Old 03-25-2013, 04:08 PM   #1
FredRydr OP
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,459
Low suspension F800GS - changes in the rear
Ohlins technicians in Hendersonville said on the phone today that there is no problem lowering the Ohlins forks in the front, except that there is insufficient latitude in the F800GS rear suspension for a shorter strut and spring, and still use the bike as intended.
Meanwhile, BMW comes out with a low suspension version of the F800GS for 2013. What gives? Was the 2013 frame changed to allow for more travel to lower the bike and not shorten the shock?
Fred
FredRydr is offline   Reply With Quote
Old 03-25-2013, 04:30 PM   #2
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 283
Fred
They just use a shorter spring, I think what Ohlin's is referring to is that lowering the fork sliders in the clamps does not change the travel but changing the shock or spring does.
I know that Touratech's extreme shock does have height adjust but it is independent of travel so you do not lose the off road capability.
For what it is worth I did the BMW Performance center enduro skills training and the only guy riding an F700GS spent the most time on the ground and really had the worse time navigating both the sand pit and the gravel pit, the skid plate literally bottomed out in front of me in the sand pit.
I was one of 2 riders on an F800GS, all other were on R1200G's and I went thru both with out any issues.
as to your question on the 2013 F800GS frame/swingarm it is the same as the F700GS, and should not have changed much vs. the 2009-12
Angryrican is offline   Reply With Quote
Old 03-26-2013, 12:06 PM   #3
LukasM
Oddometer: 5,426
The F650GS (and probably F700GS) shock is basically a shorter version of the F800GS with less stroke, both bikes have exactly the same frame and swingarm.
If you shorten the forks you can shorten the shock as well and keep the right geometry, as long as you reduce the stroke by an equal amount so that nothing bottoms out where it shouldn't.
Old 03-26-2013, 06:23 PM   #4
FredRydr OP
FredRydr's Avatar
Oddometer: 2,459
I didn't quite understand what the Ohlins factory techs were telling me about the limited ability to shorten an F800GS shock. They were discussing among themselves the problem with the F800GS set-up.
Next week, I am taking the bike to Hendersonville NC where it will be worked on by Dave Behrends. We'll see what the Ohlins expert can do to make my life easier while keeping enough suspension travel for me.
Fred
Times are GMT -7.   It's 08:56 PM.
