Old 03-21-2013, 08:37 PM   #1
Toddwmac OP
ADV addict
Toddwmac's Avatar
Oddometer: 288
25MPG on a 990 Adv?
Ok I know I'm not setup for milage, but does this seem right?
I'm getting 25 MPG Highway @ Sea level
  • 16T/45T
  • TKC/Mefo Explorer
  • FMF Q4
  • "high flow" map (per FMF and set by the dealer)
T
KTM 08 990 ADV
HD Duece
WR 250R
Lost but don't care!
Toddwmac is offline   Reply With Quote
Old 03-21-2013, 08:43 PM   #2
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,956
  • 16T/45T
  • TKC/Mefo Explorer
  • FMF Q4
T
Sounds heavy, we two up loaded on our carbed SE are getting 40 - 48 MPG depending on the right hand
We have the same gearing too
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is online now   Reply With Quote
Old 03-21-2013, 09:20 PM   #3
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,952
Kiwi- His bike is Fuel Injected.
Are you getting any EFI codes? Stock except for the pipes?
Check your O2 sensors wires.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 03-21-2013, 10:23 PM   #4
Big_John
Colorado Rider
Big_John's Avatar
Oddometer: 2,989
Can't help you....and know that you are FI.....
but just purchased my 950 Carb model. I did a fly, buy and ride....for 900 miles+....
and got
41mpg
42mpg
40 mpg
34 mpg (serious wind...upwards of 50 mph in the face....at 80mph)
pleased with my mileage.....
John
2004 KTM 950 Adventure S
2004 BMW R1150RT
2003 KTM 450 EXC
Pointing the Way http://www.gracemotoadv.com
Big_John is offline   Reply With Quote
Old 03-21-2013, 11:09 PM   #5
Toddwmac OP
ADV addict
Toddwmac's Avatar
Oddometer: 288
No other engine mods....just the pipes. The maps were done at a dealer. I need to take it in pretty soon for one of those low cost KTM oil changes...are there any codes or other things I can ask them about. (other than my milage sucks)
KTM 08 990 ADV
HD Duece
WR 250R
Old 03-21-2013, 11:12 PM   #6
mnsty
mnsty's Avatar
Oddometer: 173
I don't wanna start the whole mileage thing again, but I have a 04 Go 950 with a head 2 wind jet kit and it gets 130 miles to the reserve light so about 25 mpg exactly...I mean exactly what it did before the jet changes. really love the bike but it makes going anywhere a pain in the ass, especially with my friend on his 1150 GS at 50 mpg.
Currently,
76 R90S Turbo
77 R100RS
83 RS/GS
85 K100RS
90 BMW K1
91 900IE Lucky Exp
00 VOR 503SM
04 KTM 950 GO!!!!!
05 TM 530 Black Dream
= Too much stuff. When will I learn??
mnsty is online now   Reply With Quote
Old 03-22-2013, 12:02 AM   #7
corndog67
Oddometer: 1,281
But you have a better bike, have more fun, and exceptional kids too, so you win.
corndog67 is offline   Reply With Quote
Old 03-22-2013, 03:36 AM   #8
Blue&Yellow
but orange inside...
Blue&Yellow's Avatar
Oddometer: 754
The aftermarket maps are real gas-guzzlers.
I had the akrapovic map before and got probably half the milage I get now after changing back to the stock map!
I was a little hesitant about running aftermarket exhausts and stock map but temps are normal and I even checked the spark plugs when I changed oil a couple of months back - they looked fine so I'm not worried anymore. Probably set up pretty rich from the factory anyway.
I've heard that people see huge variations in mpg depending on if they run side panniers or not - the 990 is pretty slim for such a big bike so they end up right in the wind blast.
Blue&Yellow is offline   Reply With Quote
Old 03-22-2013, 05:24 AM   #9
ABuck99
0.0
ABuck99's Avatar
Oddometer: 609
At 25mph its running fat- I think with your gearing properly tuned should be closer to 35mph, but all that depends on how aggressively you drive it.
Of course you can look at the ends of the exhausts, and plugs to notice rich running but to really know how much, you might consider gas analyzer. If you have access to a dyno near by, it wont cost much to have a base run done with the gas analyzer to map out your AF ratios at RPM increments- this will tell you how rich the engine is running through out the range wehre you normally ride (1500-6500rpm) and where to adjust your map, which can be done via Tune ECU. Bike needs to be nice & warm, have them run 4th gear up to 6500rpm. And if there is time, do a 5th gear run which will load the engine a little differently to see if there is any variance in the AF ratios.
good luck
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 screwed with this post 03-22-2013 at 06:28 AM
ABuck99 is offline   Reply With Quote
Old 03-22-2013, 06:13 AM   #10
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,956
Yes I know, hence I said ....
Originally Posted by Two Moto Kiwis View Post
... on our carbed SE
as FI is usually quite a bit more efficient so he has issues.
I would suggest the mapping is heavily fueled in the wrong places, my good mate with a SD-R has corrected his with Tune ECU/PC 5 autotune, took some doing but he gets far better fuel efficiency now and stronger right through the range
His was extremely rich at idle and mid/cruising band and lean as hell at the top, now he has the perfect curve, torque and power to go with it.
Old 03-22-2013, 09:52 AM   #11
DSM8
DSM8's Avatar
Oddometer: 3,952
You have two options.
1. Dealer loads a different map back onto the bike. But you are dependent on the dealer to have the map changed every time if needed.
When I had my 990 I was running a stock map with the aftermarket pipes.
2. Go the TuneECU route. This will allow you to load your own EFI maps and there are enough people out there that someone from this site in your neck of the woods has to be around that has done this who should be willing to provide some assistance and advice.
3. Do you own oil change, it is not worth the price the dealer want when you can do it yourself.
here is a writeup on the HOW, very easy to do just take your time.
http://advrider.com/forums/showthread.php?t=371723
DSM8 screwed with this post 03-22-2013 at 09:58 AM
Old 03-22-2013, 12:33 PM   #12
zen rider
veteran rider
zen rider's Avatar
Oddometer: 207
1) I agree on the new map and Tune ECU.
2) Check your cruising RPMs on highway and consider softening the fueling around those RPMs a smidge.
3) Consider a 17T front sprocket on longer highway rides, which will lower cruising RPMs and increase MPG. With practice this is a 10 minute job.
4) Carry 1-2 Liter fuel bottles on longer trips.
BTW I have heard the Q4 hurts MPG. I am thinking of an Adventuretank 2 into 1 with Q4 exhaust for my 990 anyway ($399).
Kevin
'12 DL650 Adventure black Russell seat; '05 TTR250; '13 Zuma 125
zen rider is offline   Reply With Quote
Old 03-22-2013, 01:08 PM   #13
DSM8
DSM8's Avatar
Oddometer: 3,952
For comparison.
07 990
Leo Vince System (this is the mid pipe and the cans not just the bolt on cans like the Q4)
Stock Map (dont know what version but it was loaded in late 08)
45mpg commuting to work
38-40ish off road
I dont think the pipes are what kill the mileage so much as just having a far to aggressive EFI map loaded.
Just my .02
Old 03-22-2013, 02:10 PM   #14
mnsty
mnsty's Avatar
Oddometer: 173
Huh??
Currently,
76 R90S Turbo
77 R100RS
83 RS/GS
85 K100RS
90 BMW K1
91 900IE Lucky Exp
00 VOR 503SM
04 KTM 950 GO!!!!!
Old 03-22-2013, 06:03 PM   #15
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,327
I live close and I might have an extra 17 tooth. Plus I have tune ecu and stuff and a 990.
Come out to the east side meet up sometime.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Times are GMT -7.   It's 10:37 AM.
