Old 03-29-2013, 08:37 PM   #1
FINNDIAN OP
Mine goes to 11
FINNDIAN's Avatar
Oddometer: 1,740
Fcr problem. suggestions welcome.
39fcr kit
The base threads into the carb body. This one must have been loose for some time. Now threads are worn of both sides. Anyone seen this before?
Thinking the only solution might be a whole new carb.
Sent from my Droid RAZR using tapatalk 2
The more side roads you stop to explore, the less likely that life will pass you by. ~Robert Brault. 2004 KTM 950 S GO!!!!(Blacked out),03 Beta Rev3, 1973 Rokon Trailbreaker 2x2, 1999 Intruder 1500, 08 Aprilia rxv450, 90 DRBIG 800,79GS850
Ride Reports
FINNDIAN is offline   Reply With Quote
Old 03-29-2013, 08:49 PM   #2
Idle
Oddometer: 703
JB Weld!
Idle is offline   Reply With Quote
Old 03-29-2013, 08:53 PM   #3
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 644
I can't tell from the photo, but are the threads in the carb body as bad as the spigot? If the receiving threads in the carb aren't worn too bad a new spigot could be carefully threaded on with a little blue loctite 242?
.2
HeatXfer is offline   Reply With Quote
Old 03-29-2013, 08:59 PM   #4
FINNDIAN OP
Mine goes to 11
FINNDIAN's Avatar
Oddometer: 1,740
no. It's very bad on both sides. no interferance fit. very loose now.
How is jb weld with gas and vibes? It'll take a lot
Ride Reports
Old 03-29-2013, 09:37 PM   #5
CRW
I dont want a pickle
CRW's Avatar
Oddometer: 805
Maybe Devcon instead of JBweld. seen a lot of internal engine repairs done with it......
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
CRW is offline   Reply With Quote
Old 03-30-2013, 07:47 AM   #6
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 644
Were you thinking Devcon Titanium putty? That stuff is great. I've used it for gap filling between shafts and bearing races, filled in surface imperfections on rotating stock and I've used it instead of Helicoil inserts on emergency equipment repair. It is a little pricey - $120/lb, but it lasts a long time in the can and you'll find a million uses for it once you've tried it.
If both surfaces are thoroughly wire-brushed to clear any loose aluminum out of the remaining threads and roughen the other contact surface areas, that would give the putty a lot of rough surface to adhere to and once cured would be nearly the same a weld.
Old 03-31-2013, 05:26 AM   #7
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,120
That, or get it welded. A good welder can probably do that nicely with very low amps. Meight have to do some specialized cleaning before though, good idea with epoxy as well.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 03-31-2013, 11:10 AM   #8
CRW
CRW's Avatar
Oddometer: 805
Yup that's the stuff. It is pricey for sure. I have found it in small tubes at O'rileys auto parts (old Kragen).....
Welding that would be very tricky.... But what do I know I'm a welder/fabricator by trade..... The carbs are an expensive peice of kit if I recall correcttly.
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
Old 03-31-2013, 11:19 AM   #9
CRW
CRW's Avatar
Oddometer: 805
Just a thought. Find a gas resistant material and make a gasket to bush between the surfaces and drill and tap. Tap the material that has the most thickness(looks like the carb body).
Or bring it by a decent machine shop to see what they can offer.
EXPLORE ALL OPTIONS BEFORE FLIPPING THE CASH FOR NEW CARBS!!!
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
Old 03-31-2013, 01:47 PM   #10
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 730
If you can buy the new piece with fresh threads, then clean up the threads in the carb body, might get enough bite with a bit of locktite or epoxy to salvage it..
I've fixed tractor blocks with JB weld,, I'm sure it would take the beating..
Dave
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is offline   Reply With Quote
Times are GMT -7.   It's 02:49 PM.
