Old 11-09-2013, 12:38 AM   #1
Plaka OP
Brevis illi vita est
Oddometer: 4,588
Who took the Teflon?
So I keep hearing about these "teflon" lined cables the airheads have. I keep saying not freakin' likely simply because I know how unsuitable teflon would be for the application. I've been thinking it's polyethylene.
So I ended up with a leftover piece of choke cable from a 1--->2 system, about 1983. I cut one end off and pulled out the piece of plastic tube iside. Didn't look like telon, didn't feel like teflon either (I have some teflon slab around). I gave it the old lighter test and it melted instantly, burned with a halfway clean blue flame and started dripping flaming globs on the floor. Ah for some orange sunshine blotter and ziltches.... Anyway, it ain't Teflon. But it wasn't looking like polyethylene either. Poly burns in a particular way, it goes clear where it melts just ahead of the flame front. And it didn't smell like poly---although that one is subtle. it definitely isn't nylon. Nylon has very distinctive smell. Try lighting up the end of a zip tie or some nylon robe. It isn't polyurethane. That stuff makes a black char as it burns and the smoke is ultra nasty--my nose is still stinging (and no buzz either ).
So does anyone know what it is or have any ideas? (I still have to test some UHM-PE, I have to get the glue off it. The PE I tried was tube, not sheet, and likely HD or LLD.)
Old 11-09-2013, 01:03 AM   #2
squish
Out of the office.
Oddometer: 6,161
Maybe PBT polybutylene terephthalate....
Or PET polyethylene terephthalate.
I'm not a plastics guy but IIRC both were used in bowden cable liners.
On vacation for a spell
squish is offline   Reply With Quote
Old 11-09-2013, 03:18 AM   #3
lockyv7
lockyv7's Avatar
Location: Sunshine Coast Australia, There is no winter here.
Oddometer: 1,022
Polytetrafluoroethylene PTFE !!
there featherlight cables available from Motobins in the UK. I changed over my clutch cable and there was a marked improvement.
lockyv7 is offline   Reply With Quote
Old 11-09-2013, 03:23 AM   #4
paulom
Oddometer: 29
Sorry to burst your bubble, but PTFE = teflon.
paulom is offline   Reply With Quote
Old 11-09-2013, 03:59 AM   #5
Plaka OP
Oddometer: 4,588
Scratch PET. Very distinctive sweetish odor when burned. Just tried some.
Dunno how to get some confirmed PBT. But given the date of the cable, I may be able to get something off the patent date.
Old 11-09-2013, 04:12 AM   #6
lockyv7
lockyv7's Avatar
Oddometer: 1,022
FEATHERLIGHT CLUTCH CABLES
Featherlight clutch cables provide the ultimate smooth delivery and clutch action. The high technology teflon lines and super smooth marine grade stainless steel inner combine to provide the lightest of actions. PTFE is "self lubricating" and requires no oiling.
Old 11-09-2013, 04:52 AM   #7
Horsehockey
A GPS? Huh?
Oddometer: 328
Wrong or right, I've concluded that the speedometer, tach, clutch and choke cables benefit from oiling. Brake cable too, prolly, though I've never oiled a brake cable. It's the throttle cables that are lined with something that does not benefit from oiling...and some say oiling can harm throttle cable linings. Just put this in the interweb urban myth category if you wish, but I thought I'd share my conclusions...which flow from reading lots of airhead forum posts over the past 10 years.
Horsehockey is offline   Reply With Quote
Old 11-09-2013, 05:40 AM   #8
beemerphile
beemerphile's Avatar
Oddometer: 1,749
IIRC, the teflon is coated on the cable and not the composition of the sheath. PTFE tubing is possible to manufacture in short lengths. It is used in medical devices, but is crazy expensive because the pure material cannot be extruded. Tthe extrudable types are not pure PTFE but only called "Teflon" by the expanded use of the trade name by DuPont.
I'm guessing teflon-coated wire inside a nylon sheath is what gets called a "teflon cable".
ΜOΛΩΝ ΛΑΒΕ - Lee
Amateurs practice until they get it right, professionals practice until
they never get it wrong
beemerphile is offline   Reply With Quote
Old 11-09-2013, 07:26 AM   #9
SculptD
Smells like tech
Oddometer: 455
On the burning poly question, is there a different appearance when burning LDPE vs. UHMW?
R75/5 SWB, Aprilia Falco. Both compulsively modified. And an R100s is on the way.
SculptD is offline   Reply With Quote
Old 11-09-2013, 07:41 AM   #10
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,336
Teflon tubing (i.e. tubing made of PTFE) : http://www.mcmaster.com/#5239k23/=payxjz
Stan_R80/7 is offline   Reply With Quote
Old 11-09-2013, 07:47 AM   #11
Plaka OP
Oddometer: 4,588
Nope. The cable That came out of this sheath isn't coated with anything. Heated the end to red hot and only the tiniest whisp of smoke and a burning oil smell.
The sheath inside the housing isn't nylon. see opening post.
Coating a cable with teflon or anything else is a major pain, costly and gives no benefit. The Cf of steel on plastic and plastic on plastic is the same. Look it up, many engineering sites have the data tables for various materials. When you make cable, the wire is lubricated to reduce friction running through the spinning dies. To coat*** it, you need to get that lubrication off. bunch of work.
Virgin teflon is extruded. There is no "extrudable type". It is simply mixed with a carrier as an aid in the process and the carrier is removed later. Check out DuPonts (and others) technical literature on processing it. It is not melt extruded like other thermoplastics. 1/8" tubing in 50' lengths is commonly available (try shopping for some) and I suspect that is cut from much longer spools. This material is used for medical purposes, research gear and everything else. I have a short piece around here somewhere. it is indeed expensive. Crappy material to line a cable sheath with---it's soft and doesn't resist abrasion. It also cold flows. I notice the stuff I took out of the cable sheath is very springy.
*** as in really coat it, not just overmold it like the vinyl on a bicycle cable lock.
Old 11-09-2013, 08:17 AM   #12
SculptD
Smells like tech
Oddometer: 455
Wouldn't nylon also be lousy? It swells with moisture.
Old 11-09-2013, 11:03 AM   #13
Plaka OP
Oddometer: 4,588
I would expect not but I haven't tested it. I've welded UHMW and it gets transparent at melt. I have to try some LD, it can be more transparent in the first place (like a 6 pack 6 ring package)
Old 11-09-2013, 11:03 AM   #14
Plaka OP
Oddometer: 4,588
Yes, but it isn't nylon anyway.
Old 11-09-2013, 01:02 PM   #15
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,124
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Times are GMT -7.   It's 07:23 AM.
