Old 03-28-2013, 01:06 AM   #1
dvebe9 OP
Blarg Honk
dvebe9's Avatar
Oddometer: 14
3D Printers and Protective Parts?
Just curious if anyone has investigated using 3D printers to fabricate some of the smaller protective bits on a bike?
E.g. Brake resevoir's, hand guards, headlight protector etc.
That which we obtain too cheap, we esteem too little.
Blarg Honk
dvebe9 is offline   Reply With Quote
Old 03-28-2013, 01:11 AM   #2
madefrtv
madefrtv's Avatar
Oddometer: 427
sounds like a cool idea. I wonder if the material that you print 3d in would be useful for absorbing impact or just for rapid prototyping?
whoa, dude...
madefrtv is offline   Reply With Quote
Old 03-28-2013, 01:13 AM   #3
mousitsas
mousitsas's Avatar
Oddometer: 2,728
I think its a great idea as long as the material is tough, which I believe it is.
mousitsas is online now   Reply With Quote
Old 03-28-2013, 01:15 AM   #4
dvebe9 OP
Blarg Honk
dvebe9's Avatar
Oddometer: 14
You can apparently use ABS plastic (Same stuff they make Lego out of), hence the smaller bits less likely to take a significant hit than a bash plate or crash bars.
Blarg Honk
Old 03-28-2013, 01:45 AM   #5
mousitsas
mousitsas's Avatar
Oddometer: 2,728
These Lego are indestructible. Good info!
Old 03-28-2013, 09:14 AM   #6
juun
Oddometer: 23
i've been interested in 3D printing and hopefully obtaining one someday. I guess the main issues have been types of lasers used to have the plastics dense enough to withstand abuse. Also the time it takes to print some parts can take hours or days.
juun is offline   Reply With Quote
Old 03-28-2013, 09:17 AM   #7
munchmeister
Grow'd Up Mini Trail
munchmeister's Avatar
Oddometer: 1,382
Munchmeister
2002 R1150GS - It's not about the knockdown, it's about the recovery.
munchmeister is offline   Reply With Quote
Old 03-29-2013, 05:17 AM   #8
JRWooden
Oddometer: 4,232
Saw a video the other day where a guy made a fully functional lower receiver for an AR-15 with a 3D printer (likely one of the more expensive units )
I think the day is coming soon and may already be here for some parts ...
Depending on tolerances required it can take a long time, but for most brackets, and protective bits the tolerances can be pretty loose (from the machine's perspective) and still make a part acceptable to a guy that's going to go cover it up with mud anyway ... which speeds up process time quite a bit...
I have a buddy that built his own unit, as soon as I get my taxes done I'm gonna go pester the hell out of him about it.........
JRWooden screwed with this post 03-29-2013 at 05:28 AM
Old 03-29-2013, 08:26 AM   #9
Plaka
Brevis illi vita est
Oddometer: 4,588
Expensive and fragile. The machines are even more expensive and very vibration sensitive, so special installations. Then you need a Solid modeler (3D CAD solids modeler) and software to translate the CAD into machine code for the stereolithography unit....
If you are making a model for a production run of a hundred thousand, yeah. One offs? No.
An injection molding machine can make 20 or more brake reservoirs in a single 45 second cycle...
Old 03-29-2013, 08:46 AM   #10
scarysharkface
30-125
scarysharkface's Avatar
Oddometer: 13,026
Are you kidding? The beauty of 3D printing is that one-offs don't require extensive building of molds and such. If you look around, there are sites sharing CAD files that are pretty much ready to go. Sure, it's not economical if you're only going to build a single piece for yourself, but I work with a guy who uses one for pretty much anything that pops into his head that he can draw..
John
The road to Hell is paved...
Save $5 on a Smugmug subscription when you use my coupon:
yBr7OofIPuOP6
Another '98 DR350 for sale http://advrider.com/forums/showthread.php?t=1036981
scarysharkface is offline   Reply With Quote
Old 03-29-2013, 09:11 AM   #11
markk53
jack of all trades...
markk53's Avatar
Oddometer: 8,379
John
See one operate first. Great for rapid prototyping is the key here. Prototype doesn't always mean 100% functional.
These machines build in layers, imagine thousands of small seams to create thousands of stress risers. The process is no where near as good as a seamless injection or even roto molded part.
The ones that are getting big media attention are fine to make low stress parts and all, but no where near as functionally sound as a regular manufacturing process at this time.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 03-29-2013, 09:31 AM   #12
Off Road Ryder
Off Road Ryder's Avatar
Oddometer: 2,447
Mark53 is right on the money here.
Prior to getting into the lighting biz. I managed a RP service burrow for the largest provider and manufacture of equipment around, 3D systems.
The thought that you can pop a part off of the platform that will be usable is a fallacy to say the least.
Typ they are used for design reviews, sales presentations or to make patterns for RTV mold on limited production runs.Even then there is a ton of hand or machine work that goes into a good part.
There are some machines that will make alloy parts, even titanium, however the parts are still relatively weak compared to the real McCoy,s and require a lot of Hand/machine work to be useful.
You cant believe everything you read on the interweb.
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 03-29-2013, 09:37 AM   #13
Plaka
Oddometer: 4,588
I saw some eyeglass frames done on one. They looked decent, but weren't strong enough for use.
last company I worked for just bought a pair of them for prototyping. 100 grand each. And they make small handheld medical tools.
However there are a number of techniques that are pretty easy at home. For a reserviour you can cast it in epoxy or polyester from a silicone mold made from a hand made pattern or an old (and damaged) part. You can also hot bend plastics and vacuum form them at home. You can make a handguard out of fiberglass/epoxy that is close to unbreakable. Ditto complx shapes for bash pans. A 3/8" fiberglass plate is as strong as a steel one, lighter and easy to maintain. Doesn't have some of the virtues of steel but doesn't have some of the liabilities either. And it's easy to fabricate.
Old 03-29-2013, 02:15 PM   #14
scarysharkface
30-125
Oddometer: 13,026
I've been supporting these things at work for 10 years or so. I've seen what can be done.
John
yBr7OofIPuOP6
Old 03-29-2013, 02:24 PM   #15
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,559
There is one at a Tech Shop, it's pretty cool, I've seen some neat things being made, but no way are they strong enough for crash protection. Maybe it's the plastics they are using but everything I have seen is very delicate off that printer.
Cool for a quick prototype to hold in your hand and check fit etc before committing to a real part but not what I would trust for actual parts even if one off for yourself.
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Times are GMT -7.   It's 10:54 PM.
