Old 03-30-2013, 12:34 PM   #1
munsey8 OP
munsey8's Avatar
Oddometer: 36
Faulty Fan ?
Today my 2006 990 adv boiled up and steam was pouring out.
Temp bar was max, boiled straight away and i switched it off straight away to.
Got home left it running and the fan isn't kicking in.
Is there an easy way to test the fan? e.g. taking it off and attaching it to a battery or something?
munsey8 is offline   Reply With Quote
Old 03-30-2013, 12:53 PM   #2
GZERO
Fixing stuff around
GZERO's Avatar
Oddometer: 265
Right side of the bike, in the radiator right next to the coolant overflow tank there is a rubber boot covering a 2 cable conector.
Put back the rubber boot, disconect the conetor, then get a paper click and jump the two cables together and with the key as if the bike were running the fan should kick in.
Also, did you check the fuse?
Having some time off bikes.....family first :(
GZERO is offline   Reply With Quote
Old 03-30-2013, 01:01 PM   #3
6732cash
6732cash's Avatar
Oddometer: 162
Air lock
6732cash is offline   Reply With Quote
Old 03-31-2013, 08:46 AM   #4
munsey8 OP
munsey8's Avatar
Oddometer: 36
Cheers! Yea checked the fuse and also swapped it anyway. Fuse was good. I tried the paper clip test using a bit of cable and the fan is ok so must be a problem with the thermostat. Cheers for the help.
Old 03-31-2013, 09:04 AM   #5
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Low(er) Temp Fan Switch
If your fan switch has gone bad consider replacing it with one of the lower temp-switching units from ADVMachines. It starts the cooling fan at 88C/190.4F instead of the stock 105C/221F.
Coming on at a lower temp keeps the bike from "heat-soaking" where the fan looses its ability to shed all the BTU's being pumped through the radiator. Makes a huge difference, esp in traffic & slow (or sandy) offroad.
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician screwed with this post 03-31-2013 at 09:19 AM Reason: added "fan on" temp specs
geometrician is offline   Reply With Quote
Old 04-01-2013, 11:30 AM   #6
munsey8 OP
munsey8's Avatar
Oddometer: 36
Cheers, going to get that lower temp thermostat on order.
Old 04-02-2013, 12:23 PM   #7
Steveman
Steveman's Avatar
Oddometer: 471
What u need is the thermo switch not the thermostat, its the one where the two cables you shorted are connected to
Steveman is offline   Reply With Quote
Old 04-03-2013, 01:53 AM   #8
munsey8 OP
munsey8's Avatar
Oddometer: 36
Cheers for all the help. I did mean thermo switch for the fan rather than just the thermo lol!
And turns out I think it was an air lock. After topping up the coolant and bleeding it properly the fan kicked in.
Only had the bike a week, I'm glad the garage checked it over.
Old 04-03-2013, 12:20 PM   #9
6732cash
6732cash's Avatar
Oddometer: 162
Shame you didnt read the 3rd post
Old 04-03-2013, 12:25 PM   #10
munsey8 OP
munsey8's Avatar
Oddometer: 36
I did mate but I'm not very mechanically minded and I assumed the worst. I was just trying to get an idea of what the simplest problems could be to the more complicated lol.
Cheers
Old 04-03-2013, 12:29 PM   #11
6732cash
6732cash's Avatar
Oddometer: 162
Always look for the cheap simple answer first......Enjoy the bike when the weather warms up
Times are GMT -7.   It's 08:18 PM.
