Old 08-01-2013, 01:09 AM   #31
Motomochila
Mad Scientist
Motomochila's Avatar
Oddometer: 1,083
Just read this for the first time. A few thoughts, if you are really wanting a "flat tracker" look.
1. Get those bar risers off before you kill yourself, unless you only plan to ride pavement. Dirt will get you into some real trouble with the setup you have.
2. Its easy to relocate pegs and controls to a standard instead of forward. eBay is your friend and parts for this bike are cheap.
3. For under $100, you can get a megaphone tail that will give you a better look.
4. Cut off any excess brackets, and rear pegs to lighten the load.
5. A better bag would be used "horse" saddlebags, and a lot more safe when you slide her sideways on the dirt roads. $30.00 on eBay.
6. Eliminate the front headlight for a single LED centered in the lower section of the front number plate. Look at Omar's.com for idea, then buy LED from JC Whitney. You don't need bright, just the same as your stocker.
7. Carve you seat foam down and re-wrap with same vinyl. Look at flat tracker seats for design ideas.
Last....get rid of the front fender. No such thing on a flat tracker or a street tracker.
KTM-2014 500 EXC, 2014 690R, BMW- 2015 F800 GSA, 2012 K1600 GTL, Ducati-2015 Hypermotard SP, and 16 other motorcycles in various stages of restoration.
Motomochila is offline   Reply With Quote
Old 08-07-2013, 10:31 AM   #32
brian72 OP
URBEX
brian72's Avatar
Oddometer: 315
Thanks for all the advice I was looking for. I'm glad there is someone with as much information, on how my bike should look, out there as you have.
brian72 is offline   Reply With Quote
Times are GMT -7.   It's 08:01 PM.
