Old 03-31-2013, 03:04 PM   #1
motorkelly49 OP
Oddometer: 2
New Owner - Simple Question - 12 volt outlet
Just joined the group via a barely used 2010 990 Adventure. Love it! Simple question. The 12 volt receptacle on the "dashboard". Do I correctly understand I need an adaptor to accept BMW-style powerlet plugs, such as for Gerbing heated gear? Thanks in advance!
motorkelly49 is offline   Reply With Quote
Old 03-31-2013, 05:02 PM   #2
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,043
No need for an adpter as it is a BMW style receptacle, As opposed to the much larger standard cig receptacle in autos.
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 03-31-2013, 05:02 PM   #3
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,818
Correct. The socket fits a standard US- style cigarette lighter plug
I see another opinion. Above. Let me be more clear. My 2011 990A has the same socket as all three of my cars.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 03-31-2013, 08:48 PM   #4
motokeith
Oddometer: 107
The plug in the dash is a standard automotive style cigarette plug. Gerbing, Powerlet, First Gear, and Warm & Safe heated clothing uses coax connectors, so you want a cigarette to coax adapter like the one found on this page...
http://gerbing.com/Products/accessories.php
If the plug in the dash was the BMW style plug you would still need an adapter to mate to the coax plug on the clothing.
The stock fuse for that cigarette plug may not be adaquate for heated gear.
motokeith is online now   Reply With Quote
Old 03-31-2013, 08:58 PM   #5
chrish4ku
chrish4ku's Avatar
Oddometer: 848
On my 2011 - I installed a parallel BMW style outlet, to the same fuse line as the dash item (car style). Easy job - and has been fine for my heated vest. Better position and doesn't get in the way. I would not or do not, run both outlets at the same time as I am fairly sure the fuse would blow. I am using the Tour Master Synergy heated vest for example.
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 04-01-2013, 07:50 AM   #6
motorkelly49 OP
Oddometer: 2
Outlet
Thanks so much for the prompt and helpful replies. Just what I needed! Cheers!
Old 04-01-2013, 07:52 AM   #7
FakeName
FakeName's Avatar
Oddometer: 1,818
Originally Posted by chrish4ku View Post
Ouch.
I'd impale myself on the protruding plug in the first ten minuites.
2014 500EXC Black
Old 04-01-2013, 09:08 PM   #8
Bill 310
Poser Emeritus
Bill 310's Avatar
Oddometer: 3,193
My 2007 has a BMW powerlet type plug. My electric's guru upgraded the wire gauge from the plug and wired it (with fuse) directly to the battery.
My Gerbings was much warmer with the heavier gauge of wire.
Canada "It's a rough place, son. In fact, you have to puke twice and show your razor just to get in. Better grow some whiskers if you wanna go to Canada." Ronnie Hawkins when asking Levon Helm to join his band and play in Canada.
Bill 310 is offline   Reply With Quote
Times are GMT -7.   It's 12:03 PM.
