Old 03-22-2013, 02:11 PM   #1
midfat OP
wholesome dirtiness
midfat's Avatar
Location: Socal, between the mountains, desert and ocean
Oddometer: 222
Wheel Fitment: ADV to SE
Need some help determining if these will fit my 950SE. There's a set of wheels for sale in the Flea Market that appear to have come off a 950ADV.
http://advrider.com/forums/showthread.php?t=868127
- The ADV rear will be a bit wider than the factory SE rim, right?
- Can I remove left front disk, or will the mount interfere?
- Will the right front disk on match the 950SE caliper offset?
I'd like to have two sets of wheels mounted up for my 950 -- one street set, one dirt set. Trying to figure out if this would be an easy solution.
midfat is offline   Reply With Quote
Old 03-22-2013, 02:29 PM   #2
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,917
Those will absolutely fit. The front wheel will only need one rotor and the rear rim will be wider but the hub is the same.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 03-22-2013, 02:36 PM   #3
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 1,083
We
I have a set on my se. Just use the se's spacers. :)
dogsslober is offline   Reply With Quote
Old 03-22-2013, 04:42 PM   #4
It'sNotTheBike
Oddometer: 704
Wheel swaps don't get any easier than what you have planned.
I'm guessing you will use the stock SE wheels for the dirt
tires and the Adventure wheels will have the tires which are
better suited to paved road use mounted on them.
The stock SE rims are stronger than the Adv rims so
using the stronger wheels for the dirt riding would make
sense, or at least it would to me.
It'sNotTheBike is offline   Reply With Quote
Old 03-22-2013, 06:03 PM   #5
dogsslober
dogsslober's Avatar
Oddometer: 1,083
wheel pic
Here is my set. I took the 21 off and laced a 19.
Old 03-22-2013, 06:59 PM   #6
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,075
I am interested in a 17/17 set if anyone knows of any going at a reasonable price.
I also looked at the 21/17/18 idea but like the idea that I can bang a 17" track sticky on for being stupid with, did this with my DR as well and loved they way I could tuck it in.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 03-24-2013, 03:00 AM   #7
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
^^Cool pic^^.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 03-24-2013, 09:16 PM   #8
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
I thought the SE uses a thumper fork lug with the smaller diameter front axle. I remember this from when I built up a set of SE wheels for my ADV.
I am thinking that you could probably swap bearings and make an ADV hub work on an SE but it'd be much easier to buy the right wheel from the beginning...or simply swap rubber on the SE rim you already have.
Rear hub is no different and a pretty nice setup for a low profile Scorpion for road with the wide 18".
Sporting Wood is offline   Reply With Quote
Old 03-24-2013, 09:51 PM   #9
Vicks
gets stuck in sand
Vicks's Avatar
Oddometer: 3,204
+1
The SE front axle is smaller (24mm) than the Adv's (30mm ??)
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally and 2012 KTM Adv990
530Exc Adventurization re-build
Vicks is online now   Reply With Quote
Old 03-25-2013, 08:13 AM   #10
dogsslober
dogsslober's Avatar
Oddometer: 1,083
Adv wheels
The ADV hub bearings and internal spacer are the same as the Se. The out side spacers are what steps down to the smaller axle size. I know this for a fact because I have the adv hub with SE outer spacers on my SE for my street wheels.
Times are GMT -7.   It's 12:58 AM.
