Old 03-30-2013, 05:52 PM   #1
vlhugo OP
Oddometer: 11
Gas milage w/Akrapovic
Just installed new complete Akrapovic exhaust on my 2007 gs and looks like gas milage went from 45 mpg to 33! I also pull out silencer and ride 80-85 mph for little while so I understand gas milage is lover but I read before taking out catalic conventor will help for better gas milage?
vlhugo is offline   Reply With Quote
Old 03-30-2013, 05:56 PM   #2
JustKip
JustKip's Avatar
Oddometer: 4,620
Oops!
Looks like I'll hold off on ordering till there are a few experienced responses.
JustKip is online now   Reply With Quote
Old 03-30-2013, 06:00 PM   #3
Menachem
Oddometer: 194
I have a full system on my 08 GSA and I get 40-43 depending. I am not light on the throttle.....
Did you remap? You really should
08 BMW R 1200 GSA
07 Ducati 1098s
06 Ducati 749R...track only
06 DRZ 470 supertard
Menachem is offline   Reply With Quote
Old 03-30-2013, 06:06 PM   #4
darmahman
"Illogically Deluded"
darmahman's Avatar
Oddometer: 3,089
I have 8000 miles on my Akro and there is no difference in mpg from my stock system. I get 45- 50 mpg.
ABC# - 4011
“Folks are usually about as happy as they make their minds up to be.” Honest Abe
The last honest politician to come out of Illinois
darmahman is offline   Reply With Quote
Old 03-30-2013, 06:38 PM   #5
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,262
Good questions but I'm wondering why you think removing the catalytic converter would improve your gas mileage.
Those runs at 85 mph use a lot of additional fuel. If you run the same course on the same day you should get roughly the same mileage with either exhaust.
You mentioned removing the cat, did you leave the O2 sensors connected?
roger 04 rt is offline   Reply With Quote
Old 03-30-2013, 06:50 PM   #6
Racegun
Single Track Mind!
Racegun's Avatar
Oddometer: 2,567
Cool2
here is an idea...
Put the old stock exhaust back on. Ride the hell out of the bike like you did with the after market unit. Check your milage. Do it again w/ the aftermarket, ride it the same way. Compare milage. Should be close in mpg. It is incredibly super easy to trash mpg's with spirited riding.
BTW, leave O2 sensor in operation. Unless you have the ability to monitor the exhaust with a gas analyzer
and a dyno-mometer and the technical ability to re-map etc.
...well those were my findings anyway.... back to your regular scheduled program.
Racegun screwed with this post 03-30-2013 at 06:59 PM
Racegun is offline   Reply With Quote
Old 03-30-2013, 06:55 PM   #7
vlhugo OP
Oddometer: 11
Yes o2 sensors are connected, info about catalytic converter I read here afew month ago. Anyway I will try it again maybe I will come with better numbers.
Times are GMT -7.   It's 08:46 AM.
