Old 03-29-2013, 10:26 PM   #1
alekkas OP
alekkas's Avatar
Oddometer: 669
DIY factor on maintenance?
Never had a boxer before. Finding some decent used GS prices. Mostly 1200s. However, from some things I read, the cost of proper maintenance and down time at the shop is not something I want to do at this time of life. Additionally, I know one doesn't need a lab coat to do good work.
I do most most most most my own maintenance on bikes and cars. What is the DIY factor for these bikes?
I have the competence and confidence to do most maintenance. For example, valves on my Connie, carbs clean/rebuild, cam chain extenders on vtwins, fluids, forks spring/valving, change/rebuild brakes, change tires etc... I also perseverate and read a ton before taking on a job. YouTube too.
Do these skills on japanese and american bikes transfer to what needs to be done on the 1200s? What are some of the "high cost" jobs and intervals?
So, many DIYers out there? Thoughts?
Some ride reports:
http://leroylanes.blogspot.com/
Why do I keep thinking I'm gonna wind up in a love / hate relationship with a Guzzi?
alekkas is offline   Reply With Quote
Old 03-29-2013, 11:39 PM   #2
Multiplicity
Oddometer: 172
IMO, the BMW Boxer is the easiest DIY machine
Multiplicity is offline   Reply With Quote
Old 03-29-2013, 11:39 PM   #3
a.c.s.
Complaining less
a.c.s.'s Avatar
Oddometer: 244
You'll have no problems doing the routine maintenance on the 1200. I can teach my most mechanicly incompetent friends how to keep the 1200 up to spec with only a little common sense. Throw in a JVB DVD and you'll be trained by "the Master."
The place to improve the world is first in one's own heart and head and hands - R. M. Pirsig
Semper Fidelis
a.c.s. is offline   Reply With Quote
Old 03-30-2013, 12:10 AM   #4
alekkas OP
alekkas's Avatar
Oddometer: 669
Well that's great news!
Most bikes I have known have one or two things that commonly crop up at certain miles - like Vulcan cam extenders around 30k miles. Versys staters around 30k. Etc...
Are there any fairly common things that come up ... Other than replacing wear items.
Some ride reports:
Old 03-30-2013, 06:50 AM   #5
mercury01
Oddometer: 36
A big difference I have found with the 1200 GS over the Japanese, etc is that the body panels fit - you don't end up screwing around trying desperately to line up invisible holes, then try to screw in cheap, nasty fittings. Also, it appears for the most part that the engineering department figured out where everything goes, not the marketing department. Most routine jobs are easy to get to and the tools can actually reach the fitting.
mercury01 is offline   Reply With Quote
Old 03-30-2013, 07:38 AM   #6
Hikertrash
Oddometer: 2,895
One of the reasons I went with a boxer engine is because its so easy to do maintenance on.
Hikertrash is offline   Reply With Quote
Old 03-30-2013, 08:14 AM   #7
MoodyGS
Going round the bend
Location: Monte Nido, Santa Monica mountains, Californiay
Oddometer: 184
Are there any fairly common things that come up......
The routinely get muddy
MoodyGS is offline   Reply With Quote
Old 03-30-2013, 08:15 AM   #8
MoodyGS
Oddometer: 184
They routinely get muddy
Old 03-30-2013, 09:32 AM   #9
chewnaut
Rob
chewnaut's Avatar
Oddometer: 70
Google this: JVB DVD. BMW is loosing tons of money because Jim has taught us that the boxer engines are rediculously easy to work on. Yes, rediculously
chewnaut is offline   Reply With Quote
Old 03-30-2013, 09:40 AM   #10
ragtoplvr
Oddometer: 6,419
This is the easiest bike to work on I know of. That said, there is always something, the exact something is dependent on your skills.
almost anyone can do the liquid changes, spark plug changes. This is not true for all bikes.
A smaller group can add valve adjustment and brakes. There are many bikes, that require cam shaft removal for this, and that requires a much larger skill set!
A smaller still group can pull the tank and change the fuel filter.
Now beyond this point, there is little if any advantage to the boxer and some disadvantages, like clutch replacement.
ragtoplvr is offline   Reply With Quote
Old 03-30-2013, 09:45 AM   #11
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,846
Some but certainly not all R1200GS/GSAs have had issues with final drives and some with driveshaft u-joints, and those are well documented on numerous threads. My bike has been very reliable, and I find it easier and more satisfying to work on than other brands I've owned. Even removing my DRZ's seized swingarm pivot bolt was more aggravating than anything I've ever done on my GSA. For reference, my GSA's maintenance history is detailed at the links at the bottom of my post. Good luck with your decision!
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 03-30-2013, 11:38 AM   #12
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,650
As long as nothing electrical goes wrong aka abs pump, you can fix almost anything yourself. Parts are still expensive tho
AviatorTroy is offline   Reply With Quote
Old 03-31-2013, 07:34 AM   #13
dfwscotty
dfwscotty's Avatar
Oddometer: 3,364
In addition to getting JVBs vids read up on the GS related articles.
This is a link to the articles at teh bottom of every page here.
http://advwisdom.hogranch.com/Wisdom/
Anything you want to do to the GS is found on line. If not, someone has done the work and detailed the jobs in threads here.
Traffick911
1999 BMW 1100GS
2012 Kawasaki Concours
dfwscotty is offline   Reply With Quote
Old 03-31-2013, 07:52 AM   #14
bobbybeemer
Oddometer: 56
I also find the BMW easy to work on. Just use good tools. call your local snap on dealer and get a good torx set. Invest once on a set and they will replace them for life. Get any special tools if needed for a job, many are online. Also don't freak out about the things you read on here and the little noises a boxer makes, just ride it like you stole it.
bobbybeemer is offline   Reply With Quote
Old 03-31-2013, 07:55 AM   #15
jsb223
ADV Rookie
jsb223's Avatar
Oddometer: 1,218
Lot's of great info out there...
Procedures, patience and proper torque values.
R1150GSA
DRZ400S
DRZ400E
jsb223 is offline   Reply With Quote
Times are GMT -7.   It's 12:54 AM.
