Old 03-31-2013, 08:32 AM   #16
a.c.s.
Complaining less
a.c.s.'s Avatar
Oddometer: 244
Originally Posted by billdonna View Post
Mice love to nest in the air snorkel. Make sure your air intake is clear!!
Originally Posted by Pickup man View Post
I concur with bildonna, mice love to sneak in the garage over the winter. I usually put steel wool at the entrance of the air intake snorkel when not riding the bike for a while. Just have to remember to take it out again!
Try using a 1/4" steel mesh screen over the snorkel. It keeps mice and crap out + it can be left in place year round.
Air snorkel is clear...
The place to improve the world is first in one's own heart and head and hands - R. M. Pirsig
Semper Fidelis
a.c.s. is offline   Reply With Quote
Old 03-31-2013, 09:58 AM   #17
a.c.s.
Complaining less
a.c.s.'s Avatar
Oddometer: 244
Problem solved!
Observations:
1. By twisting the throttle all the way while cranking, the bike sounded like it would start. Then, it started up.
2. There is an exhaust leak where the pipes meet immediately after the exhaust flap.
3. Let it idle for a few minutes, took it for a ride around the block, shut it down and it started right back up.
Hypothesis:
Fuel system blocked from sitting.
Anomalies:
Spraying starting fluid into the fuel injector ports did not cause the bike to start and caused me to discount the fuel system hypothesis; this could be from a failure in my method. Therefor, the hypothesis was derived from observations - FU NIH and your hypothesis driven research!
Conclusions:
The motorcycle runs and likely did not start due to a fuel system blockage - before storing it next time, run a tank of gas with SeaFoam before storing it for the winter. Tests could not confirm where in the system it was blocked. The exhaust leak needs to be fixed at some point, but is likely independent of the starting issue.
Semper Fidelis
a.c.s. screwed with this post 03-31-2013 at 01:34 PM
Old 04-01-2013, 03:25 AM   #18
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,068
I should have been more specific. The mice use the air snorkel as an entry point to the airbox and filter area to build their nest.
The snorkel can be clear, but you may have tenants in the box
How about the OP egwags...how`d you make out?
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 04-01-2013, 05:03 AM   #19
a.c.s.
Complaining less
a.c.s.'s Avatar
Oddometer: 244
Ahh... Air box is clear too... Thanks!
Semper Fidelis
Old 04-01-2013, 03:50 PM   #20
Pickup man
Location: People's Socialist Republic of Ontario, Toronto
Oddometer: 289
Im glad you got it sorted. I put seafoam in the tank for my last couple of rides before storing. I also start the bike and let it run for a bit at least once every 4 weeks during the winter.
Pickup man is offline   Reply With Quote
Times are GMT -7.   It's 03:32 AM.
