View Results: How did your failure happen?
No notice at all ,left me stranded on the spot. 66 22.37%
Noticed a problem ,but was able to ride back to civilazation 107 36.27%
Just checked and felt fine ,but died a few hundred miles later 17 5.76%
Noticed problem,rode bike hundreds of miles without total failure 105 35.59%
Voters: 295. You may not vote on this poll
Old 03-02-2010, 08:59 AM   #241
Disco Dean
Disco Dean's Avatar
Oddometer: 1,276
2006 GS 1200 Adventure. (built before Feb 06 - the needle bearing upgrade in August 06) has smaller needle bearing.
47,000 kms
Slight vibration - when no load. No leakage to speak of (I replaced the right rear seal at 35k after slight sweating around seal.
Pinion gear - movement - lateral and along the axis.
Removed - pinion and pinion needle bearing shot - ground down races and severe gauling/pitting.
The rest still looks good. Teeth look fine and wearing where they should - I will double check that to see if the shims are correct from the factory. Along with the gear lash for the ring gear.
Big bearing very tight - no rear wheel play - slightly less than tolerance specs even.
I will be replacing the needle bearing and seals.
Thinking of selling the rebuilt item and buying an 09 FD with all the upgrades.
Dean
youmoveyou
As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?
Disco Dean is offline   Reply With Quote
Old 03-02-2010, 12:07 PM   #242
August West
Wharf Rat
August West's Avatar
Oddometer: 552
[quote=Disco Dean]
No rear play - slightly less than tolerance specs?? Are these two statements contradictory or am I missing something?
I have a bit of play when I grab the rear wheel at 3 and 9. '04 1150 GS. The local dealer said it seemed within spec. I thought any movement was bad. Is some wheel movement within spec? Perplexed GS noob.
A.W.
August West is offline   Reply With Quote
Old 03-02-2010, 01:52 PM   #243
Disco Dean
Disco Dean's Avatar
Oddometer: 1,276
[quote=August West]
A.W.
Just my ineptitude...
On the 1200gs you can expect up to 1 mm tolerance (that is the combined + and -) at the rim when measuring. That is the normal range. I do not know what the 1150 should be but you can feel movement (1mm is quite a lot to feel) and it will still be in spec (on the 1200gs)
Maybe someone else has the spec for the 1150...
youmoveyou
Old 03-02-2010, 03:07 PM   #244
Wallowa
Oddometer: 5,409
Keep Us Posted on '09 FD
[quote=Disco Dean]
If you go for an '09 FD...please post the installation and costs..thanks!
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline   Reply With Quote
Old 03-02-2010, 05:20 PM   #245
Ken Fritz
Oddometer: 1,017
give us non-failures an option
+1 for an option for those of us who keep on going and going and going without FD failures. Only 40,000 miles on my 1150GS, but virtually all of it hard riding in all kinds of weather (but not much deep water crossing stuff) - heavily loaded solo or loaded two-up And no sloppy wheel or leaking seals. Just changed the FD oil again and it was dirty but without any discernible metal using bright light, a strong magnet and a filter to trap anythign else I may have missed. I've changed the FD lube at about 11000-12000 intervals after the first change at 6000 miles and the result has been consistently uneventful. I wish you all the same good fortune. YMMV
Ken Fritz screwed with this post 03-02-2010 at 05:36 PM
Ken Fritz is offline   Reply With Quote
Old 03-03-2010, 07:14 PM   #246
rinho
Rinho Féroce
rinho's Avatar
Location: back in France but Soul still in North America
Oddometer: 1,117
I'm rebuilding mine
80.000 Km
Leaking but no bearing damage
However, you can feel something when the big one spin and the tapered have some wear.
I'm replacing everything and want to have the perfect shimming
(play at the wheel was feelable, but less than 1 mm).
http://rinho.org/gallery2/main.php/m...rs/finaldrive/
Sans un sou mais plus riche qu'avant
rinho is offline   Reply With Quote
Old 03-04-2010, 01:16 PM   #247
Paul Mihalka
Old Fart
Paul Mihalka's Avatar
Oddometer: 877
I think I got a lucky deal. My '05 R1200GS has 99k miles. Original rear drive with no problems, no leaks, just a little bit of play at the wheel rim.
Browsing ebay I found a rear drive, by seller less than 10K miles. Ebay, but seller was BMW Santa Cruz County. Recommended by seller to change pivot bearings. This unit is on the bike and the old one will go to Anton for full refreshment. The ebay drive was $200.
Paul Mihalka is offline   Reply With Quote
Old 03-05-2010, 06:44 AM   #248
g-bike
beerdrinkin'fuckaholic
g-bike's Avatar
Oddometer: 249
05 1200gs, noticed pinion shaft play and noisey when turning by hand while replacing drivehaft at 93,000. Shipped FD to San Jose BMW for an overhaul at $735.00 to replace all bearing and seals. While waiting for the 05 FD to be returned I ran an 07 FD I bought off e-bay years ago. Problem was, no speedo or ABS because hole for speed sensor is different on the 07. Just used my GPS for a speedo and ran it anyway until my original came back. And no, a 07 speed sensor does not jive with 05 'putor. San Jose did a great job, all is well now and the restraining order for the UPS man has been lifted.
Andrew
03 1150GS ADV (Stepping Back & Going Forward)
05 1200GS (110,000 Mile Deerslayer) RIP
g-bike is offline   Reply With Quote
Old 03-05-2010, 01:25 PM   #249
Lord Vader
Lord Vader's Avatar
Oddometer: 195
Got a 06 GSA 1200
got now 52400 miles and it just eaten the 4th final drive
first at 13k,26k,38k and now at 52
anyone can beat that???
Lord Vader is offline   Reply With Quote
Old 03-05-2010, 01:32 PM   #250
Disco Dean
Disco Dean's Avatar
Oddometer: 1,276
Originally Posted by Lord Vader
Got a 06 GSA 1200
I just sighed my guts right out of stomach and all over the FD oil covered floor...:c ry
youmoveyou
Old 03-05-2010, 04:08 PM   #251
Ken Fritz
Oddometer: 1,017
Pissed Ouch!
Got a 06 GSA 1200 -got now 52400 miles and it just eaten the 4th final drive
It's all about the ride. Shees! Sorry about all that hassle!
Old 03-06-2010, 08:09 AM   #252
Wallowa
Oddometer: 5,409
Damn!
Got a 06 GSA 1200
Hey LV...this really sucks..any WAGs why you have lost so many FDs?
"In Wallowas"
Old 03-06-2010, 03:10 PM   #253
leftystrat62
leftystrat62's Avatar
Oddometer: 999
Originally Posted by Professor Fate
That is the actual number on the bearing. The BMW part numbers are: Bearing- 33121468899 The seal # 33121241938 O ring # 33111451182
Do these #'s fit all models -I have a 09' GSA
leftystrat62 is offline   Reply With Quote
Old 03-06-2010, 04:13 PM   #254
Gravehunter
Gravehunter's Avatar
Oddometer: 753
Got a 06 GSA 1200
holy crap! Wouldnt that qualify you for the lemon law? (more than 3 times the same problem)
2005 BMW 1200GS
Gravehunter is offline   Reply With Quote
Old 03-06-2010, 06:21 PM   #255
kelsokid
Where to next
kelsokid's Avatar
Oddometer: 275
Nah, final drives are regarded as consumable items.
Never, never, never give up (W. Churchill)
2001 1150GS
1998 Ventus 2AX
1994 DR350
kelsokid is offline   Reply With Quote
Times are GMT -7.   It's 12:02 PM.
