Old 03-18-2013, 10:49 AM   #1
skclarey OP
Tempe trail rider
Oddometer: 61
Sand!
Wow she (2010 990) really is misbehaving in sand. The front end wants to swap in a bad way. Even with stabilizer almost fully cranked in. Any front end advice for sandy roads....
2012 KTM 500 XC-W
2014 Polaris Razer 1000
skclarey is offline   Reply With Quote
Old 03-18-2013, 10:52 AM   #2
Blue&Yellow
but orange inside...
Blue&Yellow's Avatar
Oddometer: 754
What tyres are you running? Lowered the tyre pressure? Standing on the pegs? Gaze far ahead? Easy on the handlebars and steer with your knees? Let it move beneth you? When in doubt gas it?
Blue&Yellow is offline   Reply With Quote
Old 03-18-2013, 11:01 AM   #3
mousitsas
mousitsas's Avatar
Oddometer: 2,950
No chance to get the max out of it unless you sort the front end springs. In any case, you have to really tighten your suspension, try sport settings to start with.
Old 03-18-2013, 11:17 AM   #4
CRW
I dont want a pickle
CRW's Avatar
Oddometer: 765
trottle is your buddy
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
CRW is offline   Reply With Quote
Old 03-18-2013, 11:27 AM   #5
skclarey OP
Tempe trail rider
Oddometer: 61
Tkc 80
Lowered the front tire pressure, standing up, trying to steer with legs etc, I've been desert racing for years and just cant believe how the front end wants to tank swap. Forks are headed to Superplush this week hopefully that will help.
2012 KTM 500 XC-W
Old 03-18-2013, 11:34 AM   #6
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,842
The stabilizer may be your problem. The bike wants to move around a bit and I've found too much stabilizer will work against me, and make me fall down.
Other thing to know:
Riding in sand is difficult, especially on a wallowing 500lb beast of a bike.
Yes, "gas it out" is always the over-simplified answer, and works a treat- until you have to slow down for sharp turns or (like yesterday) deep, long (miles) sections of sand whoops.
2011 White 990 Adv S
2014 500EXC Black
FakeName is online now   Reply With Quote
Old 03-18-2013, 11:47 AM   #7
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,747
Especially with a full tank (which always seems to be the case when I come to the deepest sand) there is a lot of weight on the front end... Gotta get your weight back.
traveltoad is offline   Reply With Quote
Old 03-18-2013, 12:48 PM   #8
Blue&Yellow
Oddometer: 754
If you've been desert racing for years you're more experienced than I am. But have you tried lowering the rear suspension and stiffening up the front? That increases the steering rake angle and should make the bike more stable.
Also - stupid question: your front wheel is spinning smootlhy right? No gravel or anything between the disc and the caliber?
Old 03-18-2013, 12:55 PM   #9
EZ300
EZ300's Avatar
Oddometer: 1,121
Talent,... You need more of it.
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 03-18-2013, 01:02 PM   #10
Eldon
950 ADV
Eldon's Avatar
Oddometer: 518
Yes don't over rely on your stabilizer. Turn it back a few turns so you're not fighting it. Now use that throttle!! You need to be moving at least 40 mph to break plain, then things will settle down. stand up and let that beast move under you. Speed is your friend!
05 KTM 950 ADV Black (FOR SALE)
06 YZ250 Smoker
Eldon is offline   Reply With Quote
Old 03-18-2013, 01:07 PM   #11
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 525
My little sand lesson.
Find sand without obstacles, keep speed down, and practice a given stretch many times so you become comfortable while you learn how to react automatically.
From a stand still, look ahead, aggressively look ahead to where you want to go, aim with your eyes and lean forward as if you "will" yourself to the spot. Do this in a straight line at first.
Think of working the throttle up and down rpm's with the back spinning and let the bike work under you. If you strive to look where you want to go and let your body move to control the direction, then the bike can take care of its job and go there.
Handlebar grip should be firm but light, don't fight, just guide the front. Your body needs to move around, the bodies weight distribution allows the back tire to sweep and steer the bike. To learn you got to loosen up and experiment and at the same time aiming to a spot to go. Don’t be looking down at the front tire. Looking ahead gives you balance and control.
After the straight stretch is going OK start some sweeping turns with the rear tire spinning. When you can start “drifting” back and forth you are getting it.
As an example of the time and effort you need to get results think of learning to play a simple song on the violin. Practice and practice and you will be rewarded. For learning safety beware of riding too fast. This can be done a slower speeds. Enjoy and have fun.
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 03-18-2013, 01:10 PM   #12
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,459
For your viewing pleasure.....
Mike Gilkey, 04 950 Adventure, he never stands.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 03-18-2013, 01:20 PM   #13
Katoom72
Katoom72's Avatar
Oddometer: 910
It's as easy as it is hard. Don't fight the bike.
Theh arder u clamp on the grips the more the front end wil be upset, let the wheel find it's on way.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 screwed with this post 03-18-2013 at 01:26 PM
Katoom72 is offline   Reply With Quote
Old 03-18-2013, 02:03 PM   #14
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,747
Not many pro flat trackers do...
Old 03-18-2013, 02:10 PM   #15
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,007
Damper on my 950 is 11 clicks in....start in 2nd gear....do at least 35-40mph....
and yell weeeeeeeeee........
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Times are GMT -7.   It's 02:53 PM.
