Old 03-19-2013, 09:02 PM   #1
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
FCR Durability?
For the folks here running FCRs, are there any issues with durability or reliability? Are they known for any particular parts breaking?
I figured you guys would know.
<<This is my Airhead, there are many like it, but this one is mine>>
My "Orange Snappy Club" Membership Photo
Les_Garten is offline   Reply With Quote
Old 03-20-2013, 12:14 AM   #2
BergDonk
BergDonk's Avatar
Oddometer: 3,840
The only issue I'm aware of is that the anti rattle plate on the slide and fatigue and crack. The one on the MKI I fitted to my 501 Berg did this, but I caught it in time. The MKII on my DR650 shows no issues with 40,000 kms. My 650 Berg's MKII also looks fine at 260 hrs. I understand that the rollers on the slide can wear in the carb body, but if they are turning OK, should be OK. My carbs show no sign of slide or roller wear. Great carbs once setup.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 03-20-2013, 12:49 AM   #3
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
That sounds like what I was hearing.
Old 03-20-2013, 04:13 PM   #4
BergDonk
BergDonk's Avatar
Oddometer: 3,840
This is a pic of my MKI plate. I bent it deliberately where it cracked. Hard to spot in the formative stages.
I suppose the other durability issue, or potentially anyway, is that the MKI has an exposed AP shaft, whereas the MKII is all inside. Both mine are all OK though.
From UHE:
Throttle plate cracks
The throttle plate mounted on the back of the slide cracks in a circular motion around the dished depression in the design. The plate cracks because it can vibrate after a very large rubber ring has worn from the fluttering and from then on you can hear the plate 'clattering' likle a a handful of dominos on a kitchen table. If you replace the inexpensive rubber 'O' ring at this point it's a good cure and the plate will last interminably. You can make the plate clatter at anytime by holding your hand over the end of the silencer........!
http://www.husaberg.org/wiki/index.p...le=Carburation
Old 03-20-2013, 05:07 PM   #5
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Thanx for the info and the link!
Where is the best place to buy a few of these reasonably?
Old 03-20-2013, 05:11 PM   #6
davesupreme
grand poobah
Oddometer: 1,645
i get parts here, good place.... parts are hard to get, you gotta go thru a dealer, and pretty much all of them come from Sudco in ca., and they don't wanna talk to you.....
http://www.jetsrus.com/index.htm
davesupreme is offline   Reply With Quote
Old 03-20-2013, 05:20 PM   #7
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
That's who I have book marked as well. Thanx!
Old 03-21-2013, 07:11 AM   #8
Kawidad
Kawidad's Avatar
Oddometer: 4,985
Just make sure you buy the later model ones, if searching fleabay or whatnot, the early ones were troublesome. They can be distinguished by the slide assembly being straight up and down, whereas the newer/better ones the slide is angled in relation to the carb body.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 03-21-2013, 08:10 AM   #9
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Do have any links with PIX? Is this what is known as MK 1 and MK2?
Old 03-21-2013, 12:52 PM   #10
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,405
You've got that backwards. The slantbodies are the old-style.
jesusgatos is offline   Reply With Quote
Times are GMT -7.   It's 07:03 AM.
