Old 04-01-2013, 06:14 AM   #1
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
Error when firing up BaseCamp
Recently, I have purchased and installed 24k topo Northeast and 24k topo Southeast onto my PC, and the data card on my Montana.
However, when I started up BaseCamp the other day, before it would open, I got the following:
I hit cancel, and BaseCamp proceeded to open. I went to a known location in the southeast with 24k Topo Southeast selected and only base map detail was shown.
I reinstalled both Topo sets. Now, when I fire up BaseCamp, I still get the error, but the missing map detail is no longer missing and is now displayed.
Thoughts? (This is on a Windows PC)
Old 04-02-2013, 12:59 PM   #2
Emoto OP
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
Got it figured out!
Found "TOPO U.S. 24K Southeast v2.gmap" shortcut in C:\ProgramData\Garmin\Maps\ so, I opened BaseCamp, then when the error message came up, browsed to it and selected it. BaseCamp then opened and SE topo info was displayed. Then, I closed BaseCamp and re-started it. Guess what, same error message, and when I clicked Browse, it remembered where I had been and so I selected "TOPO U.S. 24K Southeast v2.gmap" again.
Someone suggested that I take a look at the properties of that shortcut, and that was the key to it!
The path shown in the properties was to a folder on a drive letter that I think the PC assigns to either my Zumo or Montana when connected. Since it was not connected, it was not finding it. So, the error message was somewhat misleading. It ought to have said that the shortcut target was not found instead of the shortcut itself not being found. I edited the shortcut target to "C:\ProgramData\Garmin\Maps\TOPO U.S. 24K Southeast v2.gmap" (the folder) and when I re-started BaseCamp, no more error message!
So, at some point, the shortcut changed to point to the folder on the GPS unit, rather than to the folder on the hard drive. Maybe this happened when I used BaseCamp to install the maps to the GPS unit?
Re-pointing it to the hard drive folder fixed the problem.
Times are GMT -7.   It's 04:16 AM.
