Go Back   ADVrider > Riding > Regional forums > West – California, the desert southwest and whatever is left
Old 04-02-2013, 04:09 PM   #1
meatsack OP
Moto-idiot
meatsack's Avatar
Oddometer: 395
Ukiah Flat Track Round 1, Sunday 4/7/13
Round 1 of the Inaugural Ukiah Speedway Flat Track Series is this Sunday, 4/7/13!
Information regarding the classes and race day schedule are below:
Ukiah Speedway Flat Track 2013
Racing Classes
*NOTE* All Classes must have “Class C Traction” on the Rear Wheel Unless otherwise Noted.
OPEN DIVISIONS:
Open DTX: Any Size Wheel, Unlimited Size Engine, Unlimited Mods.
Senior: 40+ Open, Unlimited Displacement, Unlimited Mods.
Vintage Light Weight: Single Cylinder, Air Cooled, Twin Shock Chassis, 250cc Max Displacement. Pre-1980. No Front Brake.
Vintage Open: Single, or Twin Cylinder, Air Cooled, Twin Shock Chassis, Pre-1980. No Front Brake.
MINI DIVISIONS:
230 Premier: Up to 230cc Air Cooled Four Stroke Motor. Must Retain Stock Carburator. Unlimited Chassis Mods. Max Front wheel Diameter 19”. Max Rear Wheel Diameter 18”.
Vet Mini: 30+. Up to 150cc Liquid Cooled Four stroke Motor, or 250cc Air Cooled Motor. Max Front Wheel Diameter 19”. Max Rear Wheel Diameter 18”.
150 Production: Stock Bikes Up To 150cc Air Cooled Four Stroke Motor. Engine, Carburator, Airbox, Chassis, Wheels & Brakes Must Remain Stock.
Formula 125: Up To 125cc Air Cooled Four Stroke Motor. Unlimited Mods.
YOUTH DIVISIONS:
50cc Pee Wee: 50cc Air Cooled Bikes with 10” Diameter Wheels. (Note: this class can run ANY TIRE you like)
65 / 125: Up to 65cc Two Stroke Motors, Or, 125cc Four Stroke Motor.
ENTRY FEES & GATE SPECTATOR ADMISSION:
No Membership Cards are Required to race! Sign Up at the Track on Race Day!
First Race Class entry fee is $35.00. All additional Race Class Entry Fees are $25.00 per Class.
Spectator Admission is $10.00 (Children Under 12 are Free)
NOTE: 50cc Pee Wee Class races for FREE!
RACE DAY SCHEDULE:
9:00 a.m. Gates Open.
9:00 a.m.-11 a.m. Tech Inspection
10:00 a.m. Track Prep.
10:30 a.m. Practice. All Race Classes (Ideally everyone should get 2 Practice Sessions)
11:30 a.m. Track Prep.
11:45 a.m.MANDATORY RIDERS MEETING!
12:00 p.m. Heat Races. (10 laps for all Divisions with the exception of Pee Wee’s which will be 4 lap Heat Races)
1:30p.m. Track Prep. Race Staff Lunch Break.
2:00 Main Events Start. (15 Laps for all divisions with the exception of Pee Wee’s which will be a 6 lap main event)
Trophies will be handed out at the end of each main event to the top 3 finishers.
PLEASE NOTE: Ukiah Speedway is a Family oriented facility and will not tolerate Alcohol & Drug Abuse in any way shape or form.
We will also not tolerate abuse of our staff, they work long and hard hours so that you may have a fun & safer environment for your motorsports entertainment.
Please be respectful of others. Thanks for Coming Out!
For your Convenience, Food Concession will be open at Each Race Day & Race Fuel will be available as well.
Michael M.
"The ninja got a bit fruity on me down the corkscrew." -Tom Sykes, Laguna 2014
10' Husaberg FE390, 05' ZX636R TrackBike, 00' XR680RR SM
04' CRF230 Flat Tracker, 02' CRF150F, 66' CB160
meatsack is offline   Reply With Quote
Old 04-02-2013, 04:38 PM   #2
meatsack OP
Moto-idiot
meatsack's Avatar
Oddometer: 395
UKIAH SPEEDWAY FLAT TRACK MOTORCYCLE
COMPETITION and TECHNICAL REGULATIONS 2013
Please Note-
These Rules are intended as a guide for the conduct of the sport. The Race director / and or referee shall be empowered at any time to permit deviations from any specifications herein or to impose any further restrictions or changes that in their opinion do not alter the minimum acceptable requirements. Any interpretation or deviation of these rules is left to the discretion of the officials. Their decision is final.
Technical & Safety Regulations-
All race Entrants are required to have their motorcycle pass Technical Inspection prior to entering the racetrack. It is the riders responsibility to come to Technical Inspection with the intent of passing. The Racer or designated crew member / mechanic must bring the motorcycle to the tech inspection area before entering the race surface. Any Rider caught on the racetrack without proper authorization may be asked to leave. Always inspect your bike before coming to tech.
1) All Drain Engine Drain Plugs must have some sort of Silicone Sealant (gorilla snot) Placed on it to prevent backing out. (safety wire also acceptable)
2) No Leaking Fluids of any kind: Oil, Water, or Fuel. No Loose Parts.
3) No Anti Freeze in the cooling system: Water Wetter, or equivalent ok. No substitutes.
4) Number Plates must be securely attached and easily read from 50’ away. At all racing events, the rider’s motorcycle shall be fitted with 3 number plates, each securely fastened to the machine. At the discretion of the head scorer / or Referee, a machine whose numbers are not legible may not be scored.
5) Remove Kickstand, and any lights (or have them securely taped over). Mini Classes may retain kickstand if it is secured.
6) Brakes & tires in Race Ready condition; No loose spokes, or damaged tires.
7) Throttle, Control Levers & pedals must operate freely. (Throttles must have positive return!)
8) Full Face Helmet, Eye Protection, Gloves, Boots & Long sleeves are REQUIRED.
Ukiah Speedway Staff Member may require a rider to leave the track and have his bike
re-inspected if the Bike does not pass technical requirements.
Fuel Regulations-
All Brands of Gasoline are Legal. Race, Pump, any octane rating. Leaded or Un-Leaded.
NO additives…NO Alcohol…NO Nitro or Methane. (Race Fuel is available Trackside).
Michael M.
Old 04-10-2013, 09:41 AM   #3
meatsack OP
Moto-idiot
meatsack's Avatar
Oddometer: 395
Round 1 Results
Here are the results from Round 1 of the Ukiah Speeday Flat Track Series 4/7/13
Position Number Name Points
Open DTX
1st 90g Chris Baker 25
2nd 61 Kevin Keeran 22
3rd 322f Forress Kuecker 20
4th 31 Ted Tamagni 18
5th 169 Hank Wiedmann 16
6th 93v Beau Thompson 15
7th 372h Nicholas Garner 14
8th 11x Bobby Ingle 13
9th 35 Max Capps 12
10th 5 Chris Geilfuss 11
Senior
1st 90G Chris Baker 25
2nd 31 Ted Tamagni 22
3rd 56x Jimmy Clarke 20
4th 5 Irving Kenzy Jr 18
5th 42 Brian Pecore 16
6th 5 Chris Geifuss 15
7th 420F David Tishma 14
9th 58 Jim Cole 12
10th 201 Brad Raymound 11
11th 475 Dirk Stanley 10
12th 25 Armando Miranda 9
13th 954 Mark Topping 8
14th 35 Max Capes 7
15th 74 Ralph Ribera 6
1st 48f Steve Beretta 25
2nd 49 Logan Orsini 22
3rd 57 Jim Bruno 20
4th 954 Mark Topping 18
5th 759 Jimmy Miller 16
Vintage Open
1st 925h Gary Durbin 25
2nd 56x Jimmy Clarke 22
3rd 76n Tim Niles 20
4th 48f Steve Beretta 18
5th 49 Logan Orsini 16
6th 954 Mark Topping 15
7th 201 Brad Raymond 14
8th 39U Ron Kilby 13
9th 5 Chris Geifuss 12
10th 125g Pat Moore 11
230 Premier
1st 155g Michael Mannion 25
2nd 42 Brian Pecore 22
3rd 25 Armando Miranda 20
4th 67f Rick Kerrigan 18
5th 80 Rob Prather 16
6th 58 Jim Cole 15
7th 11 Kieth Russell 14
8th 156 Steve Coscarelli 13
Vet Mini
1st 42 Brian Pecore 25
2nd 155g Michael Mannion 22
3rd 67F Rick Kerrigan 20
4th 25 Armando Miranda 18
5th 58 Jim Cole 16
6th 156 Steve Coscarelli 15
150 Production
2nd 238 Tony Monteleor 22
3rd 101f David Larkin 20
4th 280 Chris Gray 18
50cc Pee Wee
1st 8 Clancy Williamson 25
2nd 120G Jesse Debaca 22
3rd 52 Joey 20
65/125
1st 131 Brandon Weller 25
2nd 1 Ava Williamson 22
Michael M.
Old 04-10-2013, 01:30 PM   #4
meatsack OP
Moto-idiot
meatsack's Avatar
Oddometer: 395
The Ukiah Daily Journal ran a story about the opening round on 4/7/13.
Read it here:
http://www.ukiahdailyjournal.com/ci_...races-at-local
Michael M.
Times are GMT -7.   It's 06:28 PM.
