Old 03-20-2013, 08:33 PM   #1
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Scotts install on 2012 990 Adventure R.
Hello all. So I came home today and found a nice little present waiting for me:
Now I know there are probably a hundred Scotts threads, and that I'll probably get the standard 2nd, 3rd, and 4th posts saying "you know how to do a search, you idiot?" However, firstly, the vBulletin search engine used by Adv sucks. Secondly, yes, I used the whole Google "site:www.advrider.com scotts" etc etc etc... All to no avail. What I'm looking for is an install how-to for the above components. The setup came with a pretty stellar install manual, but I'm a bit leery about the whole drilling out of the security bolts that hold the key switch on the stock upper triple. Everything else is pretty straight forward. Anyone have some experience with getting the keyswitch off of the stock upper triple and transferring it to the Scotts upper triple. Mainly the whole drilling part? Thanks!
Old 03-20-2013, 11:44 PM   #2
dog'meat
Presidient
dog'meat's Avatar
Oddometer: 168
Eek My set came with full instruction sheet
Didn't your triple/Scott's combo came with full install booklet?
"I think of a man, and take away reason and accountability...", - Melvin Udall
KTM 990 Adventure R 2012 - KTM 640 Adventure 2007
__________________________
Mexico City, Xilitla, Aquismon, the Cave, the River and the Shangrila...
Mexico City, Cuetzalan, Nautla, Veracruz
dog'meat is offline   Reply With Quote
Old 03-21-2013, 03:58 AM   #3
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,372
Drilling the keyswitch bolts out kinda freaked me out a bit, too.
Turns out to be pretty easy, really.
I drilled a bit too deep, and into my stock clamp just a bit, but not enough to ruin it for re-use. No real harm at all, really. Drilling the heads out seemed easier than trying to hacksaw a screwdriver slot, and that would have notched the stock clamp also.
The instructions are so thorough and lengthy, that I think that added to my apprehension, and made it "seem" harder than it actually was.
It's easier than it sounds, seriously,...go for it!!
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 03-21-2013, 07:59 AM   #4
Supahflid
Wheelieless
Oddometer: 3,663
Mostly the same experience here. Just jump in and do it OP!
Edit:
Went back and looked at my Smugmug files and I only found a couple of pics that I took during installation. I doubt they will help much, but here they are:
Supahflid screwed with this post 03-21-2013 at 08:05 AM
Supahflid is offline   Reply With Quote
Old 03-21-2013, 08:03 AM   #5
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Thanks guys! I will. Yeah, I agree. The instructions are so long and thorough that it freaked me out a bit. Mainly the drilling part. I'm just going to go for it. Did you guys use a center punch to divit the security bolt heads like the manual says to do before drilling?
Old 03-21-2013, 08:06 AM   #6
Supahflid
Wheelieless
Oddometer: 3,663
Yes, you should do that; it helps center the bit.
Old 03-21-2013, 08:34 AM   #7
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,372
Exactly how I felt.
Then I got done and thought......"that wasn't so bad"
Old 03-21-2013, 08:58 AM   #8
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
GREAT info. Thanks a ton guys!! I have a killer cold right now but will be attempting install when I'm out of the woods and feeling better.
PS gotta pick myself up a center punch.
Old 03-21-2013, 09:55 AM   #9
Arzach
never too old...
Arzach's Avatar
Oddometer: 333
I just installed mine 2 or 3 weeks ago
Easy to follow instructions , but...
Anybody bothered by the rubber mount ?
It feels weird to me .
Anyone switched to hard mount ? I believe I have seen
some inserts on CJ's site .
People sail for fun and no one has yet convinced me
that it's more fun to go Slow than it is to go Fast .Dick Newick
Arzach is offline   Reply With Quote
Old 03-21-2013, 11:29 AM   #10
CRW
I dont want a pickle
CRW's Avatar
Oddometer: 805
i did mine last winter with no instructions(bought used).
just do it!
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
CRW is online now   Reply With Quote
Old 03-21-2013, 01:02 PM   #11
Supahflid
Wheelieless
Oddometer: 3,663
You don't have to do it with a center punch. Anything hard enough to make a prick mark in the head will do it, but a punch is cheap enough and probably something you should have in your tool arsenal anyway.
Old 03-21-2013, 02:56 PM   #12
DirtyADV
DirtyADV's Avatar
Oddometer: 2,199
Or instead of drilling them out you could cut a slot with a dremel tool and simply undo them with a screwdriver.
That is what I did and they came out easy think some have had trouble since they should be on there with some thread lock so if it fails drill them out.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Old 03-22-2013, 11:01 AM   #13
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Installed.
So I just installed the Scotts. Went fairly well. Took 2.5 hours. I ran into a slightly annoying snag. The ignition cable goes down on the right side of the head tube and tucks in behind a plastic cover in the frame. I looked at it and went WTF? How an I supposed to get the off? I had to take off the right side panel and loosen the right fuel tank in order to get a torx bit on the screw holding the plastic frame cover on. Once this cover was off, the ignition plugs were sitting right behind it. Below is a pic from the parts fiche showing the frame cover and where it installs. I called Scotts. They didn't know about the plastic frame cover up by the steering head. It doesn't mention this frame cover in the Scotts manual at all either:
Other than that it went pretty well. I drilled out the security bolts for the ignition, and went a bit too far. Nothing that makes the ignition unusable or unmountable. So no biggy. I just took a little bit of the metal from the ignition mount off too! I also scratched the frame a bit wile working on the bike too. Bummer. Either way, it came out good. Looks good. The factory setting on the stabilizer is WAY too stiff though. I'll have to get it out on the road and make some adjustments. Good stuff overall.
The Griz screwed with this post 03-22-2013 at 04:04 PM
Old 03-22-2013, 11:22 AM   #14
DirtyADV
DirtyADV's Avatar
Oddometer: 2,199
Earlier models dont have that plastic cover on the frame, really early did not even have the splashguard number 27.
/Johan
Old 03-22-2013, 12:04 PM   #15
Dru
Hardly an Adventurer
Dru's Avatar
Oddometer: 568
/Johan
This really is the best way to do it, if you have a Dremel. No risk in damaging the threads or going too far. I think the assumtion is that everyone has a drill and a good bit is much cheaper than a Dremel.
Dru is offline   Reply With Quote
Times are GMT -7.   It's 10:20 PM.
