Old 03-28-2013, 01:39 PM   #1
DesertQben OP
Oddometer: 15
oil tank drain plug, crush washer, or oil ring???
I'm in the middle of my first oil change on my new to me 2005 950 Adv. After using 5 old t-shirts, 5lbs. of kitty litter, 1 roll of paper towels, and a can of contact cleaner to clean up this mother of a mess, I forgot if there was a crush washer or an o-ring on the oil tank drain plug? Orange Crush please HELP!!
DesertQben is offline   Reply With Quote
Old 03-28-2013, 01:41 PM   #2
stevodadevo
What happened?
stevodadevo's Avatar
Oddometer: 177
My 990 has one. I forgot it one time and the oil leaked.
stevodadevo is offline   Reply With Quote
Old 03-28-2013, 01:45 PM   #3
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 730
Copper washer on my 950.. :) Both the engine and the oil tank..
Cheers,,
Dave
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is offline   Reply With Quote
Old 03-28-2013, 02:16 PM   #4
keener
Speed changes you.
keener's Avatar
Oddometer: 925
+1 Copper washer. Replace or at least flip it.
Once I forgot to replace it and development and a slow leak in Moab. Had to put a new washer in, on the side of the road with my finger on the drain hole, and hot oil of course. Lesson learned.
04 ADV 950
keener is offline   Reply With Quote
Old 03-28-2013, 02:21 PM   #5
DesertQben OP
Oddometer: 15
Thanks!! found the copper crush washer in the old oil!
Old 03-28-2013, 02:22 PM   #6
KtmPedro220
KtmPedro220's Avatar
Oddometer: 69
Originally Posted by pdxmotorhead View Post
copper washer on my 950.. :) both the engine and the oil tank..
Cheers,,
dave
+1
KtmPedro220 is offline   Reply With Quote
Old 03-28-2013, 02:44 PM   #7
barbwire44
barbwire44's Avatar
Oddometer: 118
dont forget to heat the crush washer up with a propane torch to a nice orange glow, quench with water and re-install.
Doing the right thing is not always the easiest thing to do. (J.J. 2012)
13 KTM450,08 KTM200,GASGAS EC200,Guzzi Quota 1100es, DRZ400, 1200HD,
barbwire44 is offline   Reply With Quote
Old 03-28-2013, 03:34 PM   #8
stevodadevo
What happened?
Oddometer: 177
What's this do?
Old 03-28-2013, 04:06 PM   #9
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,024
Swells it a bit and makes it malleable so it crushes again.
Though I just reuse the old one as is with no issues.
Crush it, Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 03-28-2013, 08:40 PM   #10
hennessyktm
Oddometer: 39
Heating the crush washers with a torch
+1 on heating the crush washers with a propane torch and quickly cooling them off in water. I have been doing that with the same washers for the last few oil changes and have had zero issues/leaks. Quick, easy, and free...can't beat that!
hennessyktm is offline   Reply With Quote
Old 03-28-2013, 11:17 PM   #11
pdxmotorhead
Oddometer: 730
Originally Posted by stevodadevo View Post
What's this do?
Its called anealing it reduces work hardening of brass and copper and some softer alloy steels. You don't have to go full orange,,, just wait for the bloom of hte color change then quench,
Dave
Old 03-30-2013, 12:14 AM   #12
rattis
rattis's Avatar
Oddometer: 1,128
Question size
What is the size of them little washers?
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, double up now, a 990Adv and a 950 SER
rattis is offline   Reply With Quote
Old 03-30-2013, 07:31 AM   #13
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 639
Dave
You don't have to quench it, but you can handle the washer right away. Heating to red is required to properly anneal copper. Every time you reinstall your drain bolt, that 'crushing' process hardens the washer, so heating it to soften is a good idea. Every time your reuse your washer it will get a little thinner & wider, except for that, you should be able to reuse it indefinitely.
HeatXfer is offline   Reply With Quote
Old 03-31-2013, 11:37 AM   #14
keener
Speed changes you.
keener's Avatar
Oddometer: 925
The size is listed in the parts list.
04 ADV 950
Times are GMT -7.   It's 04:07 PM.
