Old 03-31-2013, 12:49 PM   #1
Monsignore OP
Plunger Boy
Monsignore's Avatar
Oddometer: 901
Help, FD won't connect.
(Bike is '05 R1200GS, 58,000miles)
I thought today would be a nice service day: change FD oil & lube splines, replace rear brake rotor and pads, test ride all before the rain set in.
Nope.
FD oil drained, splines lubed, and that's where I'm stuck. I've been struggling for the past 3 hours to get my FD and driveshaft splines to align. I can get the FD side to just start to connect with the drive shaft, but then the corner of the FD gets caught in the mouth of the shaft. I've tried brute strength, banging on FD housing with a rubber mallet, I even bought a ratcheting tie-down to try to slowly force it in. All to no avail.
Right now the bike is on the street with the FD held up by the tie-down, it's gonna rain soon, I work until 2:30 tomorrow, MaxBMW is closed tomorrow, and I go out of town Tuesday thru Saturday.
Am I missing something, is there an easy way I'm not seeing? I'm proper fooked, so any advice is greatly appreciated.
Ewig war ich.
IBA # 55612
Monsignore is offline   Reply With Quote
Old 03-31-2013, 12:57 PM   #2
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 926
Try putting the transmission in gear to keep the driveshaft from turning.
whisperquiet is offline   Reply With Quote
Old 03-31-2013, 01:34 PM   #3
WoodButcher
WoodButcher's Avatar
Oddometer: 2,057
Pull the rubber boot off and put it together a couple of times. With the boot off you can see what you are doing and learn the trick. Then put the boot back on and put it together one last time.
Rusty
2009 BMW R1200GS Adventure
1999 DR650
WoodButcher is offline   Reply With Quote
Old 03-31-2013, 01:40 PM   #4
Kingsized
Kingsized Adventurer
Kingsized's Avatar
Oddometer: 762
Don't try and force it. When it aligns it will slide in. The last time I serviced my final drive I had the same problem. It only took me about 30 minutes but I had an extra set of hands. Walk away from it for a bit. We didn't find an exact solution, it just finally slid in after rotating the rear tire and playing with the transmission. Not much help I know.
Everything's better in retrospect.
My ride through Bourbon county http://advrider.com/forums/showthrea...7#post22154447
Two Wheels Good, a journey out west http://twowheelsgood3.blogspot.com/
Kingsized is offline   Reply With Quote
Old 03-31-2013, 01:40 PM   #5
Jorik
Jorik's Avatar
Oddometer: 71
This + try to hold shaft straight by screwdriver inserted into u-joint.
Jorik is offline   Reply With Quote
Old 03-31-2013, 02:32 PM   #6
Monsignore OP
Plunger Boy
Monsignore's Avatar
Oddometer: 901
I tried fitting the parts without the boot. Nope.
In gear. Nope.
In neutral. Nope.
Screwdriver in U-joint. Nope.
Various combinations of the above. Nope.
Even when I could align both parts by hand without the boot, and was fairly certain I had flange and groove matched, there would be no movement. It's like the receiving end suddenly shrunk by a minute amount.
Ewig war ich.
IBA # 55612
Old 03-31-2013, 05:19 PM   #7
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,541
That is how I do it. If you lower it gently and add the boot, it usually goes right back on.
Jim
Old 03-31-2013, 05:21 PM   #8
JimVonBaden
"Cool" Aid!
Oddometer: 51,541
In gear. Nope.
In neutral. Nope.
Go have a beer and relax. When you start again it will fir right on!
Some people find using a rag under the shaft to hold it up a bit helps. Just make sure the rag has a part hanging out to the side so you can pull it out when done.
Jim
Old 03-31-2013, 07:14 PM   #9
orgo
Oddometer: 210
Don't use force or rubber mallet. If it's aligned it'll slip on. be patient
orgo is offline   Reply With Quote
Old 03-31-2013, 08:06 PM   #10
def
Ginger th wonder dog
def's Avatar
Oddometer: 9,720
Does that model have a phasing spline which requires rotational alignment?
def is offline   Reply With Quote
Old 03-31-2013, 08:19 PM   #11
FlyingFinn
Oddometer: 1,097
No.
"It is not when or how you die but how and if you truly were ever alive!" Dr. Jerri Nielsen FitzGerald
FlyingFinn is offline   Reply With Quote
Old 03-31-2013, 08:44 PM   #12
LaurelPerryOnLand
Oddometer: 3,478
Per Jim Von Baden's Tech Pictorial:
http://www.jimvonbaden.com/R1200_Final_Drive.html
Step 8 says...
"8. Install the rubber gaitor, pivot the rear-wheel drive up and introduce the bevel-pinion shaft into the universal drive shaft. If necessary, turn the FD gently back and forth to facilitate this operation. (This is made way easier if you have the bike in neutral.) I took half an hour to figure this out, and it still took a few minutes). Also, if you are having trouble, pull the gaiter off and test fit it, then reinstall the gaiter and it will go on easier."
Here's a trick I discovered: (variation of the ole SUPPORT THE SHAFT WITH A SCREWDRIVER when assembling):
I make a U-shaped stainless wire and loop it UNDER the "universal drive shaft".
Open part of the U at the TOP.
This makes it EASY to adjust the mating shaft...LEFT or RIGHT...UP or DOWN.
Once you've got it initially mated...PULL the wire out.
Yeah...takes us ALL about an hour to figure this critter out...so don't be so hard on yourself.
Like a previous posters idea of having a beer break!
Sometimes...starting a project on a NEW day also helps.
Good luck.
LaurelPerryOnLand screwed with this post 03-31-2013 at 09:07 PM
LaurelPerryOnLand is offline   Reply With Quote
Old 03-31-2013, 08:58 PM   #13
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,974
I find it best if you set the driveshaft up so it hinges vertically without binding at all. Drop it nearly straight down and lift gently.
Did it not fit before or after the banging and ratchet strap? Hard to believe you could damage the splines but you might check for burrs now.
Got a friend nearby? They don't need anything but a couple extra fingers to help you with. Even a pissed off wife/girlfriend will work.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb screwed with this post 04-01-2013 at 09:31 AM
trc.rhubarb is offline   Reply With Quote
Old 04-01-2013, 12:08 AM   #14
kk3an
kk3an's Avatar
Oddometer: 88
Having done this many times personally, I agree 100% with trc.rhubarb....it sounds as if the final drive is not being introduced perfectly flush to the shaft. Perhaps apply grease to the initial contacting surfaces, and try to introduce both at as close to a 1:1 as possible.
kk3an is offline   Reply With Quote
Old 04-01-2013, 07:26 AM   #15
bobbybob
Oddometer: 591
Any chance the front splines are pulled back from the transmission output shaft?
bobbybob is offline   Reply With Quote
Times are GMT -7.   It's 11:39 AM.
