Old 03-21-2013, 01:42 PM   #1
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 663
Euro Special
Another Unholy Union rebuild on a R100GS:
Donor is a low mileage one owner bike that had been stolen and vandalised by kids. The original owner kept it for years in the hope of rebuilding it, but never got round to doing it.
[IMG] photo palermoGS_zpsf43b9b78.jpeg[/IMG]
TAG aluminium extended monolever, bitches:
[IMG] photo IMG_0013_zps3450a07b.jpg[/IMG]
The beast:
R100GS base engine, Moorespeed 1000cc long skirt pistons+valves and balanced OEM crank.
I have the Moorespeed pistons on my 100GS city ride and really love them. Waiting to see how the valve changes affect the feel and esp looking forward to trying out a balanced crank.
[IMG] photo IMG_0003_zps4a1b5701.jpg[/IMG]
Ras Thurlo screwed with this post 03-22-2013 at 04:10 PM
Ras Thurlo is offline   Reply With Quote
Old 03-21-2013, 01:59 PM   #2
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 663
a dry run:
WP50mm forks, Trail Tech Rally light, TAG kevlar tank
I hope some of you pick up on the Samcro look
Check out my neighbour
[IMG] photo projecttrial_zpsda972047.jpg[/IMG]
Ras Thurlo screwed with this post 03-22-2013 at 06:27 AM
Old 03-21-2013, 02:27 PM   #3
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,673
The engine turned then up on time then Ras? Looks great. cant wait to hear how well it goes.
Jota as well. Very nice.
Rob Farmer is offline   Reply With Quote
Old 03-21-2013, 02:34 PM   #4
Prutser
Prutser's Avatar
Oddometer: 1,006
Those are what you call ROX RISERS
Looking forward to a new bike build. I sure like the TAG gadgets.
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 03-21-2013, 03:34 PM   #5
Chad M
Custom User Title
Oddometer: 785
Originally Posted by Ras Thurlo View Post
a dry run
I hope some of you pick up on the Samcro look.
Chad M is offline   Reply With Quote
Old 03-21-2013, 05:36 PM   #6
GESII
Gerry with a G
GESII's Avatar
Oddometer: 110
Laugh TAG Mono
I want one of those TAG aluminum monolever swingarms bad!
GESII is offline   Reply With Quote
Old 03-21-2013, 05:44 PM   #7
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,479
Neato!!!
A buell fairing on a G/S???? RAd!!!!!!!
Looking forward to your progress
Old 03-21-2013, 06:11 PM   #8
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,559
does TAG have a website? I can't find anything on them.
Also, are those swingarms currently available?
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 03-21-2013, 07:02 PM   #9
hardwaregrrl
ignore list
Oddometer: 7,479
TAG
Old 03-22-2013, 02:32 AM   #10
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 663
Frame/Geometry
Mainframe strengthened by TAG, with a 2 degree change in rake and engine mounting moved forward.
Using stock KTM triple clamps that came off a '98 300exc. The offset is negligible, but wanted to try this out for now. Given that I have a steeper rake angle, I wanted to play it safe on the offset, until I got a feel for the bike.
Chopped GS subframe, cut just behind the rear pannier rack mounting point. I prefer the look of the G/S subframe (as in earlier dry run picture), but I have seat and pannier racks that will fit onto a paralever frame, so wanted to minimize brain damage for now.
I hear that there is a risk that the greater suspension travel of an extended monolever could cause the wheel to hit the mudguard on the longer paralever subframe. Am going for a smaller mudguard, so lets see.
[IMG] photo IMG_0010_zps6c027562.jpg[/IMG]
Ras Thurlo screwed with this post 03-22-2013 at 06:28 AM
Old 03-22-2013, 05:43 AM   #11
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 663
Fleabay Forks
Horror shots from a fleabay set of WP50s
Paid 60 Euro for them, so did not mind the complete overhaul
[IMG] photo wp502_zps0ceb4d34.jpg[/IMG]
[IMG] photo WP501jpg_zps8d947ec8.jpg[/IMG]
and then there's the XXX shot:
[IMG] photo wp503_zpsd1071551.jpg[/IMG]
Old 03-22-2013, 06:30 AM   #12
hardwaregrrl
ignore list
Oddometer: 7,479
Good lord those suckers are filthy!!!
Old 03-22-2013, 07:12 AM   #13
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,513
Oooh, I was waiting for this thread to happen.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 03-22-2013, 09:27 AM   #14
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 663
Rim Offset
In order to calibrate the required rim offset, I put on some 140 Michelin Deserts, as this is the widest tyre that I will be using.
After quite a while setting up the offset, still have a problem with clearance:
[IMG] photo IMG_0014_zps4a03c888.jpg[/IMG]
man, this job has a terrible work to results ratio. Packed it in after I could see at least 1mm of clearance:
[IMG] photo IMG_0015_zps442b306d.jpg[/IMG]
Old 03-22-2013, 09:46 AM   #15
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 663
Cyborg
450w alternator kit
have also gone for the Moorespeed programable ignition as an alternative to double plugging. As I assume the high compression pistons would not be as happy as I am to be riding in mamma hafrica
[IMG] photo IMG_0009_zpsae39a8a3.jpg[/IMG]
Ras Thurlo screwed with this post 08-06-2014 at 02:22 PM
Times are GMT -7.   It's 03:31 PM.
