Old 03-30-2013, 09:00 AM   #16
rwf
rwf's Avatar
Oddometer: 125
Are you saying the chain is too long? Are you saying they made the links shorter to sell more links? The links will be made to a standardized dimension.
"I was going faster than I ever went in my whole life, then I fell off." Little Fauss
rwf is offline   Reply With Quote
Old 03-30-2013, 09:32 AM   #17
StuartV
Motorcyclist
StuartV's Avatar
Oddometer: 1,432
LMAO!! I don't know if notrivia is jerking our chains (pun intended) or a clueless nimrod. Either way, this thread is hilarious! :sly::sly:
- Stu
'09 R12GS, '05 GSX-R1000
Iron Butt # 4999, WERA/CCS EX # 666 (currently, expired), AMA Life Member
Racer, Drummer, Bassist, Software Engineer
StuartV is offline   Reply With Quote
Old 03-30-2013, 10:43 AM   #18
notrivia OP
Oddometer: 62
It's an endless chain ...
Hey RWF and Max -
Yes, RWF, I am saying that they are incrementally increasing the size of each link so that the adjustment cycle will be shorter so they can sell more chain.
And Max, this is my 4th chain. The stock chain got me 33,000,
my second was a Regina which gave about 18,000- but I was traveling a lot and did not give it the care it deserved. My third was reportedly the stock DID with sunstar sprockets, about 8,000, lovingly cared for. I noticed at installation the adjustment was in the middle. The EK X-Ring doing the same has prompted this "investigation". I also went back to the stock sprockets ...
I've e-mailed both Regina and EK with precise information, and especially asked EK to "explain the technical fact that causes the chain to be in the middle rather than the start of the adjustment mark".
THANKYOU FOR YOUR COMMENTS.
notrivia is offline   Reply With Quote
Old 03-30-2013, 12:27 PM   #19
Railbender
Oddometer: 1,038
Did you replace both sprockets at the time you installed the new chain? If not that may account for your problem.
The shortest distance between two points is boring.
Railbender is offline   Reply With Quote
Old 03-30-2013, 12:32 PM   #20
notrivia OP
Oddometer: 62
A link too many
Yes, Railbender, everything is as it should be, correct sprockets with the right tooth count, and stock chain link amount. And my version is the "N" Max.
Old 03-30-2013, 01:40 PM   #21
06CCDMAX
Johnny 2-Stroke
06CCDMAX's Avatar
Oddometer: 20
Never seen an adjuster start out RIGHT at the beginning, there's intentionally some extra so you can... Wait for it... Adjust. What matters is the length between links. There's a wear limit your manual will recommend, probably measuring 10 links. Reaching the end of the adjuster has nothing to do with it. You will probably exceed that limit before you exceed your adjusters. If you do reach the end of the adjuster and still have good life in the chain, remove one link, adjust, and ride on.
2012 KTM 300XC Plated Dirtbike Ring-Ding-Ding
1974 RD250 Got on trade for XS400 (That I bought for $50 )
1975 RD350 Bought for parts, but wanna put on road now.... 1984 RZ350 Why not?
"I run on Caffeine and Klotz. Beer is a bonus
Originally Posted by kenny61 View Post
You wanna tag some poles together?
06CCDMAX is offline   Reply With Quote
Old 03-30-2013, 02:04 PM   #22
kingby
Oddometer: 87
^^^^this
Chain wear has nothing to due with the position of the adjusters. The adjuster allows some leeway for stretch and sprocket changes (while giving you way to maintaining chain tension), but are not an indicator of a warn chain. It sounds like you are trying to use it as a wear indicator???? Install with adjustors all the way in, and ride it until there is no adjustment left??? Be prepare for a broken chain if this is the case (and all the bad things that may happen when it snaps).
Or as they say... are you pulling our chains??? Little early for April fools isn't it?
kingby is online now   Reply With Quote
Old 03-30-2013, 03:07 PM   #23
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,680
I have to say that the amount of fail in this thread is EPIC!
Old 03-30-2013, 03:19 PM   #24
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,666
Wtf? The op has ridden more miles and owned more bikes than most of you combined. If he says there is something wrong then I would believe him. Personally I think it maybe a swingarm problem. As a bend or worn bearings would make it effectively shorter and causing the too long problem. If you don't have anything to offer why don't u take it to the basement
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 03-30-2013, 03:47 PM   #25
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,391
Maybe Suzuki starting making the swingarms shorter to save materials and cut costs. This would really fry my ass,,,, paying for a whole swingarm and getting shorted!!!!
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 03-30-2013, 04:22 PM   #26
Warin
Retired
Oddometer: 2,212
As sensible people have said in past posts
Chains are made to a standard.
Chain ware of 3 to 5% is taken as the maximum ware... so any chain made approaching that would be shunned by the market.
The OP should MEASURE their chain.. rather than assume. Maybe looking at a brand new bike may help?
Measure 9 links - should be 5.625 inches... use a vernier caliper for resolution... a motorcycle mechanic may have a dedicated gauge to check chain ware ...
Warin is offline   Reply With Quote
Old 03-30-2013, 04:48 PM   #27
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,602
my dad was a machinist I may have to break out some of his measuring tools and verify whats going on..does anyone have a link to what the standard is?
What, a ruler? The pitch is 5/8", it's pretty easy to check. Measure this bad boy and multiply . . .
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 03-30-2013, 04:50 PM   #28
sieg
sieg's Avatar
Oddometer: 2,853
+1
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 03-30-2013, 04:58 PM   #29
baloneyskin daddy
bikaholic
Oddometer: 2,158
Maybe he got one of them new fangled pre stretched chains.
baloneyskin daddy is offline   Reply With Quote
Old 03-30-2013, 05:03 PM   #30
victor441
victor441's Avatar
Oddometer: 961
Another way that works is to measure a length that will be an even number of links....for 5/8 pitch chain 15" will be 24 links.....if the distance grows to 15 3/8" it has elongated 2.5% and the chain is about due to be replaced. This much wear would lengthen the entire chain about 1 3/4" and require the axle to be moved back about 1/2 that much from new to adjust for wear, about 7/8" (but as was said the bike manufacturers spec for wear should be used)
victor441 is offline   Reply With Quote
Times are GMT -7.   It's 06:29 PM.
