Old 03-31-2013, 08:55 AM   #1
thecoralreefer OP
thecoralreefer
Oddometer: 1
broken part found in engine, 1978 xl250s
This part was found laying in side case when changing cam chain. It is cast steel/iron (magnetic) with the only machining a slight bit on the end of the 2 opposing sides. No signs of wear or polishing so it does not appear that it was under much force. I have removed the valve cover and both side cases and can not located the original location. Any idea? Maybe from inside tranny? http://tomgabi.zenfolio.com/p96790028
thecoralreefer is offline   Reply With Quote
Old 03-31-2013, 09:07 AM   #2
mcma111
mcma111's Avatar
Oddometer: 11,863
That's a tip off of one of the shift forks. To replace that part means the engine has to come completely apart.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-31-2013, 10:04 AM   #3
baloneyskin daddy
bikaholic
Oddometer: 2,085
The bike's over 30 yrs old , if it was working fine before you found the piece it may continue to work for a long time. Keep that in mind ,but if you can't live with it at least make sure the part is available before you tear into it.
baloneyskin daddy is offline   Reply With Quote
Old 03-31-2013, 10:12 AM   #4
mcma111
mcma111's Avatar
Oddometer: 11,863
According to Cheapcycleparts only one of the three shift forks are still available. This is for a 79 as they don't list the 78
E-Bay, $25.00
http://www.ebay.com/itm/1978-1981-Ho...42a39b&vxp=mtr
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 12:25 AM.
