Old 03-24-2013, 04:26 AM   #1
Brumm OP
Oddometer: 8
How to make the BMW F 800 GS lighter?
Hi fellow riders,
I just ordered a new 2013 BMW F 800 GS with lots of adjustments, like TT stuff to protect and carry. This will add some more weight to the already quite heavy bike. So I am looking for ways to make it lighter. An example would be the exhaust pipe, which brings about 2.5k.
Are there other significant ways to reduce weight (of my bike, of course )?
Please let us know what you have done. Thanks.
Brumm is offline   Reply With Quote
Old 03-24-2013, 03:30 PM   #2
GH41
Oddometer: 822
Exhaust and battery will shed some weight but is it worth the $$$. It's about like the difference between a full and 1/2 tank of fuel! GH
GH41 is offline   Reply With Quote
Old 03-24-2013, 04:49 PM   #3
DoWorkSon
Oddometer: 267
There was a similar thread a few months ago about the same thing.... Some of the suggestions were...
-Lighter exhaust/remove cat
-Cut off passenger pegs
-Remove one brake caliper/rotor up front
-Replace metal pieces with carbon fiber
- Less fuel
-Lighter wheels
-New battery
I'ts a heavy bike, not much room to drop a ton of weight. And if you truly want to, it will cost a lot of $$$$$
You could go as far as carbon fiber tank, swing arm, wheels, etc... much like sport bikes do, but that is more than the cost of the bike.
DoWorkSon is offline   Reply With Quote
Old 03-24-2013, 04:54 PM   #4
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 387
East less and exercise
Shed a few KG from the rider would help.
Kiwi Tinkerer is offline   Reply With Quote
Old 03-24-2013, 04:58 PM   #5
runnin4melife
Oddometer: 804
New suspension! You will not shed weight any where on the bike that is worth while, but getting a good suspension will make it much easier to manage!
runnin4melife is offline   Reply With Quote
Old 03-24-2013, 05:01 PM   #6
biodieselandon
biodieselandon's Avatar
Oddometer: 358
That's my goal. I figure I should be able to lose enough weight to offset all the farkles I put on. That's why I got a Bowflex
2013 BMW F800GS, Cordoba Blue, ASC, ESA, ABS
2012 BMW G650GS - 13,000 miles ***SOLD***
"If you're not mixing gas, you're not hauling ass!"
"A clean GS is a dirty shame."
biodieselandon is offline   Reply With Quote
Old 03-24-2013, 05:14 PM   #7
epicxcrider
epicxcrider's Avatar
Oddometer: 645
Somebody removed the abs system, saved a good bit of weight.
Old 03-24-2013, 09:20 PM   #8
sorebutt
Oddometer: 1,801
It is cheaper to buy a lighter bike than to buy a heavy bike and lighten it up. The 800 carries it weight well and feels lighter than it is. Maybe you should ride it for a while and then decide what farkles you need. Everyone has their favorites, but they might not be yours with the way you ride and places you go.
You could fill the tires with helium, but then it is hard to keep the rubber side down.
sorebutt is offline   Reply With Quote
Old 03-25-2013, 07:57 AM   #9
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,377
Get yourself a "Sponsor" who will deny you access to the Touratec catalogue or any others that may cause you to "fall off the wagon" and add protection weight after spending 2 Grand to make it lighter!
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 03-25-2013, 08:12 AM   #10
Casejeep
Casejeep's Avatar
Oddometer: 739
Ive cut close to 10lbs off my bike, but them put another 25lbs on, TT tank, Skid plate, Rear Rack, Side Racks, Tools...... so on and so forth.
MY F800 GS Build
Casejeep is offline   Reply With Quote
Old 03-25-2013, 09:36 AM   #11
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,852
Buying a lighter bike in the first place is the best revenge,adding a pile of parts then cutting pieces off the bike is one way to do things.
Maybe hack one cylinder off? Cut it right down the middle then get a machinist to make it into a real single cylinder.
All just thoughts.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 03-25-2013, 10:04 AM   #12
jengel451
1 Cool MotherF#$cker
Oddometer: 799
Per a previous comment. Getting your suspension dialed in, while not pulling weight off, will make your bike "FEEL" about 50 bounds lighter.
jengel451 is offline   Reply With Quote
Old 03-25-2013, 10:25 AM   #13
Blue&Yellow
but orange inside...
Blue&Yellow's Avatar
Oddometer: 754
Or if you're a rich man, give touratech a call:
Blue&Yellow is offline   Reply With Quote
Old 03-25-2013, 10:06 PM   #14
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
psh....
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 03-26-2013, 04:14 AM   #15
Blue&Yellow
Oddometer: 754
Originally Posted by Motorfiets View Post
psh....
Yes - I've seen it! Very nice work!
I think there is another one as well with twin headlights? Or was that yours before? Not sure.
Do you know if there is a guide or thread of this conversion being done somewhere? Would be an interesting read, I wonder how hard it is to relocate the instrument cluster and get it all working.
Times are GMT -7.   It's 12:08 AM.
