Old 04-08-2011, 08:34 PM   #1
GSDonovan OP
There and back again
GSDonovan's Avatar
Oddometer: 860
What the hell happened....steering dampener shot?
Hello all, I've got about 25K miles on an '08 GSA that I bought new in '09. I just started noticing over the last few days that my steering seems really wobbly. The handlebars turn from side to side with almost no resistance when the bike is on the center stand. Riding on the interstate seems more tiring...the front seems less planted. I'm not sure if its just my imagination or not.
Has anyone heard of the stock steering dampener failing or wearing out after such a short period of time? Maybe rain water has messed up the bearings or something?
Is there anyway to verify if its ok or not without having to take the whole thing apart?
Any comments/advice are welcome. Thanks!
GSDonovan is offline   Reply With Quote
Old 04-08-2011, 08:56 PM   #2
slowinfastout
Just Ridin' By....
slowinfastout's Avatar
Oddometer: 1,806
There is no stock steering dampener on a GS.
You could have loose head bearings or a worn front tire. You don't say the mileage on the bike, but either of those are but two possibilities.
slowinfastout is offline   Reply With Quote
Old 04-08-2011, 09:00 PM   #3
GSDonovan OP
GSDonovan's Avatar
Oddometer: 860
Thanks, I have 25K miles (stated above) on the clock...brand new front tire, so maybe its the steering bearings.
The bike is still under warranty, would that sort of thing still be covered you think?
Old 04-08-2011, 09:08 PM   #4
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,385
Slowin, you been drinkin' man?
To the OP, you don't have a steering dampner on that bike unless you mounted one. You don't even really have head bearings as you would in a normal bike, because you have a ball joint and a trailing arm instead. You do have one angular radial bearing which sits under your top fork clamp, and that can go bad but not often.
The bars ought to swing freely from lock to lock without hitching up or being sticky. If they don't, you have a problem with that bearing, and they should get notchy, not lose.
As for your steering feeling lose, there can be problems with the ball joint and it is PITA to replace. Also, you could have that tire issue Slowinfastout mentioned.
At least you have warranty coverage for the bike, which would be good news if it's the ball joint. But I'm with Slowin in thinking it's something else.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 04-08-2011, 09:12 PM   #5
GSDonovan OP
GSDonovan's Avatar
Oddometer: 860
Thanks, yeah, I may swing by the dealer tomorrow and see if they can look at it quickly. It MIGHT be my imagination, but I don't think so...it really feels much looser to me.
Old 04-08-2011, 09:36 PM   #6
Juvat
Juvat's Avatar
Oddometer: 695
Did you recently adjust the air in your tires?
Juvat is offline   Reply With Quote
Old 04-08-2011, 10:51 PM   #7
pbransonii
Big Ol' Puss
pbransonii's Avatar
Oddometer: 509
Damper.
Unless it's making your steering wet.
That's the rub ding dong. Your argument is narrow, alarmist and without merit. Aside from that it was far from succinct and lacked any elegance or eloquence.
pbransonii is offline   Reply With Quote
Old 04-09-2011, 01:22 AM   #8
Tosh Togo
Oddometer: 1,594
Originally Posted by pbransonii View Post
Damper.
Dampeners need diapers.
Tosh Togo is offline   Reply With Quote
Old 04-09-2011, 07:37 AM   #9
HunSolo
Mad Monk
Oddometer: 393
Among the conditions that will make your front end squirrelly, you might add a separation in your tire, loose spokes/wheel damage, a cracked hub, loose axle, loose lower or upper triple clamp, shock damage or failure, loose fork tube to upper triple clamp, torn or dislodged rubber bushing at the fork tube to upper clamp connection, damaged handlebar or clamp, loose grip, etc. A cursory check on the front end while on the center stand will eliminate most of these. Then the dealer, for sure.
There is always some restriction in the steering from the cable/hoses/wiring. Even a hose that was binding or a zip tie that broke and freed something up will make the lock-to-lock feel different.
All of the above is unlikely; still, your safety depends on your instincts. Don't let anyone talk you out of this. If you feel that something is different in your steering, something is probably different.
Good luck.
HunSolo is offline   Reply With Quote
Old 04-09-2011, 08:17 AM   #10
SQD8R
Eat squids and be merry
SQD8R's Avatar
Oddometer: 7,373
Did you recently play with the suspension or tire pressures? Normally that is the problem. Even if you had a SD, which you don't unless aftermarket, it would likely still be tire pressure, bearings (highly unlikely given the mileage) or improperly adjusted / set up suspension.
2006 BMW HP2E: Teutonic Dreadnought
2011 Husqvarna TE630: Swedish heritage, German engineering, Italian flair
2011 BMW S1000RR: The Barvarian Bullet
Married men don't live longer, it just seems longer.
Sour grapes are a lesser man's fruit.
SQD8R is offline   Reply With Quote
Old 04-09-2011, 08:23 AM   #11
GSDonovan OP
GSDonovan's Avatar
Oddometer: 860
Hey guys, thanks for all the comments....I'm gonna investigate the front end and look for the obvious stuff you've all mentioned. The anakee 2 tires are brand new (500 miles), air pressure is ok and steady...and I haven't been making any suspension setting changes. If I don't find anything, I'll swing by the dealer later today if they aren't swamped. Otherwise, I'll take it other next week at lunch.
Thanks again!
Old 04-09-2011, 08:32 AM   #12
SQD8R
SQD8R's Avatar
Oddometer: 7,373
Thanks again!
Another idea. If you use a top box and it is filled to capacity with something heavy, at high speeds I found the front end on my 12GS get light. But I am talking more than legal speeds.
Old 04-09-2011, 08:35 AM   #13
Lime
Lime's Avatar
Oddometer: 221
My front wheel easily turns under its own weight while on the center stand. I did however recently find a loose bolt under a plastic cap that holds the rear of the paralever to the bike.
Lime is offline   Reply With Quote
Times are GMT -7.   It's 01:26 PM.
