Old 04-30-2013, 05:43 AM   #61
Prutser
Prutser's Avatar
Oddometer: 1,018
Originally Posted by Airhead Wrangler View Post
If I had to guess, I'd say 42N/mm spring rate and 280mm free length.
I think you are right on the length but with the ratio of that TAG swing arm the spring rate needs to be at least 80 N/mm or more.
Do you know what spring rate is on your bike AW ?
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 04-30-2013, 06:21 AM   #62
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,551
Nope, but I know it's too soft, whatever it is.
EDIT: You got me curious so I went back and looked at a few photos and managed to catch the number in one of them. It's a 75-240 spring, also made by WP, so those numbers should be directly comparable.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 04-30-2013 at 08:17 AM
Old 04-30-2013, 08:35 AM   #63
Prutser
Prutser's Avatar
Oddometer: 1,018
Your numbers sound right. It will be 240mm long (free length) and 75 N/mm.
Our shocks were mounted on almost the same place but your swing arm is longer. ( if I remember correct from the drawings you made?)
On my bike I'm using a 90 N/mm spring with 15mm pre load and I might even try a stronger one.
With more pre-load I would have the risk of the coils blocking. And a mono swing would start to jack to high so I have no dynamic sag when I'm riding anymore.
If you mount a stronger spring on your shock you should be able to get your fork moving a bit better too.
Now back to Ras his bike
Ride Report 2012
Prutser screwed with this post 12-29-2014 at 01:00 AM
Old 04-30-2013, 10:48 AM   #64
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,986
Originally Posted by Ras Thurlo View Post
great advice, with a bit of route-planning the RT clutch cables worked out great on the giraffe risers
already had long brake line, so did not have the worry about that
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 04-30-2013, 02:08 PM   #65
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,574
[IMG] photo IMG_0192_zps8300d94e.jpg[/IMG]
Off topic, but still on two wheels, sort of. Is that Vespa scooter off to the right an SS (with the "big" 180cc two stroke engine)? I can't remember how many models came out with that shaped head light.
That tank looks good, and who need more than 35 litres anyway?
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 04-30-2013, 03:47 PM   #66
johnalex
Rider of rides.
johnalex's Avatar
Location: Los Angeles, CA, USA l Todos Santos, BCS, Mexico
Oddometer: 52
I am glad that my eco-friendly centerstand mod was noticed. Should also work well as a biodegradable bash plate.
In the meantime I also got a telescopic side stand from Migsel. Its real chunky and well made, as well as being able to deal with moving the spring so that it can work like a 'real' side stand.
Although will need to try out how it feels in this location as there is quite a lot going on in this particular corner of the bike between carbs, gear-lever, footpegs and side stand
Where can the side stand be ordered?
JohnA in LA
85 RZ500 - Tricked out
00 Pegaso - SOLD - 01 RSVR - SOLD
98 VFR - 133,000 miles
89 BMW R100GS - in Mexico
johnalex is offline   Reply With Quote
Old 04-30-2013, 04:05 PM   #67
Clay Spinner
Clay Spinner's Avatar
Oddometer: 713
Google migsel bmw, go to site and send email. It will not be listed in the webshop.
Clay Spinner is offline   Reply With Quote
Old 04-30-2013, 10:41 PM   #68
Phreaky Phil
Oddometer: 1,855
Got to agree, that tank does look good,as is the rest of the bike. Is there good steering lock with the tank indentations ?
Those are some big Rox Risers.! ! Ithought mine were big at 3 1/2 inches, but i have mine angled back a lot further. How is the reach to the bars when sitting. A bit "Easy Rider"
Phreaky Phil is offline   Reply With Quote
Old 04-30-2013, 11:52 PM   #69
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,574
They are probably just the ticket for standing though. I am 178cm tall with longish legs and I can't get my bars high enough or pegs low enough to stand comfortably. On my previous bikes, an 1100GS and Xchallenge I was able to set them up so I could stand almost straight up with comfort for many kilometres.
David Hunn:
Old 05-01-2013, 06:46 AM   #70
ontic
Oddometer: 1,070
Hi Ras,
loving the build,
that looks a bit uncomfortably close in my very humble opinion.
Not much room at all for sticks and stones and mud and stuff...?
I've got the standard KTM two pot brembo caliper, and the same 320 rotor as you. My current caliper bracket set-up is a little complicated right now to go into, and I am about to change it anyway, but essentially with the stock caliper it gives me 8-9mm room on either side between the fork slider and the spokes. Although it took me a while to figure it out I didn't have to alter the stock wheel spacers or the caliper brackets like Jenna did.
sorry for the terrible photo, but you can kinda see the space on either side here.
It is probably not much good to you now because you have that caliper and HE bracket already, and apologies if it is old news to you, but the stock two pot brembo seems to have plenty of stopping power with the 320mm rotor, and there is a HE relocation bracket to make it work for a 320mm rotor- for either variation of the WP50 fork sliders and the differing caliper bracket lugs (forks that came stock with a 260mm rotor such as yours have smaller lugs, and forks that came stock with a 300mm rotor have larger lugs).
This post goes into a bit more detail about this stuff.
After all my work making my cobbled together brackets I ended up getting a spare set of WP50's that have the larger caliper lugs (ie from a bike that came with a 300mm rotor stock) and found the correct (used and cheap) HE caliper bracket to suit them- eg, this
sorry for the sidetrack and long post,
I hope it made sense.
Keep up the good work!
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 05-01-2013, 08:21 AM   #71
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,986
I had thought the Brembo "goldline" 4-piston calipers only worked with the Supermoto, as the front wheel is smaller and there is more room to fit the wider caliper...
R65LazaruS
Old 05-01-2013, 12:10 PM   #72
Clay Spinner
Oddometer: 713
Ras, whats going on with those funky exhaust pipes there?
Old 05-01-2013, 07:20 PM   #73
ontic
Oddometer: 1,070
Yeah, that is right, that is the stuff I remember reading way back when I kept finding references to not being able to fit a 320 rotor to WP forks and a 21 inch wheel- wasn't a problem for us as it turned out but they must have been talking about using that caliper that Ras has. I did also read back then that there is a small amount of room that can be gained by carefully milling a little meat off the back of the caliper where it comes closest to the spokes. The rotor spacers have pushed that rotor so close to the fork leg though...
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 05-04-2013, 01:49 AM   #74
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 673
Moorespeed 42mm pipes and end can
[IMG] photo IMG_0174_zps6eaed9cc.jpg[/IMG]
[IMG] photo IMG_0175_zps55749a14.jpg[/IMG]
Ras Thurlo is offline   Reply With Quote
Old 05-04-2013, 01:55 AM   #75
Ras Thurlo OP
Desert Lion
Ras Thurlo's Avatar
Oddometer: 673
It does fit, but you're right- does not leave any room for error.
esp when I go into the clay swamps that we get around here in the valley floors its could get all gnarled up.
I fear that you and Solo are right and that I will have to get a standard KTM two pot calliper. BTW- was told by the local orange boys that they improved a lot in 2012 so will probably just get a new one.
will the gold bling 4 pot calliper have the same problems on WP 4860s?
[IMG] photo IMG_0200_zps7638ebe9.jpg[/IMG]
Ras Thurlo screwed with this post 05-04-2013 at 11:38 AM
Times are GMT -7.   It's 09:35 AM.
