View Results: How did your failure happen?
No notice at all ,left me stranded on the spot. 66 22.45%
Noticed a problem ,but was able to ride back to civilazation 107 36.39%
Just checked and felt fine ,but died a few hundred miles later 17 5.78%
Noticed problem,rode bike hundreds of miles without total failure 104 35.37%
Voters: 294. You may not vote on this poll
Old 12-28-2010, 06:55 AM   #271
Quetzal
Guatemalan Import
Quetzal's Avatar
Oddometer: 462
Take it to the dealeship, warranty should still cover it....
I had a similar problem with mine with 36K+ miles on it, it was a little over the warranty limit but they gladly agreed to repair it free of charge....
Good luck!
Quique
BMW R1200GSA
BMW S1000RR
'A good traveler has no fixed plans and is not intent upon arriving.' - Lao Tzu
Quetzal is offline   Reply With Quote
Old 12-28-2010, 10:53 AM   #272
podio
podio's Avatar
Oddometer: 119
Thanks, mine is a 2007, I'm sure the warranty has expired, but I'll try.
podio is offline   Reply With Quote
Old 12-28-2010, 01:33 PM   #273
Unca Fud
nrpetersen
Unca Fud's Avatar
Oddometer: 246
2005LT w 16000 miles. I saw a sharply incresed rate of debris collection on the magnet a week ago & have decided to do a pre-emptive rebuild rather than risk a 3000 mile trip next summer.
Unca Fud is offline   Reply With Quote
Old 12-28-2010, 04:09 PM   #274
cjack
cjack's Avatar
Oddometer: 855
That seal is...
33117679864, about $28. I think that is a bit harder to replace than the outside one...and it could be the big "sealed" ball bearing that has spun it's grease out instead of the seal. You'll have to inspect all that to be sure.
Anyway, the proper refill is 180 cc.
09Shaft seal80X100X9133117679864$28.25
My other bike is a BMW
Jack
RA & MOA #224
cjack is offline   Reply With Quote
Old 12-31-2010, 08:00 AM   #275
podio
podio's Avatar
Oddometer: 119
Thanks cjack, I'll inspect the bearing and replace if necesary. I'll post some photos for future reference.
Old 01-31-2011, 10:53 AM   #276
veloct
veloct's Avatar
Oddometer: 41
Latest Victim - No early warning
2003 1150 GS Adventure, 26K miles, probably 10 short creek crossings where the hub was submerged since I've owned it.
Mine came on all of a sudden, riding 2 up down a back road. I had no warning at all. We rode 80 miles the day before, at speeds up to 90 mph, with no uncommon vibrations in the pegs. All of a sudden, I heard and felt vibration, and it felt like the back tire was on severely grooved pavement. It also felt like the brake rotor was warped, causing intermittent drag on every rotation of the rear wheel.
Luckily I was only going 20 mph when it happened, and I easily maintained a controlled stop. But had it happened doing 80 and leaning into a corner while flirting with the limits of traction, things could have been much different. I'm not sure if the effects would have been so pronounced at a higher speed, and quite frankly, I hope I never find out.
Also worth mentioning, there is no play 9 to 3 or 12 to 6 with the back tire off the ground, but when I spin the wheel, there's an intermittent grinding sound.
I broke out the AAA card, and had it towed home. That afternoon, I noticed a small puddle of final drive oil under the right side of the rear tire.
Now I have to decide whether to do the work myself, or have BMW do it. I am confident I can perform the bearing R&R, but since it failed with such low mileage, I'm concerned that it may need re-shimming and I can't find a DIY procedure to check the tolerances.
Can this be done with a feeler gauge, or is there some "special tool" required? Better yet, is this a job better suited for a pro? I'd like to be confident that it won't happen again, at least for another 26K miles.
veloct is offline   Reply With Quote
Old 01-31-2011, 03:16 PM   #277
lemieuxmc
lemieuxmc's Avatar
Oddometer: 3,360
Fine German Engineering
Yep... them new BeeYemDubbaYas sher iz uh lawt betteren them Ol' Airheads!
Say yung feller, yewever gunna moovuponna Harley Davisson wun of theez dayz?
Getcha a guud traydin d'yeal downat Billy Bobz Sickle Shop
lemieuxmc is offline   Reply With Quote
Old 01-31-2011, 03:20 PM   #278
QED
Oddometer: 355
Wicked
80k miles and counting, no problems.
QED is offline   Reply With Quote
Old 01-31-2011, 07:13 PM   #279
veloct
veloct's Avatar
Oddometer: 41
Update - Dealer Quote
The local dealer quoted $924 ($600 labor and $324 parts) for the shaft bearing, axle bearing, shaft seal and o ring gasket. That's barring any further damage they may find. A brand new Final Drive would run $1600 ($1400 parts plus 2 hours labor). Either way, they'd warranty the work for 2 years parts and labor.
I jokingly asked him if the warranty would cover "recovery costs". It doesnt.
From what I've read, the parts run about $150, so a bit confused as to what I need. Do you normally replace the Axle bearing as well as the shaft bearing?
This sucks. Anyone know a good attorney for a class action suit?
Old 01-31-2011, 07:55 PM   #280
AZ_ADV_RIDER
Demons In My Helmet
AZ_ADV_RIDER's Avatar
Oddometer: 815
I wonder what model year(s) seem to be more susceptible to FD failure?
- Mark
The road to enlightenment is not paved.
AZ_ADV_RIDER is offline   Reply With Quote
Old 01-31-2011, 08:02 PM   #281
(none)
poser
(none)'s Avatar
Oddometer: 2,620
If you are expecting dealer part prices to be the same as internet part prices, you have a few things to learn.
Also, you want to sue BMW over a 8 year old bike, 5+ years out of warranty? Ok, have fun.
Current:
R1150GS
GN400
LC80
JK Rubi
(none) is offline   Reply With Quote
Old 02-05-2011, 02:58 PM   #282
veloct
veloct's Avatar
Oddometer: 41
Shim Measurement
I found a video detailing the main bearing removal/replacement procedure, including measuring for correct shim thickness. http://www.bmwlt.com/uploads/lt_final_drive_rebuild.wmv
Also, here's a thread from a guy who upgraded the OEM bearing with an Angular Contact bearing. He paid $750 for a pair of them. - http://www.horizonsunlimited.com/hub...failures-38600
Old 02-05-2011, 07:45 PM   #283
bzrider
bzrider's Avatar
Oddometer: 2,628
Originally Posted by Lord Vader View Post
Got a 06 GSA 1200
got now 52400 miles and it just eaten the 4th final drive
first at 13k,26k,38k and now at 52
anyone can beat that???
ITS GOT THE WRONG SHIM IN IT .the crown bearing is gat to much preload it is a bearing that requires none the tapered bearing is loaded ,but over preloaded it will burn up the crown bearing,
bzrider is offline   Reply With Quote
Old 02-05-2011, 07:49 PM   #284
bzrider
bzrider's Avatar
Oddometer: 2,628
this method works but if you dont keep the housing good and hot when you take the measurement you can get a false reading make sure you take it multiple times until you get he same measurement .05 mm of and the bearing will fail early.
Old 04-05-2011, 02:18 PM   #285
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,217
In the parking lot of a hotel in Alcoi, Spain. Got the old one pulled off at a shop in town. New bearing
promised in Alicante tomorrow morning.
Oil changed 2.000 km ago with no sign of problem.
The bearing lasted 100.000 km.
High velocity travel with passenger and lots of (her) luggage is the norm.
Two days delay because I didn't have the bearing with me, but must wait for it to arrive.
No big deal.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Times are GMT -7.   It's 10:00 PM.
