Old 03-23-2013, 11:59 PM   #1
2laneblacktop OP
Tarmac
2laneblacktop's Avatar
Oddometer: 3,121
DR650 Hydraulic Clutch Installation
If you like the reliability and smoothness of hydraulic clutches, this is the way to go, installed on a 09 DR650
This system came about through several detailed pictures and measurements back and forth to tech support
Peter Ubellacker at Magura, who I must say was the most helpful and determined tech support I've experienced
This is literally a drop-in clutch setup that may as well have been made for DR650s, a minute to file the bracket
and less than a minute to move the clutch arm over 1 spline and you're done, the rest is just a quick oil fill and bleed
and heat shield fab
I suggest ordering directly from Magura instead of going through a local store so you don't experience the frustration I did
waiting for weeks for the wrong parts they ordered
This is a very simple install anyone can do
Magura Clutch Procedure
Parts List Sugg. Retail
Magura Clutch Assy part# 0120492 $ 295.00
(Slave cylinder) part# 0120653 Included
(Slave cylinder bushing) part# 0412310 Included
(Cylinder Barrel adapter) Included
(46 inch plastic oil line) Included
Recommended Items Sold Separately
46 Inch SS Braided Line Part# 0720550-32 $ 70.78
Mirror clamp bracket Part# 0720543 $ 27.80
Bleed Kit Part# 0720528 $ 26.12
Magura Blood Mineral oil Part# 0999999-02 $ 5.16
Note: This assembly comes with a lever that has a red spur knob for lever position
adjustment (confirm when ordering)
Contact Sales/Support:
Peter Ubellacker Magura USA 1-800-448-3876
Peter@Magurausa.com
Tools
8 mm socket 1/4 drive (on swivel or flex extension)
8 mm open end wrench
10 mm socket
12 mm socket
6 mm Allen socket or wrench
4 mm Allen socket or wrench
Pliers
1/8 punch or equivalent (removal of roll pin in mirror clamp)
7/32 (5.5mm) open end wrench (slave cylinder bleeder)
Blade style feeler gauge is helpful
Rivet gun or just screws for heat shield
PROCEDURE:
Note: DO NOT MANUALLY PUSH IN THE SLAVE CYLINDER ARM, THIS CAN UNSEAT THE SEALS, IT SHOULD ONLY BE ACTUATED BY THE LEVER WITH OIL INSTALLED
Disassembly
(1) With the 10, 12 mm sockets and pliers for fuel line remove your side panels, seat and gas tank
(2) With the 4, 6 mm Allen sockets, remove your header pipe at engine front, shield at mid point, and header clamp bold behind the shield
Note: If you haven’t done your header pipe weld clean up at the head, do it before you reinstall the header
(3) Swing your hand guard out of the way if installed
Original Clutch Cable Assy
(4) Mark the clutch arm original and new position with a punch or sharpie, remove clutch arm bolt, remove clutch arm, then remove from cable end. (Fig 1)
THE NEW POSITION OF THE CLUTCH ARM WILL BE 1 SPLINE OVER TO THE LEFT FROM THE ORIGINAL POSITION (Fig 2)
(5) The cable is now loose in the bracket, note how the cable is routed, remove lever clamp at the perch and pull the cable from it’s routed position from top of handlebars
Magura Hydraulic Assy
(6) Install the mirror mount clamp bracket if ordered, tap out the roll pin in the mount with a 1/8 punch or the back end of a 1/8” drill bit, use a wooden hammer handle to not damage the drill tip (Fig 3-1)
(7) If you ordered the stainless hose separately install it now, but leave the nut at the master cylinder loose for now (Fig 3-2) For added protection I added shrink tubing over the stainless line but it’s not necessary
Note: A couple of pics were taken out of sequence, so you'll notice Fig 7 & 11 show the cylinder with the vinyl tubing
(8) Install the new assembly routing the same way as the cable was routed
SETTING THE FREEPLAY: The freeplay recommended in the install manual says 4-6 mm, I set mine about 4 mm and it worked perfect on the 2009 DR650
NOTE: THE FREEPLAY IS DETERMINED BY HOW YOU REMOVE OFF THE MOUNTING BRACKET
(9) Remove the cylinder bracket and grind/file the rolled over portion so there is a flat surface for the slave bushing to rest in and against, and slightly open up the inside diameter of the cylinder bracket tapping in with a punch so the cylinder bushing floats freely inside, there should be no binding, an additional 1-2mm will be removed from this flat surface to achieve correct freeplay, (if you accidentally remove to much, washers can be added back to correct the needed amount noted below) (Fig 4 and 5)
(10) Remove 1-2mm from the bottom of barrel adapter end to clear the case under clutch arm (Fig 6)
(11) Install the bracket, mount the slave cylinder and bushing in the bracket, put on the barrel adapter end, install on clutch arm and install clutch arm in new the position 1 spline over left from original position. Putting a small washer behind the bracket on the second bolt will help align the cylinder arm for straightest pulling action (Fig 7)
Checking freeplay - Push the slave cylinder back and measure the freeplay between the bracket and slave cylinder bushing with a feeler gauge or ruler, Now is when you determine how much more if any, needs to be removed from your bracket to achieve proper freeplay, this should be 1-2 mm, check carefully. (Fig 8 and 9 )
Note: A washer is supplied in the install kit to take up some freeplay if there is too much
Note: Too much freeplay will cause the bike to crawl forward in first gear with the clutch pulled in when the bike is fully warmed up
Note: The red knob at the lever is for LEVER POSITION ONLY not clutch freeplay
BLEEDING THE SYSTEM
Before tightening the oil line fitting nut at the reservoir, put approx turn twist in the line pulling toward the handle bars, this twist down the line will cause the cylinder to rest toward the starter and away from the exhaust as much as possible, the tighten the fitting nuts
(Fig 10 and 11)
Follow the directions in the kit, this process is simple and quick
Wrap a paper towel around the reservoir to minimize clean up then suspend the bleeder syringe with oil, tap up and down the line to help release any trapped air in the system
(Fig 12 and 13)
Making A Heat Shield
The clutch cylinder sits close to the exhaust pipe, so making a heat shield seemed like a good idea. Cut 2 pieces of 4”x6” 1/16 aluminum, bend or push them down into the jaws of a vise with a tube the same diameter of the exhaust, then trim them down to the final size of 2 x 5 (Fig 14)
Heat shields work best with air gaps so rivets were used to fasten the pieces so they would elevate the shield off the pipe, (Fig 15) small nuts were pinched between walls for another gap to fit a strip of heat shield material
Heat material available at most auto stores
(Fig 16 and 17)
Lastly, trimming the corner approx inch allowed the shield to accommodate the bend in the pipe underneath, and finally, installed with extra wrap of heat material on cylinder
(Fig 18 and 19)
2laneblacktop screwed with this post 03-26-2013 at 08:12 AM
2laneblacktop is offline   Reply With Quote
Old 03-25-2013, 04:12 PM   #2
rpet
Awesometown
rpet's Avatar
Oddometer: 820
thanks for sharing!
hydro clutch would be sweet on the ol' DR. The heat shield stuff is mildly annoying to have to deal with. Please report back with the long term results.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 03-25-2013, 04:13 PM   #3
BergDonk
BergDonk's Avatar
Oddometer: 3,580
Looks good
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 04-09-2013, 11:32 AM   #4
FuzzyNugs
Oddometer: 79
I've never seen this mod before. Well done and great write-up. Does this make the clutch easier to pull in? After lot's of slow speed technical stuff, my left arm is usually wasted. Would be nice for it to be a lighter pull.
FuzzyNugs is offline   Reply With Quote
Old 04-09-2013, 04:10 PM   #5
DisTech
DisTech's Avatar
Oddometer: 616
Wow, thank you for the excellent write-up!
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 01-09-2014, 05:21 PM   #6
2laneblacktop OP
Tarmac
Oddometer: 3,121
Originally Posted by rpet View Post
thanks for sharing!
It isn't even mildly annoying, very simple and worth the precautionary measures, works great
Much easier to pull, my cable never felt right, even after changing to a motion pro, I was used to the ease of pull of hydraulic
I would do it again before any other mod
Old 01-11-2014, 07:29 AM   #7
TrophyHunter
Oddometer: 2,211
One of the best tech write ups I've seen. Thx for taking the time to post up.
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 01-11-2014, 11:06 AM   #8
2laneblacktop OP
Tarmac
Oddometer: 3,121
Thanks, I would recommend as mentioned earlier ordering directly from Magura from the contact info above, I tried to give the business to a local store who turned the order into a mess and tried to over charge, and as a result, a couple of the pics were taken slightly out of sequence
The install has a steel braided line but there are pics with the vinyl line
Times are GMT -7.   It's 12:39 AM.
