Old 03-24-2013, 09:27 AM   #1
MrPulldown OP
MrPulldown's Avatar
Oddometer: 3,255
wirelss bike computer as speedo
Figured that the thumper guys are the only ones that might even consider using a bike computer as a speedo. Has anyone tried using a wireless one. Seems like it would be easier to deal with. But I was wondering if the electronics from the bike would interfere with the signal. Anyone have an experiance they would like to share.
MrPulldown screwed with this post 03-24-2013 at 09:38 AM
MrPulldown is offline   Reply With Quote
Old 03-24-2013, 09:36 AM   #2
bisbonian
bisbonian's Avatar
Oddometer: 1,024
I looked into the wireless ones last year when my speedo went out on my Moto Guzzi.
If I remember it right there was a lot of opinion that the wireless may not work very well due to electrical interference.
I ended up using a standard bike computer but ordered up the extra long recumbent wire and mount to make sure it would cover the distance.
This has been working fine for almost a year for me.
My 2009 Alaska Adventure
bisbonian is offline   Reply With Quote
Old 03-24-2013, 12:03 PM   #3
Grreatdog
Grreatdog's Avatar
Oddometer: 11,396
Why go wireless? The wire on a Trailtech, Acewell or similar speedo is about unobtrusive as you can get. I can't remember the brand, but the little speedo/odo on my MXC is powered by watch batteries and goes for months. The only wire is the one down to the sensor.
525EXC, 640 Enduro, XT200
Grreatdog is offline   Reply With Quote
Old 03-24-2013, 04:25 PM   #4
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,050
A trailtech can run battery only, or hard wired....
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 03-24-2013, 05:32 PM   #5
k-moe
Oddometer: 2,696
I've used one, and they are......interesting. I used a http://www.walmart.com/ip/Bell-20-Fu...meter/17254766. At first it functioned well, though there is some lag between indicated speed and actual speed. It took mine about 2 seconds to settle in once I got to a constant speed. After a few months it would no longer give an accurate indication of speed above 30 MPH; it still worked fine below that. The inexpensive bike speedometers rely on a magnetic reed switch, instead of a Hall Effect sensor like the Trail Tech does. I think that on mine the reed switch simply began to fail due to flexing much more rapidly than the manufacturer intended.
k-moe is offline   Reply With Quote
Old 03-24-2013, 07:35 PM   #6
victor441
victor441's Avatar
Oddometer: 950
From what I've read many brands will not work at motorcycle speeds but Sigma's generally do....have not tried a Sigma on an MC but they have worked great on my bicycles. Another option I have tried is a Garmin GPS bicycle speedo and it works well, also records your track if you want to download it to a computer, Google maps, etc after the ride. Will run for many hours on its internal rechargeable battery but will probably wire up a mini USB feed on mine so battery life is not a concern...
victor441 is offline   Reply With Quote
Old 03-24-2013, 08:40 PM   #7
bisbonian
bisbonian's Avatar
Oddometer: 1,024
This is the one I've been running for almost a year now:
It's a Cateye Velo 5, this has been discontinued now but I think it was discontinued when I picked it up at my local bike store for about $25.
The specs say the max speed is 185mph, I have no fear of outrunning that.
Old 03-24-2013, 09:47 PM   #8
Kelly_O
Oddometer: 319
I use a Sigma wired unit. Watch battery once a year is all the service it requires. VERY accurate. About $17.
Kelly_O is offline   Reply With Quote
Old 03-25-2013, 10:22 AM   #9
MrPulldown OP
MrPulldown's Avatar
Oddometer: 3,255
What is wronge with the stock speedo?
I think that I am going to get a cheepo wired one, based on all of your comments. I have a wireless computer on the wifes bike (bicycle) and it is finiky.
No back light though. I guess I don't run at night too often.
Old 03-25-2013, 01:20 PM   #10
bisbonian
bisbonian's Avatar
Oddometer: 1,024
The original dash crapped out but I came up with a replacement. However the replacement dash is metric. While I can do the math sometimes I'm lazy and the bicycle speedometer was a cheap and easy addition.
Old 03-25-2013, 08:01 PM   #11
MrPulldown OP
MrPulldown's Avatar
Oddometer: 3,255
I would really want to run a vapor but funds are low right now. I think I found a cheap Ebay unit with a backlight and air temp.
Times are GMT -7.   It's 01:26 AM.
