Old 03-31-2013, 04:44 AM   #1
DeepSeaOne OP
Carnivore
DeepSeaOne's Avatar
Oddometer: 58
Question KTM Fuel mapping
All,
I have a 2013 690 Enduro and I'm ordering a pipe for it this week. Having read a few threads on the need for fuel mapping being hit or miss depending on configuration, type of mod etc....the 2013 has adjustable fuel mapping under the seat...
Is it a safe assumption that I can simply use one of the factory map settings to at least to get close to optimal?
2013 KTM 690 Enduro R, FMF Apex, Vortex ECU
2014 Night Rod Special, Vance & Hines/Screaming Eagle package
DeepSeaOne is offline   Reply With Quote
Old 03-31-2013, 07:05 AM   #2
ramjet
ramjet's Avatar
Oddometer: 2,268
Originally Posted by DeepSeaOne View Post
All,
No. It's a KTM.
"Moral courage is the most valuable and usually the most absent characteristic in men." Gen. George S. Patton
ramjet is offline   Reply With Quote
Old 03-31-2013, 07:44 AM   #3
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,652
All,
That's an ignition map switch, not a fuel map switch.
Old 03-31-2013, 08:12 AM   #4
DeepSeaOne OP
Carnivore
DeepSeaOne's Avatar
Oddometer: 58
Ahh, that explains the aftermarket bar mounted units I've been seeing.
Old 03-31-2013, 08:21 AM   #5
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,967
It'll run like a scalded ape just the way it's delivered.
Uni Twin Pod air filter, a Wings can, and the canisterectomy/22k ohm resister mod are the only engine related mods I made and that's all I'm gonna do.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 03-31-2013, 08:32 AM   #6
DeepSeaOne OP
Carnivore
DeepSeaOne's Avatar
Oddometer: 58
Dirty
Yes...it's "Uh-Oh" fast as is but it sounds like a scooter. I'm doing pretty much the same to mine cept a FMF pipe/can. Should sound (and run) like war.
Old 03-31-2013, 10:51 AM   #7
sprouty115
sprouty115's Avatar
Oddometer: 1,555
Dirty
No mapping adjustment at all? On an already factory-lean-mapped bike? I've been down this road on an FI Triumph, the bike appears to run fine but anyone who actually spends the coin on a dyno finds out pretty quickly it's a dangerous assumption.
sprouty115 is offline   Reply With Quote
Old 03-31-2013, 04:45 PM   #8
DeepSeaOne OP
Carnivore
DeepSeaOne's Avatar
Oddometer: 58
If the ECM was done right it should be able to compensate for breathing mods with ease providing the change isn't major (which a can and filter is not necessarily). These things would be extremely altitude sensitive if they were bothered by such things.
That said I'm sure there are platforms that could be negatively affected but it doesn't necessarily take a dyno to figure that out. Long before dyno's became mainstream we were simply reading spark plugs with a pretty good degree of accuracy.
Old 03-31-2013, 05:27 PM   #9
sprouty115
sprouty115's Avatar
Oddometer: 1,555
Maybe KTM did a better job than Triumph, I don't know. But an exhaust and filter change are a big deal on the Triumph classic series bikes. Just to be clear, I'm not suggesting every bike needs to go on a dyno, but a correct map buys you engine life even if you don't feel it in the seat of your pants and as a general recommendation it's a good idea.
sprouty115 screwed with this post 03-31-2013 at 07:14 PM
Old 04-01-2013, 08:32 AM   #10
wsmc831
wsmc831's Avatar
Oddometer: 758
Get a filter and the evo1 airbox lid, load up evo1 map with tuneecu...or you could just load the Akro map if you didn't want to deal with airbox. I've loaded maps to 3 different 690 enduros (08/10/12) and all ran the best with evo1 map vs akro map.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 04-02-2013, 03:51 AM   #11
DeepSeaOne OP
Carnivore
DeepSeaOne's Avatar
Oddometer: 58
I'll likely do that. For now I'm going to see how it does just with a can and a K&N then pick up the tuner.
Old 06-01-2013, 12:47 PM   #12
dep411
dep411's Avatar
Oddometer: 150
If you can chime in:
I have the wings slip on/ DNA open snorkel air filter on a 2013 690E
I can't find the arko map but on the tuneecu site I found the EVO1 map only.
don't know what to load on the ECU as this is the first time doing this..
thanks for any help
dep411 is offline   Reply With Quote
Old 02-01-2015, 10:14 PM   #13
OldTriumphRider
Livin the Dream
OldTriumphRider's Avatar
Oddometer: 166
New toy
I just got a 2013 KTM 690 Enduro R , just kinda going through it and making a few changes.. I removed the S.A.S (turned in off using tune ecu) got a FMF Q4 pipe coming... as of now I'm undecided about changing the mapping.. Has anybody made these changes? As for now I plan on leaving the air intake stock. I put the Rottweiler on my 990 Dakar and after a week riding in the sand in Florida I had sand sticking all over the thing... planning on taking this bike on the TAT in June...I'll listen to all comments/////
OldTriumphRider is offline   Reply With Quote
Old 02-05-2015, 08:28 PM   #14
OldTriumphRider
Livin the Dream
Oddometer: 166
EVO 1 air box top
Well I ordered an EVO 1 air box lid the other day.. it comes with a map from EVO 1 ..from reading on here it sounds like all works good together.
No one else working on one of the 690s ?
Looks like a fun bike , hope to have it on the road next week sometime if I get the EVO and a couple other things I ordered.
Old 02-08-2015, 08:26 PM   #15
OldTriumphRider
Livin the Dream
Oddometer: 166
690 stall
I rode about 100 miles on the bike today ,( haven't got the Evo 1 top yet) I had it stall a few times as I came up to a stop. I read on here some of you have had stalling problems...Tomorrow I get the top and will put the Evo 1 map in the bike ...other than that the bike runs great.
Times are GMT -7.   It's 10:23 PM.
