Old 03-22-2013, 06:53 PM   #16
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,982
Originally Posted by zen rider View Post
1)
3) Consider a 17T front sprocket on longer highway rides, which will lower
Something to consider here, we changed from 17 to 16 to smooth the old doll out at lower RPM and our milage got better!
The only thing I can think of is we are now using a lesser throttle opening to attain the same speed but pretty much we are two up all the time with house and contents on ... note air dam , maybe not so applicable with FI but something to thro in the mix that having the 16 tooth may not necessarily punish your MPG.
Bloody good offer from grinns .. that is what make this place really worth while
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 03-22-2013, 07:09 PM   #17
cool1442
Oddometer: 13
I have Q4s
Ok, I know my 950 SE is carbed..which I prefer over FI.. but I want to contribute (maybe brag) here. I got my SE with Q4s but no spark arrestors. It was all messed up by a local shop..jetted way wrong, lots of air leaks. I had a local wizard jet it and seal up the leaks, added FMF spark arrestors and geared down to 16T. Result: goes like double hell, idles great, runs smooth, gets 40-42 MPG, runs 4 bars all the time, and is considerably quieter. A properly tuned bike will be smooth and cool and run great. What is not to like about this bike? I've never bought a bike for gas mileage, just for fun and it delivers on all fronts.
cool1442 is offline   Reply With Quote
Old 03-22-2013, 07:19 PM   #18
AB13
Oddometer: 1,073
Dyno the thing!
We are a Power Commander tuning center Q-4 slipons should not hurt mpg if the bike is tuned to the right AFR 13.7-1 is good for power and mpg with the PC-V you can have 2 maps one for power and one for mpg in order to tune the bike you must be able to read your AFR and load control the bike.
Just joined for the sticker.
AB13 is offline   Reply With Quote
Old 03-22-2013, 07:24 PM   #19
tilting40s
Oddometer: 57
My bike is gettin about the same. 07 990 w leo's custom map. I just cleaned out my map sensors today heard that could fix the mileage. We will see.
http://www.flickr.com/photos/9398434...in/photostream
Anyway this 1mm holes get clogged and I used a needle tip as seen to clear them out. I don't know if it is going to make a difference but I feel like the bike was smoother after.
tilting40s screwed with this post 03-22-2013 at 07:30 PM
tilting40s is offline   Reply With Quote
Old 03-22-2013, 08:12 PM   #20
chrish4ku
chrish4ku's Avatar
Oddometer: 854
Custom Map = Strange Mileage.
On my 2008 (RIP) I was getting 25 average in the dirt with the Akro map.
2011 model, I get up to 38 HWY.
It's all over the board....
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 03-23-2013, 01:53 AM   #21
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,319
I have a carbed 990.
I have been keeping a real close tab on my fuel usage.
Worst = Ultra technical heavy sand, heaps of throttle = 11 mpg
Best = tar cruising = 39 mpg
Ride like a twat on tar = 25mpg
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is offline   Reply With Quote
Old 03-23-2013, 06:08 AM   #22
zen rider
veteran rider
zen rider's Avatar
Oddometer: 207
[QUOTE=Two Moto Kiwis;21012441]Something to consider here, we changed from 17 to 16 to smooth the old doll out at lower RPM and our milage got better!
Bloody good offer from grinns .. that is what make this place really worth while [/QUOTE
Interesting. My '08 990 has the stock 17T and I'm about to lower it to a 16T mostly to make it more Wheelie-Happy. Glad to hear my MPG may not suffer.
Kevin
'12 DL650 Adventure black Russell seat; '05 TTR250; '13 Zuma 125
zen rider is offline   Reply With Quote
Old 03-24-2013, 02:36 PM   #23
Sheep Shagger
Show me your fleece
Sheep Shagger's Avatar
Oddometer: 2,153
Originally Posted by Toddwmac View Post
Ok I know I'm not setup for milage, but does this seem right?
I'm getting 25 MPG Highway @ Sea level
[*]"high flow" map (per FMF and set by the dealer)
T
It's the map, forget everything else you listed, it won't change MPG. When I asked the dealer to put the ACK map in my bike (before TuneECU was available) it took me from 35~40mpg to 25mpg. Go back to the stock map, it will be fine with aftermarket pipes and won't run lean, plus give you far better MPG.
My recommendation, go back to the dealer and ask for stock map, or read up on TuneECU, and load a stock map.
Sheep Shagger is offline   Reply With Quote
Old 03-24-2013, 04:01 PM   #24
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,982
Good advice go the Tune ECU route.
If doing the leaner thing (which you will be heading too) make sure your SAS is blanked off or it will burn the packing out of your mufflers and ruin them.
Old 03-25-2013, 09:10 PM   #25
Toddwmac OP
ADV addict
Toddwmac's Avatar
Oddometer: 288
Thanks guys...great stuff.
DSM8 ...I agree and just relocated my beloved M Coupe into the driveway to make room for more work on the big twin. It was like fingernails on a chalkboard every time I heard myself say I was going to a dealer for an oil change.
Grinns... thanks a ton for the PM. I'll ping you and head over to the dark side.
KTM 08 990 ADV
HD Duece
WR 250R
Lost but don't care!
Toddwmac is offline   Reply With Quote
Old 03-25-2013, 10:43 PM   #26
speedygee68
dirt eater
speedygee68's Avatar
Oddometer: 224
Lotsa good info
Thanks DSM8 also for this info. Might pm you for more info. I'm only a few cities away from you.
I also have a new (to me) 08 990S. 3k miles, Akropovic and gas miles sucks ass. Performance, however, is through the freaking roof. Bike tells me to haul ass or get off. After topping off the fuel, I got about 120 miles before the fuel light came on. Granted, I'm in the mountains, but I thought I would get better mileage. Bike was worked on at Eric's in Pasadena, but, he retired and moved and I don't know where Brett went. I'll keep an eye on this post for more info.
Yes, I have a truck. No, I won't help you move. I'm going riding!
08 KTM 990S, 08 Husky TE610,
speedygee68 is offline   Reply With Quote
Old 03-26-2013, 08:56 AM   #27
crashmaster
ow, my balls!
crashmaster's Avatar
Oddometer: 5,291
It's the map, forget everything else you listed, it won't change MPG. Go back to the stock map, it will be fine with aftermarket pipes and won't run lean, plus give you far better MPG.
Yep. The cookie cutter performance maps all seem to be around 25 mpg. Stock map will work just fine.
Riding the Americas: No Fumar Español
_____________________________________________
crashmaster is offline   Reply With Quote
Old 03-26-2013, 02:39 PM   #28
katanarama
riding > posting
Oddometer: 182
2007 with akros & akro map
Only chance I get to ride it is a 4 mile commute each way each day.
Lucky if I get 75 miles a tank. Crazy I know.
katanarama is offline   Reply With Quote
Old 03-26-2013, 05:52 PM   #29
dog'meat
Presidient
dog'meat's Avatar
Oddometer: 168
"I think of a man, and take away reason and accountability...", - Melvin Udall
KTM 990 Adventure R 2012 - KTM 640 Adventure 2007
Mexico City, Xilitla, Aquismon, the Cave, the River and the Shangrila...
Mexico City, Cuetzalan, Nautla, Veracruz
dog'meat is offline   Reply With Quote
Old 03-27-2013, 10:11 AM   #30
tilting40s
Oddometer: 57
Cleaned the MAP Sensor, it did nothing for MPG. Going back to stock map.
Times are GMT -7.   It's 02:16 AM.
