Old 03-31-2013, 10:40 AM   #16
Deadly99 OP
Fast and Far
Deadly99's Avatar
Oddometer: 10,037
Originally Posted by roger 04 rt View Post
Did you swap the relays?
Nope, added it to tomorrows list..thanks
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 03-31-2013, 11:32 AM   #17
Mrmerlin
K1300S fast as shi..
Mrmerlin's Avatar
Oddometer: 339
with that many miles has the Hall effect sensor ever been replaced?,
if it was bad then the fuel pump wouldnt run when you turn on the key.
IOTOH the pump runs for a second then shuts off you need to determine if the pump is bad IE not pumping enough fuel.
you can also turn the engine over by hand and see if the pump turns on for a brief second when the cylinder is supposed to fire, this will test the hall effect sensor
Mrmerlin is offline   Reply With Quote
Old 03-31-2013, 11:52 AM   #18
Deadly99 OP
Fast and Far
Deadly99's Avatar
Oddometer: 10,037
I have no history on the bike, sadly.
Turn key, and zero noise from fuel pump( today, Friday morning no sound, Friday afternoon sound and bike ran, Friday evening no sound) Is there a way to bypass the hall sensor...or some other means of testing it?
Cheers
Roaming Rally 2015
Old 03-31-2013, 11:36 PM   #19
Beezer
Oddometer: 5,865
according to my notes....
Fuel pump: Bosch #69222
about $50 on ebay... prolly close to that at auto store. fits a bunch of different cars
Beezer is offline   Reply With Quote
Times are GMT -7.   It's 11:07 AM.
