Old 04-01-2013, 03:45 AM   #1
ME 109 OP
ME 109's Avatar
Oddometer: 2,719
Wheely confused
So I'm about to replace my 12 sided rear '81 snowflake with a nice straight one.
Trouble is, I think the straight wheel I have is a '77 (77/6 stamped on spline side)
It has those raised humps in the spline cup area. It also has steel inserts.
What can I do with this wheel in order to use it on a '81?
Is it just a matter of grinding off those humps?
The wheel is very straight and clean.
Did a po toast his wheel bearings and have the inserts put in?
So close, yet so far.
Lord of the Bings, kangaroo farmer
ME 109 is online now   Reply With Quote
Old 04-01-2013, 05:19 AM   #2
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,230
Should be. That was BMW's published solution to using a newer finned FD on a pre-'81 bike. That's the same mismatch you're talking about.
Old 04-01-2013, 05:30 AM   #3
ME 109 OP
ME 109's Avatar
Oddometer: 2,719
Thanks Anton, I tried a basic fit up of the wheel and found that the fd did hit on those lumps, judging by the small amount of grease/grime left on the lump. The wheel would not turn at all.
An angle grinder is one of my favourite surgical instruments so all should be good there.
I was reading somewhere recently that the later snowflakes came with steel inserts?
If this wheel has been sleeved due to a spun bearing, it has been done well.
Old 04-01-2013, 06:56 AM   #4
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,472
Jeff, the black wheels I have were earlier wheels, the rear had the "protrusions". Your choice of weapon should be your trusty angle grinder. That's what I did.You can see the remnants of some of them marked in red...
boxerboy81 screwed with this post 04-07-2013 at 06:00 AM
boxerboy81 is offline   Reply With Quote
Old 04-01-2013, 07:20 AM   #5
ME 109 OP
ME 109's Avatar
Oddometer: 2,719
Thanks Steve, a 4" angle grinder shall be the choice here.
Imagine, a round back wheel. That will be something different.
Old 04-01-2013, 09:48 AM   #6
Plaka
Brevis illi vita est
Oddometer: 4,609
On my '83 the center of the hub is steel all the way through. The outer bearing races sit on a steel shoulder that seems to be integral with the rest of the steel in the center. The bearing outer races come out their respective sides.
Make sure the wheel is the post-recall type with the ribbed spokes at the center.
Old 04-01-2013, 09:52 AM   #7
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
Didn't the early snowflakes get recalled and replaced with the ones that had extra fins on the "spokes"?
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 04-01-2013, 10:24 AM   #8
ME 109 OP
ME 109's Avatar
Oddometer: 2,719
That's for front snowflake wheels, excluding the 18" R65 front snowflake wheel.
I'm going to operate on a rear wheel.
I like the steel inserts. Much better idea.
Old 04-01-2013, 10:24 AM   #9
villageidiot
Oddometer: 1,717
Only the fronts
villageidiot is offline   Reply With Quote
Old 04-01-2013, 10:24 AM   #10
chasbmw
Oddometer: 2,204
It was only the 19" front wheels that got recalled.
Charles
1971 Commando Fastback
Old 04-01-2013, 10:32 AM   #11
ME 109 OP
ME 109's Avatar
Oddometer: 2,719
Lucky I got in first.
Old 04-02-2013, 02:44 AM   #12
ME 109 OP
ME 109's Avatar
Oddometer: 2,719
Lugs removed and wheel on the bike.
Not too impressed with the tyre tho'
Michelin pilot active 4:00
Wheel is very good for running true.
Tyre on the other hand makes the wheel look buckled.
Bike on centre stand in 3rd gear at about 1500, The tyre appears to have a buckle!
I let the tyre down to about 10 lbs and rolled the bike backwards and forwards for a couple of wheel revolutions.
I pumped it back up to 75 psi then dropped it down toabout 37psi
The 'buckle' in the tyre is still there, although the rim can be observed to run true, certainly not showing any sign of causing the tyre to move.
I'd put a vid up but I've run out of time for a coupla days (goin' surf fishing. fuck the bike)
Any thoughts? Can't say I've seen a tyre do this.
Old 04-02-2013, 05:06 AM   #13
Plaka
Oddometer: 4,609
Buckle?? Pic?
I just made something you gotta have for your poor abused RS...Time to start a build thread I guess.
Old 04-02-2013, 02:34 PM   #14
ME 109 OP
ME 109's Avatar
Oddometer: 2,719
I do a video when I get back in a coupla days.
Old 04-05-2013, 06:20 PM   #15
ME 109 OP
ME 109's Avatar
Oddometer: 2,719
That was a quick coupla days.
Anyhowz, here is a you-tube link to my wobbly tyre.
Not sure what y'all might suggest other than deflate and move tyre around and try again?
http://www.youtube.com/watch?v=pFWJPcOt4Dw
Times are GMT -7.   It's 08:44 PM.
