Old 10-01-2014, 09:22 AM   #1
Test_rider OP
(Ultra)Sound Advisor
Test_rider's Avatar
Oddometer: 263
Tail light replacement Bulbs 2009 530EXC
I recently bought a 2009 530EXC. I am trying to find replacement light bulbs. I am not sure what type of tail light assembly it is and can't seem to upload a pic. However, after some research, I believe it is part of a "Euro Under fender and light Assembly" I believe the light part number is 7801404000. Does anyone know if you can buy replacement bulbs for this? I can't seem to find any.
When I got it, it appeared that 1 out of 3 bulbs in tail light were dead. However, still bright and brake lights worked. Yesterday I am down to 1 dim bulb and no brake lights. Maybe it's a connector issue or maybe it is the bulbs. Looking at pictures online, it appears there are quite a few more than 3 bulbs. I will be taking it apart this evening but was hoping I could get any info beforehand.
I tried to search for this on the forums and had no luck, so please forgive me if it is a easy question. Regarding the Search function, is there a place where I can get the rules. Seems adding +'s or "s doesn't change how it searches.
Test_rider is offline   Reply With Quote
Old 10-01-2014, 09:41 AM   #2
Test_rider OP
Test_rider's Avatar
Oddometer: 263
Got a photobucket account
Created a Photobucket account. Here is a pic of the assembly. Bike is running and lights are on in this pic.
Old 10-01-2014, 10:40 AM   #3
Grreatdog
Grreatdog's Avatar
Oddometer: 11,377
If it is incandescent I would just replace the whole light with an under fender LED unit. They are WAY brighter, pull less juice and seem to be pretty bulletproof. I bought a whole under fender unit for cheap, pulled just the tail/brake light off and added it to my 640. Baja Designs, Sicass, Traitech, etc. all have them or you can try a cheap eBay special like I did.
525EXC, 640 Enduro, XT200
Grreatdog is online now   Reply With Quote
Old 10-02-2014, 03:35 PM   #4
Test_rider OP
Test_rider's Avatar
Oddometer: 263
Removed light
I checked the plug to be sure there was voltage first. It was strange, went from -.1V at idle to+.6V revving. Only a single LED came on. I hooked it direct to battery and same thing, same single LED comes on whether powered through brake light or running light. Battery is at 13.3 V. Not sure what is going on there, but the result is the same. Light is definitely bad.
One thing I realized is that there is no license plate light. I'm trying to find a replacement that will fit in the Eurofender set up and has a license plate light, but no luck. Checked Sicass and Baja Designs so far.
Old 10-02-2014, 04:26 PM   #5
Test_rider OP
Test_rider's Avatar
Oddometer: 263
License Plate Lights
Here is a cool alternative for license plate lights that I found on eBay. They are bolts with built in LED's. May be kind of a hassle to install the plate at first, but then your good to go. Has anyone tried these? Search "LED License Plate Bolts" Form $5 to $15 per pair.
Old 11-26-2014, 02:44 PM   #6
Test_rider OP
Test_rider's Avatar
Oddometer: 263
Finally working on rear light again. The original KTM Euro Light (see photos above) is ridiculously expensive, and it has NO license plate light (Illegal here in Louisiana). I got this light from Baja Designs and did not realize that it fit the same fender except for the pointed out bracket. Does anyone have this bracket? Will save me tons from the fender or the original KTM light.
Old 11-27-2014, 01:59 PM   #7
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,150
Doubt that you'll find the exact same bracket sold / available separately.
It would be easier to go to your local home depot or some place where they sell L-brackets in small sizes. Buy two of them and bend them as required to mount your new tail light. Make a template out of cardboard (with markings for the holes) to find the right bracket at the hardware store.
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 11-28-2014, 06:08 AM   #8
Test_rider OP
Test_rider's Avatar
Oddometer: 263
I was thinking the same thing, Vicks, but realized they don't include the plug either with the individual light, only the fender assembly. How do I get the old plug off?
Old 11-28-2014, 06:13 AM   #9
Test_rider OP
Test_rider's Avatar
Oddometer: 263
BTW, I just read email from Baja Designs-they do sell the bracket. I asked them about the electrical plug and the cost.
Old 01-06-2015, 09:45 PM   #10
Test_rider OP
Test_rider's Avatar
Oddometer: 263
Baja Designs Light Installed
Just a followup. I was able to get just bracket and plug for the light. It fit perfectly onto the old Euro Fender without having to drill any holes. It is certainly bright and it has 3 white LEDs for license plate illumination. Baja Designs took the original fender/light combo back. The light and bracket came to about $40 with shipping. 1/2 the original and with license plate illumination. The light alone is $25 so if I need to replace it again, it will be cheap.
Here is picture with tail light only.
And here with brakes on.
And finally a night shot showing the plate illumination. Not great, but better than nothing.
Test_rider screwed with this post 01-06-2015 at 09:57 PM
Old 01-26-2015, 06:13 PM   #11
Ktmfanatic
Oddometer: 17
Good looking set up
Ktmfanatic is offline   Reply With Quote
Old 02-02-2015, 07:16 AM   #12
Test_rider OP
Test_rider's Avatar
Oddometer: 263
Thanks Ktmfanatic. I was really concerned initially about the price replacing the original . Can't beat the price of this one.
I was also concerned about mud getting in behind the new one because it is open. Yes,mud gets back there but it is easy to clean out.
Times are GMT -7.   It's 07:56 PM.
