Old 03-21-2013, 03:11 PM   #1
mathews42 OP
mathews42's Avatar
Oddometer: 338
KTM 950 Master CYL conversion
The previous owner of my 950SE, converted the clutch master cylinder to a rear brake. I'm wanting to convert it back. I am in the process of ordering the
Magura KTM LC8/690/MX 10.5 Master Cylinder Rebuild Kit
So I can have my hand clutch back. (it has a rekluse now) I'm leaving the Rekluse in but after talking to the guy at Rekluse he confirmed that the hand clutch does make shifting a lot easier. He also has a 950 and knew the issue I was having shifting with the rekluse and no hand clutch.
My question is, what is the best way to clean out the master so i can convert it back to mineral oil.
mathews42 is online now   Reply With Quote
Old 03-21-2013, 06:47 PM   #2
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 785
http://advrider.com/forums/showthread.php?t=870500
Just for reference...
Many don't use mineral oil in the clutch..
Cheers
Dave
pdxmotorhead is offline   Reply With Quote
Old 03-21-2013, 07:12 PM   #3
mathews42 OP
mathews42's Avatar
Oddometer: 338
Sweet! Thanks for the heads up!
Beads in the headlight a Flying Aga Tale by Isabel Dyson I met these two travelers on their Journey from the UK to Alaska and through South America on a 1979 BMW R100RS. Their book is now on Amazon for Kindle.
Old 03-22-2013, 07:12 AM   #4
mathews42 OP
mathews42's Avatar
Oddometer: 338
Any ideas in flushing/ cleaning out the brake fluid?
Old 03-22-2013, 08:07 AM   #5
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,961
Flush it with the oil of your choosing, would not use brake cleaner because it might harm the rubber etc but that is an unconfirmed theory on my part.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 03-22-2013, 04:10 PM   #6
pdxmotorhead
Oddometer: 785
As I recall on my old brit cars,, they recommended alcohol for cleaning up the metal bits and said to use the brake fluid to clean the rubber parts..
I've always used a clean rag and brake fluid to clean up brake parts..
Dave
Old 03-24-2013, 06:23 PM   #7
mathews42 OP
mathews42's Avatar
Oddometer: 338
My only concern is getting the clutch master clean and residue free before adding clutch oil.
Old 03-24-2013, 06:41 PM   #8
keener
Speed changes you.
keener's Avatar
Oddometer: 964
I was told, you can use cheap mineral massage oil from your local drug store to flush it if you want to save the good oil.
04 ADV 950
keener is offline   Reply With Quote
Old 03-25-2013, 04:04 AM   #9
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,012
You can use Johnsons baby oil for permanent use.
It gives the bike a nice tender smell. It is mineral oil so works fine. If you are going to use the Magura blood for the purpose of washing baby oil is fine. I use fork 2,5wt oil for lighter operation.
Cheers.
Old 03-25-2013, 12:20 PM   #10
mathews42 OP
mathews42's Avatar
Oddometer: 338
Thanks for the info guys, I'll flush with baby oil and then use fork oil or Magura blood, Havent decided yet.
Times are GMT -7.   It's 04:08 AM.
