Old 03-26-2013, 08:54 PM   #1
Mr_Snips OP
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
Help Fast
I had an oil leak on my 2011 990 adventure.
Anyways it was the gear indicator thing that i was told. i dont see any oring in there at all yet thats what was recomended. Where is the oring supposed to go in there?
Originally Posted by Reprobate
Familiar. My stock response: "Most people die in bed. So, where do you sleep?"
Mr_Snips is offline   Reply With Quote
Old 03-26-2013, 09:09 PM   #2
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 823
Never seen it before no prior knowledge,, but I would guess the O-ring would go around the black part and fit into the chamfer around the hole the thing goes into.. Doesn't it have a retainer that bolts over the top? I'd expect a fairly thin o-ring with no groove.
Hopefully a well informed person will be of real help! :)
Dave
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is offline   Reply With Quote
Old 03-26-2013, 10:27 PM   #3
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
Part location #26
Part Number: 0770275025
Description: O-RING 27,5X2,5 NBR
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 03-26-2013, 10:27 PM   #4
zeegman
zeegman's Avatar
Oddometer: 387
Missing O-ring
Here you go!
Check your parts manual for parts you are not sure about. They show how things go together and every part on the bike.
MZ
zeegman is offline   Reply With Quote
Old 03-26-2013, 10:40 PM   #5
Mr_Snips OP
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
Well i found the old o ring and reused it...cleaned up the mating surface and the o ring so we will see if it works.
I saw nothing wrong with the o ring so we shall see.
Old 03-26-2013, 10:48 PM   #6
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,167
Unfortunately, that's how it usually is- it just takes a bit of a square shape or something, and leaks just a bit. At least now you know how easy it is to replace.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 03-26-2013, 10:50 PM   #7
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
In past experience, if a O-ring has begun leaking, it will continue to do so because it is most likely permanently compressed. I have solved this issue previously with a light application of sealant grey silicone (yamabond) to the O-ring sealing surfaces, light application of sealant to the body of the switch body, then reassemble.
Old 04-05-2013, 10:23 AM   #8
what car??
down the road
Oddometer: 372
So senior snips, did you reuse the old "o" ring? What were the results? I'm experiencing a similar situation, though mainly leaks a little when bike is on it's side stand, typically overnight. Haven't really found it leaking when on the center stand... Maybe a silly question, did you lay it on the side to prevent oil from spilling out or is there little worry about that possibility unless the engine is running?
Thanks...
what car?? is offline   Reply With Quote
Old 04-05-2013, 12:01 PM   #9
Mr_Snips OP
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
I just changed the oil when I did it. I cleaned the o ring and mating surfaces and reused the same on. Still no leak. It's probably best to use a new I ring but I used what I had and it worked.
Old 04-05-2013, 06:44 PM   #10
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,283
This might help: http://advrider.com/forums/showpost....&postcount=103
Orangecicle is offline   Reply With Quote
Times are GMT -7.   It's 09:52 PM.
