMT -7.   It's 11:55 AM.
