Old 03-31-2013, 07:39 AM   #1
slickgj OP
slickgj's Avatar
Oddometer: 50
Final Drive Check Question
I did a ton of reading and searching and I have a question I didn't find a specific answer to, or maybe I just missed it (sorry). I don't want to beat the FD check to death but:
I am looking at an 02 1150GSA and the FD is solid when checking at 3 and 9, but there is slight play at 6 and 12. Since the play is only noticeable at 6 and 12 would this likely be an indicator of a pivot bearing issue vs the FD drive bearing?
thanks everyone,
slickgj is offline   Reply With Quote
Old 03-31-2013, 07:43 AM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,933
thanks everyone,
Have someone hold the brake. If you still have play it is your pivot bearings. If not it is your FD bearings.
Jim
Old 03-31-2013, 08:07 AM   #3
slickgj OP
slickgj's Avatar
Oddometer: 50
Thanks Jim, will do that.
It's not a lot of play and it's solid at 3 and 6 so maybe just an indicator its just starting to go. Will try the brake check.
Old 03-31-2013, 12:19 PM   #4
roadtrip22
roadtrip22's Avatar
Oddometer: 336
Follow me on Facebook--- http://www.facebook.com/2wheeladventures
100 things all GS owners should read---http://advrider.com/forums/showthread.php?t=836736
Repair and Maintenance DVD's--- http://www.jimvonbaden.com/
roadtrip22 is offline   Reply With Quote
Times are GMT -7.   It's 01:30 AM.
