Old 04-14-2013, 09:32 PM   #16
BadTA OP
BadTA's Avatar
Oddometer: 66
Fun story. LOL.
I"m glad to hear it had a happy ending. I'm hoping for the same. I just don't want to tear the motor completely apart if I don't have to. I also don't want to go through a bunch of effort and then have a bearing fail and have to tear it all down again.
I just want to get back in the saddle again. It's been over a year since the initial downtime. :(
BadTA is offline   Reply With Quote
Old 04-15-2013, 06:26 PM   #17
BadTA OP
BadTA's Avatar
Oddometer: 66
So....Head Gasket? Maybe?
Old 04-15-2013, 10:23 PM   #18
bmwktmbill
Traveler
Oddometer: 5,194
I dont see where it failed.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 04-15-2013, 10:33 PM   #19
BadTA OP
BadTA's Avatar
Oddometer: 66
bill
Haha!
So, seriously, do I worry about the aluminum shavings? I am considering splitting the case.
Old 04-16-2013, 10:48 PM   #20
bmwktmbill
Traveler
Oddometer: 5,194
I am serious, where did it fail?
I don't see the failure point, the gasket is intact.
Forget the rest of the engine, get the head tested first.
Check the cylinder bore by lowereing the piston, take a couple of pics.
Relax as in one thing at a time.
bill
Bill Shockley
bmwktmbill screwed with this post 04-16-2013 at 11:04 PM
Old 04-17-2013, 03:55 PM   #21
BadTA OP
BadTA's Avatar
Oddometer: 66
All the shiny areas are where there is no gasket material. There was coolant in the cylinder and you can even see it on the valves and surrounding area.
Also, I looked at the cylinder and found one vertical stripe. Is this cause for concern?
Old 04-17-2013, 08:43 PM   #22
bmwktmbill
Traveler
Oddometer: 5,194
No concern to me, the bore looks good with the exception of the single scratch.
Aren' the missing parts of the gasket surface stuck to the cylinder gasket area?
Here's a blown gasket caused by a broken compression ring.
Well no matter what you need to pressure test the hed to eliminate that IMHO.
bill
Bill Shockley
bmwktmbill screwed with this post 04-18-2013 at 09:10 PM
Old 04-18-2013, 11:56 AM   #23
BadTA OP
BadTA's Avatar
Oddometer: 66
bill
No gasket material on the cylinder head. :(
Also, the cylinder head bolts were quite loose.
Old 04-18-2013, 06:04 PM   #24
dnrobertson
Big Bike, Slow Rider
Oddometer: 834
Well, without stating the obvious, but if the cylinder head bolts were "quite" loose, wouldn't the coolant be able to flow past the gasket (regardless of whether it was stuffed or not, especially under pressure) into the bottom end?
So your choice is to get the head tested (to make sure it is not the problem) then buy a new gasket and torque wrench and fit everything back together. Or skip the head test and hope for the best.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 04-18-2013, 09:26 PM   #25
bmwktmbill
Traveler
Oddometer: 5,194
Bad,
There's this...
http://en.wikipedia.org/wiki/Deductive_reasoning
Are the copper washers on the head bolts in good shape?
b
Bill Shockley
Times are GMT -7.   It's 05:22 PM.
