| View Results: How did your failure happen? | |||
| No notice at all ,left me stranded on the spot. |
64 | 22.38% |
| Noticed a problem ,but was able to ride back to civilazation |
103 | 36.01% |
| Just checked and felt fine ,but died a few hundred miles later |
17 | 5.94% |
| Noticed problem,rode bike hundreds of miles without total failure |
102 | 35.66% |
| Voters: 286. You may not vote on this poll | |||
07-26-2005, 08:02 AM
#61 | |
get in or go in
Oddometer: 12,920
agreed...I posted on this topic months ago right as I purchased my 04 advif we want more feedback, perhaps this should get posted in Jomomma more piss n vinegar there
.... wait til you get younger to chase your dreams...... |
07-26-2005, 10:30 AM
#62 |
bavarian
Oddometer: 1,741
Those pics about the possibiity of a roadside repair of the bearing are just great! Thank you.
R1100 RT - 93.000 kms and no probs 2002 GS - 35.000 kms and no probs
R 1100 GS K75C DR 350 |
07-27-2005, 08:17 AM
#63 | |
Oddometer: 3,479
As for the price range, just take a look at Dennis Kirk's webpage a little. $200 for a top-of-the-line chain and sprocket set. I know you're pretty frugal, though, so click down to the economy chains with the cheap-ass o-rings that don't last for shit...You have to go for the close-out priced POS's to get down to $37. Most of them are around $60-$90. Right about what I said. A nice D.I.D chain...about $171--even more than the range I mentioned. As for the mileage, that's obviously going to have a huge variance as to when you'll need to swap out. But after googling around a bit, I'm pretty sure I'm right on target with my estimates...particularly in an adventure-riding crowd. The numbers posted: 10-13kmi...12.5kmi...13kmi...15kmi. The truth is you can eke out more with easy riding and routine maintenance, but trusting a ragged out chain is basically identical to trusting a ragged out driveshaft. Both will eventually get you stuck when you don't want to be. Which gets me back to the original point...given the choice between a driveshaft that might flake out on me somewhere north of 40kmi versus chains that flake out somewhere north of 12kmi, I'll take the driveshaft. DriveShaft screwed with this post 07-27-2005 at 08:42 PM |
07-27-2005, 08:30 AM
#64 |
R1200GS
Driveshaft, good point. My only issue is that the degree of raggegness can easily be seen on a chain. Seems the older (11xx) FD also had some built in inspection/maintenance. The new FDs on the r12 do not have a drain plug, nor do thay have the magnet to collect metal.
These units should not be sealed for life, and there should be a way to inspect (easily) so one can plan. If I missed this for the R12, please advise. Cheers PS> I know that the fluid can be swapped, but what about metal bits, and if the dealer finds out I had the unit opened up should the FD later fail, have I voided the "lifetime" warranty?
Have router, will split lanes for food. |
07-27-2005, 08:33 AM
#65 |
Oddometer: 3,241
Before you start calling people names I suggest you get your facts right! You can apologize all you want for the roundel but other people don't. Your lowball cost on the final drive repair when it breaks by the side of the road, is towed to a BMW dealer is so far off the mark so the rest of the blather gets discounted right away.
07-27-2005, 08:44 AM
#66 | |
Oddometer: 3,479
And final drive repair costs have been enumerated by many others on this thread. They're all pretty much in agreement. The cost of towing and such...those items will hit you whether you're packin' a chain or a shaft. Sorry it irks you so much. |
07-27-2005, 09:02 AM
#67 | |
Oddometer: 3,479
Those guys really put a stake in the ground with the R12, and it really rubs me wrong, for obvious reasons. I'm not buying the whole "lifetime warranty" either--not with their track record. It's going to take a long burn-in time to make me a believer on that. So, I'll reserve my judgement till...say...2007. |
07-27-2005, 10:14 AM
#68 | |
space duck
Oddometer: 143
:grinner ) |
07-27-2005, 11:57 AM
#69 | |
Oddometer: 3,479
07-27-2005, 12:09 PM
#70 |
space duck
Oddometer: 143
Thanks. Does anybody know if anything has been changed in the design of the FD that might reduce the failure rate? Things such as less angle changes between the engine and the wheel.
07-27-2005, 12:32 PM
#71 | |
R1200GS
The upside is the same FD is used on the K1200r, which has like 159 HP. Seems if there is a weak link the K-boys will be among the first to know. FWIW, I have volunteered to maintain a R1200 FD FaQ. The problem is that while I can write/organize, I have no real skilz/knowledge WRT to FDs.
07-27-2005, 01:10 PM
#72 | |
Funslinger
Oddometer: 7,744
3x in 31k? Ouch! Did they give any idea as to what was wrong? There's a part of me that wonders if the seal was replaced, without the underlying cause being treated- but perhaps that's just wishful thinking. All I gotta say is that after checking the replacement procedure, it seems to me that taking some time every 10 or 15k to check out a final drive is acceptable to me; well, TBH, I would say "it's not the end of the world". I would prefer such things NOT need be done- but if they are, then so be it. After all, people in this world deal with desmodromic valve adjustments, chain and sprocket replacement (as has been pointed out), wheel bearing replacement- so I guess this might simply be a cross to bear. |
07-27-2005, 01:31 PM
#73 |
Funslinger
Oddometer: 7,744
I re-read my post, and I want to add:
I hope BMW DOES address this issue- and either isolate the cause, or make sure bearings are inexpensive. |
07-27-2005, 01:54 PM
#74 | |
space duck
Oddometer: 143
), and that seems the recipe for the seal failure.I'll know more on friday... cxwing screwed with this post 07-27-2005 at 02:26 PM |
07-27-2005, 02:04 PM
#75 | |
SWM Adventuer
Oddometer: 4,153
