Old 04-01-2013, 07:19 PM   #1
Bronco638 OP
Nobody Home
Bronco638's Avatar
Oddometer: 3,969
GPSmap 60Cx - Prevent zoom out @ way point?
Sorry if this has already been covered/discussed. I did a search and used Google but didn't not come up with anything pertinent. Perhaps I was using the wrong search term(s).
I have a GPSmap 60Cx. I was experimenting with a "test" route around my neighborhood. It has about 10 via points and 8 way points. It's short enough that I can walk the route.
My issue: every time I encounter or pass a way point, the map zooms out to minimum resolution. I have to push the "in" button four or five times to get back to the scale I was using (120 ft., I think). Is there a way to prevent this from happening? I don't want to have to do this while riding.
I have registered the GPS with Garmin and My Garmin tells me that the unit's software is up-to-date. I am using Base Camp to create the routes.
TIA, Dave.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 04-02-2013, 03:29 AM   #2
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,760
I think you need to turn off Auto Zoom:
To turn autozoom off on a GPSmap 60CSx/60Cx/76CSx/76Cx;
(Menu) (menu)
Setup (enter)
Map (enter)
(At top - left most symbol selected), toogle down to autozoom
(enter) select Off (enter)
(From this post)
Old 04-02-2013, 08:28 AM   #3
Bronco638 OP
Nobody Home
Bronco638's Avatar
Oddometer: 3,969
Thanks Em, I'll give that a try.
EDIT: that worked great.
Bronco638 screwed with this post 04-03-2013 at 07:58 AM
Old 04-02-2013, 10:49 PM   #4
Countdown
Oddometer: 5,688
There is about an hour of set up you need to do.
Go to DualSportWest.com and click GPS follw instructions for 60/76 set up.
Jerry Counts
Countdown is offline   Reply With Quote
Times are GMT -7.   It's 05:19 AM.
