Old 03-29-2013, 06:27 PM   #1
pkboxer OP
Oddometer: 91
krauser bags - safety strap
I recently bought/installed the old style Krauser bags on my r90/6.
With the infamous seat belt latch.
I plan on adding a safety straps.
Have seen images of a strap running vertically keeping the bags on the racks and the bags closed.
Any suggestions or images showing how people have attached the straps to the racks?
pkboxer is offline   Reply With Quote
Old 03-29-2013, 06:33 PM   #2
DaveBall
DaveBall's Avatar
Oddometer: 1,163
Most people just wrap the strap around the whole unit, bag and mount. Some use a cinch type strap and other use a velcro type. A few just use rope.
DaveBall is offline   Reply With Quote
Old 03-29-2013, 07:02 PM   #3
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,494
I use parachute cord and tie a truckers' hitch just to piss the purists off.
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is offline   Reply With Quote
Old 03-29-2013, 10:21 PM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,543
---Albert Einstein
Old 03-29-2013, 10:41 PM   #5
Plaka
Brevis illi vita est
Oddometer: 4,612
Don't attach the straps to the rack. if you need it for something more desperate it's nice to get it off.
I rigged straps to my brothers rooftop aero-crap-carrier. it blew open on him once on the highway. because it's high up and opens even higher, we rivited strap retainers to the plastic so when he opened it he wouldn't lose the far end of the strap.
I can do a pic if you need one. It's a small metal bar on short legs with holes for bolts in the legs. hat shaped in profile. About an inch and a half long with 1/4" underneath it.
Old 03-29-2013, 11:04 PM   #6
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,273
I've made up four webbing straps, with a 'D' loop at each end. Two have cinch buckles at the other end, two don't. Loop one of each pair on the top & bottom rails (long end on the inner side of each rail), clip in the bags, run the top strap under the handle, & then cinch up that to the bottom strap. The D-ring on the straps with the buckle has to be large enough to pass the buckle through. The entire set up has the advantage of tightening the bags on the rails too.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits screwed with this post 03-29-2013 at 11:15 PM
Box'a'bits is online now   Reply With Quote
Old 03-29-2013, 11:50 PM   #7
squish
Out of the office.
Oddometer: 6,267
BMW motorcycle crate tie down straps with the cam buckle.
Old school BMW shops still sell em.
Wrap them around the frame and bag, they are long enough to do a double wrap around the bag frame.
On vacation for a spell
squish screwed with this post 04-03-2013 at 12:05 AM
squish is offline   Reply With Quote
Old 03-30-2013, 12:58 AM   #8
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,521
The buckles are those plastic push & click type. The straps are sturdy. I suspect I had too much tension on the buckle, forcing the opposing sides together against too much tension. Dodged a bullet, just last weekend.
boxerboy81 screwed with this post 03-30-2013 at 07:34 AM
boxerboy81 is offline   Reply With Quote
Old 03-30-2013, 01:01 AM   #9
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,521
Wrap them around the frame and bag, the are long enough the doa double wrap around the bag frame.
Saw a bloke last year that's still using his set from the '70's.
Old 03-30-2013, 01:53 AM   #10
advNZer?
advNZer?'s Avatar
Oddometer: 2,886
i have still got four from my then brand new k100rs
aka BMWST?
advNZer? is offline   Reply With Quote
Old 03-30-2013, 07:12 AM   #11
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,513
Suitcase straps.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 03-30-2013, 07:36 AM   #12
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,521
Same buckle I have one my straps David. See my pix above. I think I had them on too tight, encouraging one to come apart.
Old 03-30-2013, 07:50 AM   #13
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,513
It took me ages to get them just right; luckily once set, they don't need further adjustment.
David Hunn:
Old 03-30-2013, 07:57 AM   #14
ML WYDELL
NED
Oddometer: 498
I have been using ratchet tie down straps which double as something to throw my tarp over or securing the bike on a trailer if something happens.
ML WYDELL is offline   Reply With Quote
Old 03-30-2013, 08:45 AM   #15
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,675
Where the hell would you start with one of those?
Rob Farmer is offline   Reply With Quote
Times are GMT -7.   It's 01:06 AM.
