Old 03-28-2013, 06:19 AM   #1
motog OP
Oddometer: 90
Dual purpose tires on a R75/5
My R75/5 scrambler project is coming along nicely and now it's time to look at some dual purpose (or dualsport if you like) tires.
Tire sizes are: 3.25x19 front 4.00x18 rear.
I've been doing a lot of looking around and a fair bit of internet research but I've hit a bit of a problem: clearance to the swingarm on the R75/5 is tiny. I'm currently running Metzeler road tires and there is less than half an inch clearance. Putting most dual purpose tires on there may not work. I don't want to shell out money for tires that won't fit.
Has anyone else done this? What did you use? Any problems with swing arm clearance?
Background: I probably do 50-60% riding on roads. The road tires are ok on tight dirt or good gravel but are just plain scary on loose surfaces or mud/clay. I'd like to be able to increase the ability to ride on less certain surfaces. I'm not expecting to keep up with the KTMs.
Any advice gratefully accepted. Thanks
Jim
motog is offline   Reply With Quote
Old 03-28-2013, 06:24 AM   #2
east high
east high's Avatar
Oddometer: 955
A while back there was a thread about a few dudes on /2s with dirt tires. They were using Shinko 244 and Continental TKC-80.
'71 r75/5
east high is offline   Reply With Quote
Old 03-28-2013, 06:51 AM   #3
khale
ride dirty
khale's Avatar
Oddometer: 557
Jim
Don't you know you have to post pics in order to get advice?
2013 BMW R1200 GSW | 1972 BMW R75/5 toaster | 2011 Husky TE310
"4 wheels move the body, 2 wheels move the soul"
khale is offline   Reply With Quote
Old 03-28-2013, 07:12 AM   #4
motog OP
Oddometer: 90
Pics
Ok. This is an older pic - much has changed since then, but you get the general idea.
east high: Unfortunately I can't seem to find the Shinkos in Australia but I'll look into the TKC80s. Thanks
Jim
Old 03-28-2013, 07:27 AM   #5
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,708
http://www.motorcycletyres.net.au/ty...ari/index.html
Have a look at the E07
129/80 18 clears the swing arm on R65s and R100 fat swing arm so should fit R75
100/90 19 is not a fat tyre and has a moderately steep Crown Radius Section so your fine control and tip in is not compromised.
TKC hook up on the edges better on loose surfaces once you start power sliding and are better but not great in muddy conditions.
The E07 will outlast the TKC are cheaper and handle much better on the road especially in wet conditions.
It's also much quieter on the road, TKCs are almost as loud as a full knobby
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 03-28-2013, 01:59 PM   #6
ed mocz
Bristol WI
ed mocz's Avatar
Oddometer: 211
I've got these on mine and I've had them on a GS. They work fine for me.
http://www.heidenautires.com/dual-sport-tires/k60scout
1978 BMW R100/7 A holy union/cheap bike challenge combo. 1975 Honda TL250.
ed mocz is offline   Reply With Quote
Old 03-28-2013, 02:29 PM   #7
ME 109
ME 109's Avatar
Oddometer: 3,135
For the rear at least, Metzeller enduro 2, 4:00/18 A decent looking lug dual purpose.
No Metz for the front that I have seen, not to say there isn't one.
Avon Distanza has 4:00/18, 4.1/18, and 100/90/19 for the front. Not too luggy tho'
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 03-28-2013, 04:24 PM   #8
Gillus
High Desert Rat
Oddometer: 900
Shinko 705 in a 4.10 X 18 and a 110/80 -19. I did not research size changeover but the 705 may work very well for you if it'll fit.
Disclaimer: I am only responsible for what I said........... Not what you understood or how you interpreted my words!!
Gillus is offline   Reply With Quote
Old 03-28-2013, 04:44 PM   #9
blaine.hale
blaine.hale's Avatar
Oddometer: 3,267
I run heidenau k60 scouts on my r90. They're great. Not so great in the rain, though.
1974 BMW R90 /6 | 1968 Bultaco Matador MK3 | 1973 BMW R75 /5 Toaster LWB | 1966 Ducati 250 Monza | 1976 Ducati 860 GT | 1977 Moto Guzzi LeMans 850
blaine.hale is online now   Reply With Quote
Old 03-29-2013, 07:22 AM   #10
chasbmw
Oddometer: 2,350
Back in the day I used Dunlop K70s or Goodyear DTs,mthey gave a little more grip on muddy south American roads.
Charles
1971 Commando Fastback
Old 03-29-2013, 07:55 AM   #11
Gillus
High Desert Rat
Oddometer: 900
Old 03-29-2013, 11:32 AM   #12
red bud
alky w/motorcycle problem
red bud's Avatar
Oddometer: 6,080
avon distannas
"if your not outta gas, your not lost" BDXMPL
"red bud has anyone ever told u you're bit of an ass" bmwblake
http://www.advrider.com/forums/showthread.php?t=706516
red bud is offline   Reply With Quote
Old 03-29-2013, 02:45 PM   #13
moosehead
moosehead's Avatar
Location: south of the checkerboard....Bruce Penninsula
Oddometer: 276
Ran a set og Bridgestone Trailwings on my beater 1981 R100...for the backroads
Worked great on/off asphalt and pretty good in the wet:
Front 110/90-19 - ran at 36psi
Rear - 120/90 - 18 - ran at 32 psi
Were no rub issues front or rear.
retired from work - not life
moosehead is offline   Reply With Quote
Old 03-29-2013, 04:28 PM   #14
Beemerboff
Oddometer: 2,348
Mitas E07s on the G/S, work fine wet or dry, road and dirt, and last at least 50% longer than anything else I've tried.
Will eventually have them on everything.
Dunlop TT100s on the R75/7 & B44 , suprisingly good on gravel roads for what looks like a road tire.
Distanzas, and Mitas E08s, work great too, but the Avons are $100- a pair more than E08s in Oz, and neither last like the E07s.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 03-29-2013, 05:06 PM   #15
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,619
I'm using Dunlop K180's, they are 120-90x18, but they do a 100/90 too. Not as good as the K70 in gravel, but better off road and seriously good on seal and wet roads. But they won't last long, I've lost 2mm in 900km.
motu is offline   Reply With Quote
Times are GMT -7.   It's 03:35 PM.
