Go Back   ADVrider > Riding > Regional Forums > Canada
Old 04-11-2013, 09:46 AM   #76
willys
willys's Avatar
Oddometer: 2,904
IF it doesn't have an engine powered by gasoline it doesn't belong in the garage!!! Them's the rules!!!
It's half my fault too....I took the snowblower and put it back in the backyard.......thinking.....ok, well maybe not thinking.....augh!
willys is offline   Reply With Quote
Old 04-11-2013, 10:18 AM   #77
GP640
GP640's Avatar
Oddometer: 3,447
IF them's the rules, I'm going to need a bigger shed for the canoe, kid's bikes,
our bikes, snow tires.....
I can still fit my full size truck in there so it'll take more stuff with wheels before
any of the non motorized stuff gets parked elsewhere.
GP640 is offline   Reply With Quote
Old 04-11-2013, 01:25 PM   #78
gsstampeder
gsstampeder's Avatar
Oddometer: 1,086
http://www.bcsportbikes.com/forum/sh...s-I-don-t-even
A new shed you say????
Have I got a builder for you....
5 weeks in Baja
gsstampeder is offline   Reply With Quote
Old 04-11-2013, 01:33 PM   #79
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,739
Winter is supposed to be over.
There must be a major disturbance in the force, because I took the proper precaution to ensure spring:
I bought a new shovel two weeks ago. Paid full price for it, too.
You fuckers took your winter tires off, didn't you?!?
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 04-11-2013, 08:12 PM   #80
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 103,034
Snow fell in the U.S. Deep South, severe storms battered the East Coast, and International Falls, Minnesota, set a new temperature record: -46 degrees Fahrenheit (-43 degrees Celsius) on January 21. But in areas north of the United States and southern Canada, temperatures were above normal. In fact, unusual warmth forced residents of Iqaluit, capital of the Canadian territory of Nunavut, to cancel their New Year’s snowmobile parade.
This map of the United States, Canada, eastern Siberia, and Greenland shows temperature anomalies for January 9 to 16, 2011, compared to the same dates from 2003 through 2010. The anomalies are based on land surface temperatures observed by the Moderate Resolution Imaging Spectroradiometer (MODIS) on NASA’s Aqua satellite. Areas with above-average temperatures appear in red and orange, and areas with below-average temperatures appear in shades of blue. Oceans, lakes, and areas with insufficient data (usually because of persistent clouds) appear in gray.
Because this image shows temperature anomalies rather than absolute temperatures, red or orange areas are not necessarily warmer than blue areas. The reds and blues indicate local temperatures that are warmer or colder than the norm for that particular area. The overall configuration of warmer-than-normal temperatures in the north and cooler-than-normal temperatures in the south probably results from a climate pattern known as the Arctic Oscillation (AO).
The AO is a pattern of differences in air pressure between the Arctic and mid-latitudes. When the AO is in “positive” phase, air pressure over the Arctic is low, pressure over the mid-latitudes is high, and prevailing winds confine extremely cold air to the Arctic. But when the AO is in “negative” phase, the pressure gradient weakens. The air pressure over the Arctic is not quite so low, and air pressure at mid-latitudes is not as high. In this negative phase, the AO enables Arctic air to slide south and warm air to slip north.
The AO went into negative phase in the Northern Hemisphere winter of 2009–2010. The AO was in negative mode again in the winter of 2010–2011, affecting temperatures across the Northern Hemisphere as early as December 2010.
The AO can change from positive to negative mode, and vice versa, sometimes in a matter of weeks. Forecasts from the U.S. National Oceanic and Atmospheric Administration (NOAA) indicated that the AO might return to positive mode in February 2011, although the possibility of a lingering negative mode remained.
http://earthobservatory.nasa.gov/IOTD/view.php?id=48882
Old 04-12-2013, 06:24 AM   #81
Beak
Oglyarchy Hunter
Beak's Avatar
Oddometer: 3,325
Nope. I'm putting a pool in. By doing so, I have single-handedly ended Global Warming (at least for the duration of my life). As its too crappy outside now to do anything, I'm available most days to accept my Nobel.
"I haven't been paying attention, I just wanted some" - Anorak
Beak is offline   Reply With Quote
Old 04-12-2013, 06:47 AM   #82
RobbieO
Muskokatard
RobbieO's Avatar
Oddometer: 9,107
Wiarton Willy has committed suicide!!!!!!
Only a biker knows why a dog sticks his head out of a car window.
RobbieO is offline   Reply With Quote
Old 04-12-2013, 07:54 AM   #83
Lappeman
He's Down Again!
Lappeman's Avatar
Location: Lappe, ON Coldest, wettest place...well not quite!
Oddometer: 2,468
I hope it was a murder/suicide and he took the others with him!
Lappeman
Photos http://s891.photobucket.com/profile/Lappeman
Youtube http://www.youtube.com/channel/UCB-w...7m3yBQA/videos
2003 KLR 650 Alaskan Adventure
2007 YZ250F Blue Death
Lappeman is offline   Reply With Quote
Old 04-12-2013, 08:49 AM   #84
bungie4
Frostback
bungie4's Avatar
Oddometer: 501
Makie it feckin' stop!
Snowing in Sudbury right now. Again. Make it feckin' stop!
I work at the 2nd largest 911 dispatch center in North America and just spent about an hour in the station. Belleville/Quinte/Cornwall area seems to be getting the worst of it at the moment, lots of power lines down/pole fires from freezing rain.
Film at 11.
2013 FJR1300, 1984 CX650e, 2013 CRF250L - Help when you need it -http://www.assistancelist.com
bungie4 is offline   Reply With Quote
Old 04-12-2013, 08:54 AM   #85
Lappeman
He's Down Again!
Lappeman's Avatar
Oddometer: 2,468
Film at 11.
No end in sight...snowing here in Thunder Bay also. Still over 2 feet of snow in the backyard and almost 4 feet in the bush. Be amazed if the ice on the inland lakes goes out before the Long Weekend in May
Lappeman
Old 04-12-2013, 10:24 AM   #86
GP640
GP640's Avatar
Oddometer: 3,447
Snowfall warning for tonight. 5 cm forecast.
Sure, it's April but warning people about a possible 5 cm? Really?
Old 04-12-2013, 02:50 PM   #87
More_Miles OP
über-n00b
More_Miles's Avatar
Oddometer: 312
Six pages bitching about the weather... Yep we're Canadian all right!
Here, hold my beer and watch this!
Larger than life and twice as ugly!
My photos: stewie.smugmug.com
More_Miles is offline   Reply With Quote
Old 04-12-2013, 02:55 PM   #88
More_Miles OP
über-n00b
More_Miles's Avatar
Oddometer: 312
Instead of bitching, lets ride!
Don't know who it is, don't know who took the video, but I sure know WHERE it is! Looks like something I would do!
Old 04-12-2013, 03:35 PM   #89
bumper1871
Oddometer: 368
Snow in Montréal today
bumper1871 is offline   Reply With Quote
Old 04-13-2013, 08:31 AM   #90
yamalama
wet coaster
yamalama's Avatar
Oddometer: 1,294
fresh snow on the local mountains in Vancouver.
cold.
yamalama is offline   Reply With Quote
Times are GMT -7.   It's 12:27 AM.
