Old 03-29-2013, 12:20 PM   #1
1bigrn OP
Oddometer: 199
XR650R front wheel off to one side.
My xr650r front wheel is approximately 1.25 cm closer to the brake side than the other side, It runs straight put is just closer to one side and the brakes don't bind in anyway.
I just recently replaced the front speedometer assembly with the XR's Only speedometer drive replacement kit (Spacer). It was pretty straight forward and I am fairly handy with a wrench.
The only thing I can possibly think I did was put the brake side spacer in backwards. But I don't think that would have made a difference.
Any thoughts?
1bigrn is offline   Reply With Quote
Old 03-29-2013, 03:47 PM   #2
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,417
Here is a link to some XR650R pics: http://www.xr650rforum.com/t510-cool-xr650r-pix Hopefully, one of them will help answer your question.
I recommend taking some photographs of your bike before you work on it so this type of question never needs to be asked again. Good luck!
Stan_R80/7 is offline   Reply With Quote
Old 03-29-2013, 04:18 PM   #3
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,229
the first thing to do is measure your forks, they need to be parallel to each other. if they are farther/closer apart at the bottom you know you have spacer issue, if they are parallel then you have a wheel truing issue.
2 SPOT is offline   Reply With Quote
Old 03-29-2013, 07:55 PM   #4
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,820
The right side spacer is integral with the axle, it must be allowed to be as much of a spacer as is needed on the right side. It you tightened the pinch bolts on the right side before you tightened the axle, you could have pulled the right fork over when you shouldn't have.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Times are GMT -7.   It's 07:04 PM.
