| View Results: How did your failure happen? | |||
| No notice at all ,left me stranded on the spot. |
64 | 22.38% |
| Noticed a problem ,but was able to ride back to civilazation |
103 | 36.01% |
| Just checked and felt fine ,but died a few hundred miles later |
17 | 5.94% |
| Noticed problem,rode bike hundreds of miles without total failure |
102 | 35.66% |
| Voters: 286. You may not vote on this poll | |||
09-25-2006, 07:17 PM
#136 | |
"Cool" Aid!
Oddometer: 41,500
![]() Jim
09-25-2006, 08:39 PM
#137 | |
Oddometer: 5,308
11-16-2006, 01:55 PM
#138 |
Bored Track Racer
Oddometer: 544
Returning from a ~5000Km trip I noticed a high pitch wine, which at first I thought was just a tire-noise echo from the Jersey barriers. Sound gets much louder on deceleration. Drove another 250 KMs to home.
Found a lot of black fuzz on the mag plug, with some very fine silver wafers (assume peeling chromium from the balls or races). No discernible play at 6 & 9, nor roughness when rotating the wheel. Put in fresh gear oil and did a spirited 100 Km yesterday. Whine seems louder particularly on deceleration from 100 down to 75 kph. It is hard to pin point the location of the noise with a helmet on, it seems to be emanating from the entire bike. Checked the mag plug and once again covered with black fuzz, but this time there are much more fine silver wafers. Still no play, but I can feel roughness. Pulled the final drive apart and the balls and races are severely spalled on the large bearing. The taper bearing appears healthy. Seals never leaked a drop. Oh well at least its close to the end of riding season for this year.
"...There are legions of marginally competent yet pseudo-functional, witless and gullible sheep like yourself polluting our gene pool, making it very difficult to be optimistic about the future of the United States. Please don't breed." toothy |
11-16-2006, 03:31 PM
#139 | |
Renegade Sickle Hound
Oddometer: 14,896
Support the AMA. |
11-16-2006, 04:05 PM
#140 | |
Registered User
Oddometer: 25,012
11-16-2006, 07:31 PM
#141 | |
Oddometer: 5,308
He changed the oil as any sane mechanic would have, to rate the amount of damage, it is a needed step to change the oil, re-run and check it again. It is how I have always done after metal is found in the oil. This is required troubleshooting with aircraft engines, from Cessna 120's thru Boeing 747's. And you might have guessed it is the maintenance manuals which suggests that proceedure. I'd bet you would have slammed him if he didn't troubleshoot it, riiight? Just tore it apart and found nothing, what a fool he would have been,,,, then. Lighten up and allow those guys who are doing anything at all, even if it is wrong, to help others find a method to figure this shit out. Since BMW hasn't positively addressed the loyal BMW owners troubles,we all really need to be suportive of each other, don't you think? |
11-16-2006, 08:02 PM
#142 |
What's that funny noise?
Oddometer: 1,012
Well, I'm sorry to hear your bearings went bad. I am glad to know it did not fail on you suddenly, in a curve, leaned over at 70mph and on the gas... That was exciting...
Just out of curiousity, how many miles on yours when it went? My GS only had 28K miles on it when it came apart without any warning. |
11-16-2006, 08:57 PM
#143 |
Another Angry Hun !
Oddometer: 660
Gear Lube
Baba, What sort of gear lube had you been using,and how often had you changed it? Thanks, you have my sympathy.DB
Patience: A minor form of despair disguised as a virture. Ambrose Bierce |
11-16-2006, 09:55 PM
#144 | |
Bored Track Racer
Oddometer: 544
We used the same procedure on helicopter gearboxes....if you can't read a part number on the chunk, then it'll make it back to base.
11-16-2006, 09:56 PM
#145 | |
Bored Track Racer
Oddometer: 544
11-16-2006, 10:00 PM
#146 | |
Bored Track Racer
Oddometer: 544
11-16-2006, 10:10 PM
#147 | |
Bored Track Racer
Oddometer: 544
The last change was the first time the fluid actually showed a colour change.
11-16-2006, 10:21 PM
#148 | |
Oddometer: 14,896
Support the AMA. |
11-16-2006, 10:32 PM
#149 | |
Bored Track Racer
Oddometer: 544
I really didn't take any offense with his question Gus, and you are correct in identifying my troubleshooting as standard aviation procedure. Maybe we should start a SOAP program for final drives ?I was hoping someone would pick up on that the pending bearing failure is audible before any radial play, roughness, or seal leakage. I wonder if this is unique to my case ? Quote:
11-17-2006, 06:14 AM
#150 | |
Another Angry Hun !
Oddometer: 660
http://www.schaefferoil.com/products.html
