View Results: How did your failure happen?
No notice at all ,left me stranded on the spot. 66 22.37%
Noticed a problem ,but was able to ride back to civilazation 107 36.27%
Just checked and felt fine ,but died a few hundred miles later 17 5.76%
Noticed problem,rode bike hundreds of miles without total failure 105 35.59%
Voters: 295. You may not vote on this poll
Old 07-20-2005, 08:10 AM   #31
Professor Fate
Hand crafted
Professor Fate's Avatar
Oddometer: 123
Originally Posted by BiG DoM
Is this a BMW part number? FAG etc???
That is the actual number on the bearing. The BMW part numbers are: Bearing- 33121468899 The seal # 33121241938 O ring # 33111451182
I've been through more hard times than the jews and Charlie Brown put together--Homer Simpson
Professor Fate is offline   Reply With Quote
Old 07-20-2005, 09:56 AM   #32
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,643
61917, it's the actual bearing number -no matter who manufactures it, it'll have that number - even the bearing sold by BMW will have that number on the bearing.
It's a world wide standard -
the C3 number is the tolerance allowed -
here in the UK, it costs £28 from BMW dealers -
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 07-20-2005, 12:01 PM   #33
OUtback UFO
GLOW IN DARK SPACEINVADER
OUtback UFO's Avatar
Oddometer: 2,595
Originally Posted by OUtback UFO
86,500 on a 02 1150 and no problems... still rockin strong..
okay to quote and then shot my self in the foot.. at 87,003 the drive bearings and pinon bearings went out at 3am in the middle of UT... total cost of repair at LV BMW (80$ per hour labor) 929.72$... with the towing to LV by AAA of $445.00... was a very expesive business trip to LA this last weekend...
I had a good 50miles of rough riding.. thought at first my front brakes were causing problem... so i rode to the next fuel up on my route to find the drive seal had gone and final drive fluid over everything... luck i did not loose the gears...
From out of a dream I rode to beyond the Horizon. Got Adventure? The Zen Gear
One Meteior Crater surrounded by a lot of roos, emus, Yowies, drop bears and one major flood in the driest desert on Earth... There still was a bottle of red with dinner.
IBA#13157 BB1500 SS2000
Die Hohen Berghunde Agent X
My Motorcycling fine art Books are avalible at Blurb.com, click below.
159059 ss ed. 159059 sl ed. and Motorcycling to Aesthetics:Australia
OUtback UFO is offline   Reply With Quote
Old 07-20-2005, 01:46 PM   #34
bemiiten OP
League of Adventures
bemiiten's Avatar
Oddometer: 4,969
Hey, At least you can vote in the poll now! Did LV BMW replace the bearings or the whole final drive for $929.00
bemiiten is online now   Reply With Quote
Old 07-20-2005, 02:15 PM   #35
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,668
I'm wondering if I should buy these parts (in England), and just carry them around in case....
Gracie's Gold
Lobby is offline   Reply With Quote
Old 07-20-2005, 03:24 PM   #36
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,465
Add me to the list of failures.
I am at the MOA and the FD on my 99 GS is rumbling badly and I need a new one! Any help?
Jim
Old 07-20-2005, 03:39 PM   #37
Professor Fate
Hand crafted
Oddometer: 123
Jim
Can anyone tell you if its just the main bearing or the whole FD that's bad?
Old 07-20-2005, 03:50 PM   #38
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,643
Jim
if it's rumbling, chances are it'll be the crown wheel output bearing -
you can fix this on the road - you need bearing 61917 C3, if the seal isn't leaking, you don't have to replace it - and look back in this thread, all you need to know on how to fix it in an emergency -
www.gsshop.biz
Old 07-20-2005, 03:59 PM   #39
bemiiten OP
bemiiten's Avatar
Oddometer: 4,969
BMW part# for crown bearing that measures 85x120x18 is 33121468899. The seal is 33127663482 list is $124.00 and$18.70.
Old 07-20-2005, 05:01 PM   #40
OUtback UFO
Oddometer: 2,595
That is for the labor and bearings... turned into 570 in labor since the pinon bearings need to be replaced... they found one final new final drive for 1100$ or they would have to back order it... i did have to pay a good 40$ on over nighting the stuff... there was no reason to replace the entire thing with a mutiple of breaking other issues...
Old 07-20-2005, 05:02 PM   #41
OUtback UFO
Oddometer: 2,595
Thats what is showing i paid...
Old 07-22-2005, 03:02 PM   #42
enduro-ince
dirtslave
enduro-ince's Avatar
Oddometer: 5,123
Alright now what?? I took mine apart to inspect bearing because of a slow oil leak. These bearings seem fine to me and the seal seems fine as well.
Could it be the O-ring? Seemed a little flimsy to me. Everything was clean as a whistle inside the housing.. Is there not supposed to be oil beyond the seal for the bearing. Meaning, is the O ring the final sealing point for final drive oil??
enduro-ince is offline   Reply With Quote
Old 07-23-2005, 03:50 PM   #43
Professor Fate
Hand crafted
Oddometer: 123
There is indeed oil being held in by the main seal and by the o ring. You would be able to see the oil leaking out of the seal when you take the wheel off. The o ring would leak around the two halves. My bearing didnt seem bad either, but tit was a bit loose. Be sure to lube the oring up and where it slips on. I used vaseline.
Old 07-23-2005, 06:13 PM   #44
enduro-ince
dirtslave
Oddometer: 5,123
So are you saying the bearing being just a little loose caused the seal to fail?
I just finished putting on the new seal. I'm wondering what caused the seal to fail because my bearings seem ok. Time will tell and I'm riding sunday...heres hopin...
Thanks for the help!!
Old 07-23-2005, 06:32 PM   #45
Professor Fate
Hand crafted
Oddometer: 123
I'm thinking that maybe when the bearing has enough wear and I am loaded heavy the wheel sits more crooked and oil mayhave an easeir time getting past the lip of the seal when the wheel is cocked. Mine dripped the day I carried a heavy load up a bumpy mountain road.
Times are GMT -7.   It's 04:30 AM.
